Question about New World G70m Gas Double Oven
Heat escaping from cooker door
New world vision G60m cooker already in house when we bought it. lots of heat escaping from top of cooker door. doesn't seem to be a problem with the seal of the door. taking double the length of time to cook food! please help! thanks
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: New World G90M
Normally they are held on with metal clips at each corner, just pull the seal back and unhook the clips to remove the seal..
Re fit by hooking the clips into the holes in the front of the oven, you will probably have to stretch the seal to get it to fit with it being new.
Plz rate this solution.
Thanks.
Posted on Dec 19, 2008
Can I fit a plug to new world vision 50 ecwlm cooker instead of electric box? Tried to find out if over 2.9kw but 2nd hand and no manual details
I have heard of people doing that and getting away with it - such is the capacity of the modern domestic ring circuit. Certainly no one should be doing it and no one with electrical knowledge would condone or recommend such a thing as if you didn't get away with it, it could burn your house down without blowing a fuse or tripping any safety devices.
The cables carrying the current to the sockets and light fittings traverse many flammable things between the power outlet and the electricity meter...
In an emergency you could fit a plug and use the cooker but never, ever more than one boiling ring and one simmer ring OR the grill OR perhaps even the oven if it is a conventional oven.
If you do decide to take the chance I advise you most strongly never to trust anyone else to operate the cooker and never to leave it unattended...
A large boiling ring is typically 1500/2000 watts and a small simmering ring is typically 800/1000 watts. I can't tell you what the consumption of the other equipment might be but it should be easy to discover as the manufacturer might have a downloadable manual on the website or you could try googling replacement heating elements.
You should have a cooker outlet installed as soon as possible.
Oct 01, 2016 | New World Ovens
Gas wont stay lit after ignition
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 19, 2011 | New World G60m Gas Single Oven
What does it mean when a gas cooker needs hardwiring
It means that it does not have a cord and a plug to just plug it into a wall socket...
It needs to be "hardwired" into the electrical circuit with a regular piece of wire...
heatman101
Dec 13, 2010 | New World G60m Gas Single Oven
We dont have a manual for the cooker and dont know how to turn the fan of.
Any reply to this please? I too have no manuel for the G60.
Oven light broken, not sure how to remove and replace
Thank you
Dec 01, 2010 | New World G60m Gas Single Oven
Gas mark nob not having any effect on gas levels in the oven seems like it is on its highest setting all the time? Also the ignition keeps clicking away all the time could this be a s/c on the wire from...
Time to change the thermostat. the cap tube sounds like it has been broken. If it has a temp control board, change the temp probe. The clicking sound, if unit is equiped with an ignition control modual, is bad, (not shutting off after sensing pilot) or sensor rod is dirty.
Dec 23, 2009 | New World G60m Gas Single Oven
New world tgo 70 grill
I have a TGO 70 for sale in Doncaster
Aug 14, 2008 | New World G60m Gas Single Oven
New World G70m Gas Double Oven Logo
73 people viewed this question
Top New World Ovens Experts
Paul Carew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
