Service/maintenance error on Epson Stylus Photo 220
Hi Inky
just found this site in a search for help with my Epson printer and I see that it is suggested that ink pads/tank are cleaned/replaced and counter reset with a bit of software -- this sounds like good news and a lot cheaper than running out and buying a new printer!
Please could you clarify for me whether it is pads or tank in this model as I have come across 2 different links offering slightly different solutions to the problem on this site, one from an Ebay seller of tanks and one with just a bit of software -- I'd like to make the right choice straight off ;)
Many thanks for you time
Sam
  • SamJE Nov 18, 2008
    Thank you very much for getting back to me - I'll try that and let you know how I get one.
    I appreciate your help :)
    Sam
  • 691 Answers
The best solution is to reset the counter and then clean the ink pads. ONLY AFTER RESETTING THE COUNTER is a tank of ANY use. Fitting a tank WILL NOT FIX THE ERROR.
The ONLY solution I have found that you can buy on the internet to fix the error that says something like "parts inside your printer have reached the end of their life" is the solution in the link below. There are other solutions available such a thing called the SSC Utility, but I know there are reports that the SSC Utility can write bad information to the firmware and thus wreck the printer. The solution in the link below is the nearest you can get to a guaranteed safe solution:
http://www.tradebit.com/filedetail.php/816315-Documents-eBooks-Technical
If after using the above fix for the R220, you wish to add a waste ink tank, then feel free. However fitting a waste ink tank WILL NOT STOP THE ERROR coming up again. The error is caused by the firmware in the printer counting the amount of ink used and pumped into the waste ink pads in the base of the printer. Even if the ink is pumped into a tank instead of the waste ink pads, the counter still counts the ink. The ONLY THING YOU SAVE with a tank is replacing or cleaning the pads. In my opinion, the tank is waste of money. You can easily rinse the pads out all you have to do is get to them. You can also make your own tank from a small empty jar and length of tubing available from an aquarium store.
Posted on Nov 18, 2008
Hi. Reusing my old Epson Color (photo) Stylus 870 after a period of non-use; took it to work to use with my work laptop. Plug and play found and installed the drivers instantly. Bought new cartridges...
normally you will need to let the printer know that you have preformed any maintenance on it by clearing the error count after such an error occurs and is fixed it is normally listed under general or service options on the printer menu but you may need to look through the users manual
hope this helps
Robb
Oct 27, 2010 | Epson Stylus Photo 870 InkJet Printer
Reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
May 12, 2009 | Epson Stylus Photo 1400 Printer
For epson stylus photo r300
Hi Anna,
After doing some searching, this was the best I could come up with:
Turn off printer
Press and hold 'stop' 'maintenance' and 'power' buttons for about 10 seconds. A message will appear on the screen. power off and back on for reset
Allegedly, this is a pre-set maintenance routine epson implements as a service reminder...though I could not confirm this one way or another. I hope this works for you, as the epson website seemed to be utterly useless in finding a suitable resolution.
Good Luck,
Jem
Jan 04, 2009 | Epson Stylus Photo R300 InkJet Printer
Owners manual
Hi-
Go to support.epson.com and choose your printer under inkjet or go to www.epson.com then select north america then USA then drivers and support, select printer and go to documents and manuals.
Hope this helps
Sep 01, 2008 | Epson Stylus Photo R220 InkJet Printer
Ink not empty
You have confused the software in either changing a cartridge when not required or having a chip failure whilst changing multiple cartridges.
Full info on how to get out of this is on my site.
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus CX6400- Error
This worked me:
Manual reset for Epson CX6400
  1. Turn off the printer.
  2. Press and hold B/W+COLOR+STOP button.
  3. Press and release the power button.
  4. Release the B/W+COLOR+STOP buttons. (My screen said "Init EEPROM")
  5. Press COLOR button to clear protection counter.
  6. Turn off the printer by pressing power button.
Found this solution here: http://tricks-collections.com/resetter-epson-stylus-cx6500/
Jan 01, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Epson stylus photo heeds reset on mac
Hi, this means your printer needs a maintenance service from epson, ie the printer has met its end of life unless you want to pay epson £75+vat for the maintenance call.
Happy New Year
John
Dec 30, 2007 | Epson Stylus Photo R220 InkJet Printer
424 people viewed this question
jasbo
jasbo
