The smart wash cycle quit working, and then during the normal wash cycle, the cancel drain light will come on but it keeps washing and doesn't drain until the wash cycle is completed. Yesterday, it quit working all together, When you push the normal wash button, the Dry Heat light comes on too, but it can't be cancelled.
Sound like you have a bad control console, which will need to be replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
SOURCE: kenmore dishwasher 665 15752 wont cycle right
- To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
SOURCE: Stuck on wash cycle
Do you set your cycles by a manual timer or do you have a digital display?If a timer then it most likley bad or its stuck---if thats the case try wd40 behind it and see if it loosens,If your unit is digital then the control board is most likley bad,let me know.
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
SOURCE: Kenmore Dishwasher won't drain
If you opened and closed the door and it started, that sounds like a bad, door switch in the console.
But you did hear a hum sound when it tryed to drain, it could be the drain solenoid, or the motor/pump assembly.
Take off the bottom access and look at the solenoid when it starts to drain, the piston in the solenoid should move freely, up and down with the white drain flapper that it connects to.
Also check for bad wiring connections at the power junction box where the power hooks up to it under the dishwasher, i have seen the wire nuts either come loose or burn off due to loose connections.
It was the key pad that was faulty, thanks to everyone for the suggestion!!! This dishwasher is only 4 years old and this is it's third key pad. Ironically, the first two lasted exactly 2 years each!! I have bought Sears products for over 40 years. I have a house full of Sears appliances and products. I have a garage full of Craftsman tools plus lawn mowers and yard tools. This will be my last Sears purchase!! There products are no longer a quality product. Goodbye Sears!!!!
