Question about Fuji FinePix Z10fd Digital Camera
Battery in wrong way
I put battery in my camera wrong managed to get it out with difficulty put it in right way now camera not working is it likely i have damaged the camera or just the battery
  • Prettyladiie Nov 20, 2008
    I have the same problem. i out my battery in the wrong way and now its stuck. idk what to do...?
  • northmill Nov 27, 2008
    Same thing here. I bought a new battery. The problem is not fixed. Does anyone know what the warranty on these is?
    Novelist:
  • 208 Answers
HATE TO BRING BAD NEWS, BUT THERE IS THIS THING CALLED REVERSE POLARITY. THAT IS WHEN YOU PUT THE BATTERY IN WRONG AND THE CURRENT GOES INTO THE CAMERA THE WRONG WAY AND POOF! ELECTRONICS GET FRIED! THEY ARE VERY SENSITIVE AND THEY USUALLY CAN'T WITHSTAND SOMETHING LIKE THIS. IF YOU HAVE TRIED A NEW BATTERY AND IT STILL DOESN'T WORK, COST OF REPAIRS WOULD BE MORE THAN WHAT YOU PAID FOR THE CAMERA. ALSO, DOING THAT TO A BATTERY WILL KILL IT TO OR CAUSE A FIRE, SO YOU PROBABLY WERE LUCKY TO GET IT OUT OR THAT SOMETHING ELSE FRIED FIRST, BEFORE YOU HAD A MELTDOWN. MOST CAMERAS ON UP THE LINE FROM THIS ONE HAVE SOME WAY TO BLOCK THE BATTERY FROM GOING IN WRONG. THEY HAVE A CURVED SIDE OR SOMETHING THAT WILL ONLY LET IT GO IN ONE WAY. POINT TO REMEMBER WHEN YOU LOOK AT CAMERAS. SORRY FOR THE BAD NEWS, BUT IT WILL SAVE YOU MONEY IN THE LONG RUN,ESPECIALLY IF SOME REPAIR SHOP GOT HOLD OF IT AND DROPPED A $150.00 REPAIR BILL ON YOU.
Posted on Dec 18, 2008
Why will my Samsung ES74. not charge
Several things can be wrong. The battery, the camera, the connection cord and the charger.
If you can measure the voltage of the battery, with a multimeter, try that. The voltage should be e bit more than what is printed on the battery. I think it should read 3,7 Volt. So the be sure the battery is still in working order, check if the multimeter gives about 3,8 or more. (after charging). Then the camera, If there is dirt on the contacts, or you managed to put in the battery the wrong way around, it won't work. Then the charger could be defect, or have bad contacts. Or the cord could be defect. Check all parts, if they are still clean, shiny, and nothing is bent.
The charger light should come on. If it does not, toy already have the culprit.
Success while checking.
May 20, 2014 | Cameras
My Panasonic Lumix DMC-FZ28 will not power on, although the battery has been charged.
More than one possibility can cause this. Your battery can be on the end of life. Only when the battery works in another camera, of the same model, you can check the capacity. Or with a multimeter, but you must have some electronic skills. Then the contacts on both the battery and in the camera can be dirty or oxidised. Sometimes users manage to put in a battery the wrong way around. This should be virtually impossible with your camera. Try cleaning the contacts in the camera and on the battery, using some cotton swabs. Never use anything sharp.
Then again try charging the battery. Look if the charger light starts green. And is it stops after some time. If you already charged the battery, it could be the light goes out after a few minutes.
If the charger light starts flashing, you know something is wrong with the battery to the connectors. Don't forget to close the battery cover correct. There is a switch, and if the door is not locked correct this switch still indicates open battery door and the camera won't switch on. Check your manual page 17 and 18.
Apr 17, 2014 | Panasonic Lumix DMC-FZ28 Digital Camera
Nikon S6500 will not turn on
Could be the camera, but always first check the contacts from the battery and in the camera. Just to be sure nothing can block a free current. The contacts should be clean and shiny. Not a spec of dust is allowed in the battery holder. If you should need to clean the contacts, only use a dry cloth. Never use a sharp tool in or close to a camera. Then make sure you put in the battery the correct way. I don't know how strong you are, but sometimes people manage to put the battery in the wrong way around. Make sure the battery-camber / Memory card slot cover is closed correct. There is a little switch that indicates if the door is open or closed.
Almost impossible two batteries are dead at the same time. Unless you left them lying for a long time.
When you think everything must be right, just press the power switch several times in a row.
If nothing helps, I guess contact to a Nikon service station, or a new camera?
Jan 30, 2014 | Nikon CoolPix S6500 Red Digital Camera 16...
Canon Powershot A710 IS dont want to turn on. I change the batteries but nothing happens. Yesterday everything was normal. Any ideas?
When this happened after you charged the battery, a few things can be wrong. The worst that could happen, is the battery did not survive the charging session. Other things:
You managed to put the battery in, but the wrong side around. Almost impossible, but I don't know how strong you are.
There is a bit of dust in the battery compartment. Just a little piece of paper can be enough to block the current.
The battery door / cover, is not closed correct. Every battery cover has a switch that is needed to inform the camera that the cover is locked. When the switch does not work, the camera won't switch on.
So my advice: remove the battery, Look if all contacts are clean and shiny. On the battery and in the camera. Check if the battery is really charged, by placing it again on the charger.
After reinserting the battery, check is the battery cover is closed correct.
Jan 27, 2014 | Canon PowerShot Cameras
My camera wont turn on or work even after i put brand new batteries in it... whats wrong with it???
If your batteries did not leak at all, and corrode th points where the. Batteries make contact, then it could be something very serious on the main board, or something simple like the on/off switch. Really it's the sort of problem that needs to be seen by someone. I'd check the battery connections first, then make absolutely sure the batteries are going in the right way around. Flat end is - and pointed tip end is +. Good luck
Nov 24, 2013 | Jazz JDC27 Digital Camera
Batteries in camera get hot
have you tried other batterys
Aug 20, 2012 | Cameras
No work internet camera
the camera has no driver or it is damaged or it is just disabled..Go to device manager first and see what is wrong with it ..To go there select right click on computer and after that properties and device manager .. In the list look for the camera ..and see if it has the driver installed ..If it is just disabled..click right on it ..and enable ..and will work ..if it appears in yellow with exclamation sign ..it means the driver is missing or the wrong one is installed and you have to reinstall it ..try to do that from the recovery partition ..or in the list of device manager ..click right and update driver ..If the driver is still in the system it will install and work proper..
If you have a disk with drivers..just insert it and run the camera driver ..or get it from the support site .
Oct 01, 2011 | Acer Aspire Z5700 PC Desktop
Casio Exilim EXZ70 battery not charging
the battery you have may not be pushed into the camera far enough. Try putting a small piece of paper in there to push it in. If that doesn't work then the new battery would be the best option
Feb 05, 2009 | Casio Exilim EX-S880 Digital Camera
Fugi Z10
buy a new battery matee, i did the same thing, i bought a replacement battery on ebay, works a treat and im guessing half the rice of what you would buy in stores. good luck!
Jul 19, 2008 | Fuji FinePix Z10fd Digital Camera
Fuji FinePix Z10fd Digital Camera Logo
278 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
