Question about SanDisk Sansa Clip MP3 Player
Half of my space is taken up by nothing.
I deleted all the files from my 2g SanClip, installed the driver update and re-formatted, but I can't clear my SanClip.
The clip says it's empty, my media player says there are no items on the device, but when I put it in the media player to sync, all I have is 743 mb-- less than half of the space- remaining. What do I do?!?!?!
  • 1 more comment
  • melboney Nov 12, 2008
    I figured it out. I reformatted the device itself, it seems to be working OK now.
  • chayaleiba Nov 13, 2008
    I have the same problem, and reformatting the device did not solve it. Any advice, please?
  • lula303 Dec 11, 2008
    Same problem and tried to reformat.... Nothing is working!!!!!!!!!! I use to have over 300 songs and then I tried to delete them so I can refresh with all newer stuff and it will only hold 80 songs!!!!! HELP ME PLEASE!!!
  • 3 Answers
Installed
Posted on Nov 12, 2008
I tried deleting everything from my memory stick becaues there is not enough space for my file, but after deleting it, I still dont have enough space, it keeps saying the avaliable space is 270MB even tho...
Try to format the drive from your computer, instead of just erasing it. Also, memory cards do go bad too.....some times quite easily.
The good news is they are VERY inexpensive now of days if you do need to replace it.
Dec 22, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
It is stating that the memory is full when it is not.. I go to each folder and nothing is there
I had my Pockettrax CX saying "Memory Full" although I'd deleted everything. What helped finally: I formatted the SD. Now I've got all the memory back. Don't know if that would help the recording speed. but maybe. IMPORTANT: SAVE ANY FILES on your LAPTOP before formatting the SD.Here's how to format the SD:Go to Menu.Click on "Common Menu"Scroll down until you get to "Format"Press "Yes""Formatting SD" comes up and, VoilaYou've got more space.
Sep 10, 2010 | Yamaha POCKETRAK 2G Pocket Stereo Recorder
There's a virus in my asus eee pc 2G surf and hard to connect to the internet. is it better to reformat it? How?
Check Two Solution:
Install Antivirus - Install new Symentec Antivirus Updated copy, and scan all Internet file, folder & Computer.
If problem presists - then format your Notbook or only your Notebook 'C' Drive
To format -
Windows XP installation:
1. Restart your notebook - and immedietly click on F2 key/Del button
2. Boot your computer from CD Drive
3. save your setting
4. it Running System File.
5. Then Create partition press Enter-(Delete previous partition)-press 'L'to delete your 'C' partition, If you want delete all partition, same delete like C drive.
6. Select 'C' Drive press enter to format partition choose option NTFS or Fat32, and Enter
7. It's running automatically then enter operation system windows CD Key and press enter
8. It will take time 30 to 35 min. Depending upon your RAM speed.
9. It will complete automatically and PC restart.
Feb 01, 2010 | ASUS Eee PC 2G Surf Notebook
I have nokia n73. there is a problem in its use. whenever i use it , it gives the message of memory full and asks me to delete some data. please tell me some solution.
The phone's internal memory and memory card may be running out of space. Try to delete unnecessary files and free some memory space. Go to Menu>Tools>File Manager. Select the folder or file you want to delete and scroll left or right to switch from the phone's internal memory to the memory card.
Format the memory card and the phone's internal memory if the problem is not resolved above. But it will erase all saved data on both memory.
Memory Card Formatting Procedure
  1. Go to MENU > TOOLS > MEMORY.
  2. On the memory card menu press OPTIONS.
  3. Scroll to Format memory card.
  4. Press Select.
  5. Select Yes
  6. Once the formatting is complete, remove the memory card.
Phone Memory Formatting Procedure
  1. On your phone dial *#7370#.
  2. Press Yes then enter your phone lock code. Default code is 12345.
  3. Formatting is complete when the phone restarts. Insert the memory card and format it again.
Jan 15, 2010 | Nokia N73 Cellular Phone
My sansa sanclip just froze.iit was charging and
Hi.
You have two Solutions.
Solution 1:
Resetting the player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
Solution 2:
Updating the Sansa Clip Firmawre:
  1. If it's not installed yet, download and install the Sansa Firmware Updater.
  2. Connect your Sansa Clip to the computer.
3.1. Assuming there's a new firmware available, the following message will appear on your lower right task bar. Click on the balloon message:
3.2. 3b. OPTIONAL: You can also manually run the SansaUpdater from your programs files. Most likely it will be under All Programs > SanDisk > Sansa Updater > Sansa Updater.
4. Select the Firmware check box.
5. Click Download Now. Firmware downloads and updating starts.
6. Click Finish after the firmware has been downloaded.
7. Disconnect your Sansa Clip from the computer.
8. A "Firmware upgrade in progress" message will appear on the Sansa Clip's display screen. The device will turn itself off after the firmware is updated.
Additional Help:
Sansa Clip Manual Guide.
If you need any Further Help Just don't Hesitate Asking me.
Thank You For Using Fixya.
Good Luck.
Nov 03, 2009 | SanDisk Sansa Clip MP3 Player
Phone Memory Critical
actually the official ROM is bulky and take too much space in useless programs and this results in short space available thats why i always suggest usin gCOOKED ROM without useless stuff in it and it gives u more space in device memory may be 130 MB or more
for now pls reset ur device like this
while phone is OFF
press SEND and END both buttons while pressing them press Start button on top until u see a screen to format the device that will erase all data warning
after this kindly update ur ROM from here
http://www.samsungmobile.com/support/omnia/index.jsp
and in future kindly when u install programs install them in ur other big partition never install stuff in DEVICE MEMORY install in storage memory when asked during installation
it might be a software bug and will be removed in latest update kindly go to the above link feed ur phone details and downlaod the drivers and ROM update for ur device and then simply connect ur phone thru usb cable provided and then follow the instructions u can ask me for more detailed instructions i am expert in this
i would suggest using a COOKED ROM with only useful stuff and leaving the rest with more free space u can asl me where to get this ROM for Omnia
May 19, 2009 | T-Mobile Samsung SGH-i900 OMNIA mit 16GB...
I need to recover deleted memory
Try re-installing the drivers or updating it online :)
Apr 27, 2009 | SanDisk Sansa E280 MP3 Player
The 2g kingston micro sd card fails to format in samsung muse phone. It start and then say format failed. I can put it in my computer and transfer information and then retrive it but my phone says nothing...
I have the same problem to beginning with. The new 2GB SD Micro card/with adapter didn't work at all. It didn't see it by window explorer. Others older once did work properly. Make sure you update your SD card reader driver to the latest version. It should be work. My did after updated the card reader driver.
Or update your all in once card reader if you have one.
Good Luck
Flyfox........
Feb 28, 2009 | Samsung Cell Phones
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
SanDisk Sansa Clip MP3 Player Logo
104 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
