Question about Maytag MDG2706A Gas Dryer
Dryer gives off a strong odor which make my clothes smell.
I have the Legacy Series dryer. All of the sudden the dryers stinks while it's running and it makes my clothes smell like something burnt. . I tried cleaning the vent which goes outside and it's still a problem. The dryer still heats up fine although the longer it's used the stronger the smell. It kinda smells like kerosene.
  • Anonymous Mar 12, 2014
    my clothes smell fresh until I put them in the dryer then they come out smelling like body oder from my husbands work clothes any way to fix this problem without throwing it out?
  • 61 Answers
If you have been painting or staining recentley the chemicals in these products are mixing with the mercaptin in the gas to cause the odour. The problem will correct itself when the fumes are gone.
Posted on Dec 18, 2008
Odor
if you have a bad odor,pull off the vent line from the back and see if an animal is dead there,i've found dead birds,mice and a possum,in the blower wheel of some dryers,they get in from the outside hood,once they get into the vent line and slide down they can't climb back out or if the dryer is running the wheel does a job on them.also if you had some painting or staining done this also can make the dryer smell bad.this is going by what i've found when someone complains about an odor in the dryer.hope this helps,one more thing if the motor is overheating from the dryer not being cleaned out it could have like a shellac smell,you might have to take the dryer apart to see what's stinking or it could be something near the dryer,when the air is heated in the dryer it makes the smell worse but if you find waht is causing it and remove it the smell will go away,if it is from a dead animal you can wash down the area with soapy water,you don't want to use anything with a strong smell because your clothes will smell of that when the dryer heats up.what does it smell like?
Apr 13, 2013 | Maytag Atlantis MDE6400AY Electric Dryer
Odor
If you don't clean out the lint trap frequently, your dryer may have small lint fires inside the cabinet. The smell from these fires can leave a strong odor in the clothes drum.Also, if there are any solvents, paints, lacquers, etc. in use in the house, your dryer may alter and/or amplify the fumes to an odor unlike the natural fumes given by the solvent, paint, etc.
Here's what to do:
  1. First, clean all of the lint from the inside cabinet and ductwork of your dryer.
  2. Move all containers of flammable liquids at least 50 feet away from the dryer.
  3. Then, try to clear the odor, by running a couple of loads of old rags or towels.
Apr 22, 2010 | Whirlpool LER4634J Electric Dryer
My portable haier dryer (HLP140E) has a bad odor. I got it brand new from Walmart. It was happening with the portable washer (Haier HLP21E) too but that has seem to have faded. I've used the dryer a few...
No any smell coming from a dryer is not "normal," no matter what anyone tries to tell you. I would seek a replacement model immediately. You are not the first to complain about this model. Likewise, I would seriously consider a replacement for the washer as well, even though the smell has diminished. I hope this helps and good luck!
Nov 11, 2009 | Haier HLP140E Electric Portable Dryer
Washing machine stinks
do the clothes stink too? or just the washer? if you have a crawl space check the washer drain it could be draining under the house...and vapors coming up through line......
Nov 08, 2009 | Kenmore Elite HE4 Electric Dryer
Strong odor coming from dryer
Usually when there is a strong heat (burn) smell from the heat element, it is telling you that there is poor air flow. This has nothing to do with the model. It is a blocked or restricted vent line, or an internal blower wheel malfunction or a lint blockage further in the machine that is restricting the air flow. WHEN AIR MOVES CORRECTLY, THE ELEMENT HEATS NORMALLY AND DOES NOT GIVE ANY OVERHEAT ODER.
Oct 11, 2009 | Kenmore 63942 Dryer
My dryer makes my clothes stink
You NEED to have a professional vent company clean your dryer out! PLEASE don't run your dryer when you're alseep or not at home due to a fire hazard! It sounds like the dryer is full of lint that's buring and make sure you clean your lint filter EVERY time you dry a load for safety's sake and energy efficiency.
Aug 14, 2009 | Dryers
After drying, clothes have a soured smell. I really don't think its the washer because there is not a smell there. However, I have run just bleach several times through the washer and have tried candles...
Questions
Gas or Electric dryer?
Is the odor there even when not running?
Have you recently done any painting or stain/shellac in the house recently? Home perms?
Gas dryers will often give clothing a kerosene like odor if the above conditions have occurred. Any sprays or aerosols can have the same effect. Unfortunately only removal of the culprits and time will alleviate this.
Jun 08, 2009 | Whirlpool Dryers
Odor from Maytag dryer
Have you cleaned your vent lately? It might be excessively outgassing an ammonia smell because some plastic part that is getting too hot. If the vent is making it run hot or not exhausting it might stink up the room. Otherwise, it might just be stinky plastic. I don't know anything about your specific model, but I had a bread maker that was the source of a garlic & ****-like ammonia smell on the top cover after the plastic turned yellow from heat & age. Not a good feature for something that makes food and lives in the kitchen.
May 11, 2009 | Maytag PYE2300AY Electric Dryer
Clothes smell......
The following are the methods you can avoid odor in clothes after washing.
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
Good luck.Please do post comments if the problem is still not solved or if there are any doubts in this post.
Jan 20, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Dryer burning smell
Have you painted or stained in your house or apartment recently? The smell gets everywhere, dryer, stove, heating unit. I recently primed with Kilz and the clothes from my dryer smelled burned. When I called for service, it was the first question the service person asked and said they made a lot of useless trips only to find nothing wrong with the appliance. That was my case. I had to rewash clothes and let the dryer run with towels for a while
Jan 22, 2008 | Dryers
Maytag MDG2706A Gas Dryer Logo
1,022 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
