Question about Sony SA-W305 Subwoofer
Terrible distortion from Sony Dav-x10 2.1 subwoofer
I just bought this system barely used from ebay. Seems to work great except the subwoofer gives a terrible buzzing sound whenever the soundtrack gets bass heavy. I haven't found any complaints online and i am wondering if it's just broken. If so, can I fix the problem without making a beef on ebay?
Its not broken just turn the cut off frequency to level and the volume of the sub lil bit higher and it should work fine.
Posted on Aug 20, 2012
5 Suggested Answers
  • 8 Answers
SOURCE: Regarding Sony SA-WM250 Subwoofer
There is probably a bad solder joint or loose wire inside of the sub box. If you can, unplug the sub, take the screws out and remove the back to inspect the circuit board. A clean solder joint is pointed and shiny, with the solder evenly distributed in the hole. Also check to see if any plugs are loose. Plug in the audio input and then the power, but be very carefull not to touch anything inside the box while the cord is plugged in!! Play some bass at moderate volume so there is pretty constant sound. Now, take a screwdriver with an insulated handle and gently tap around on the connectors and circuit board. Tap a little harder if nothing happens, also tap in different areas to try to force the sound to cut out. You can try to locate where the bad connection may be by tapping lightly and zeroing in on the location. When and if you find the problem, you will need to solder the connection with a soldering iron. If you don't have a friend to help, try a local electronics store. Good luck!
Posted on Jul 13, 2007
  • 227 Answers
SOURCE: can i hook up my SA-WM20 subwoofer to my sony
As long as your sony reciever has a sub out connection you should be able too. This powered sub you have has a rca sub input which should coincide with the receivers rca sub out.
Posted on Aug 04, 2009
  • 26 Answers
SOURCE: why is the subwoofer making a buzzing sound? Is there a solution?
I have had the same problem with my Sony sub. It sounds like it is picking up electrical noise and would not go into standby when the reciever was off. I rerouted my wires and changed to a much higher quality wire. I was using a very low quality stranded copper with thin insulation to start with.
Posted on Jun 15, 2010
  • 19 Answers
SOURCE: the subwoofer just quit working
if the light still comes on then the fuse is still good....
a possiblity exists that either the amplifier or the actual speaker itself went bad....if you like you can dissasemble the the subwoofer to access the insides....a simple test....if you connect the driver to another amp (any amp will do as this is just a test) and it makes sound then chances are your amp is bad or just a loose connection.
Posted on Oct 28, 2010
Lost remote
check the following links for you answer
http://www.ebay.co.uk/itm/Replacement-Remote-Control-For-Sony-DAV-SC5-/271034128605?pt=UK_AudioTVElectronics_Video_RemoteControls&hash=item3f1ae498dd
http://www.ebay.co.uk/itm/Universal-Remote-Control-to-DVD-SONY-DAV-SC5-easy-to-use-TV-/110829587705?pt=UK_AudioTVElectronics_Video_RemoteControls&hash=item19cdf54cf9
http://www.ebay.co.uk/sch/i.html?_trksid=p5360.m570.l1313&_nkw=Sony+DAV-SC5&_sacat=0&_from=R40
if this does not help then no matter what you can always get a new one from SONY
ALSO PS*** check in your owners manual for info on how to program your new remote to work with your system
if you no longer have owners manual then follow this link
http://www.manualslib.com/manual/247682/Sony-Dav-Sc5-Instruction-Operation-Manual.html
Oct 20, 2012 | Sony DAV-SC5 System
Hi all, I hope someone out there can help me. Recently bought a new Samsung 46" LCD, I also have a Samsung BluRay player and HD Recorder in one, also have a PS3 and finally the Sony DAV-IS10. ...
It's unclear where the sound is emanating or where it is lost in this scenario or even the type of connection you're using to carry it.
It almost sounds like you're using the TV for sound or it's in the audio path. The sound from any high end source should be processed by the SONY DAV as close to its original device as possible and not unnecessarily patched through the TV.
The TV only NEEDS Video. High-end Audio is wasted on it.
The symptom sounds suspiciously like a loss of data from the source to the Sony DAV.
Please clarify or establish that this does or does not happen without using the remote. Sometimes remote commands are heeded by unintended devices. Try to Pause/Play sequence using front panel buttons on the unidentified Samsung BluRay to eliminate that possibility.
http://www.retrevo.com/support/Sony-DAV-IS10-Home-Theater-Systems-manual/id/2771ag604/t/2/
Observe the indicators on the Sony for any clues when the problem occurs.
Sep 24, 2011 | Sony DAV-IS10 System
The DAV S300 system I have is almost 10 years old. And I have changed the lens once before. Now it's again giving me a 'no disc' error whenever I insert any disc. Instead of changing the lens...
You're not likely to find a non-boxed-set control center amp that can safely drive 3-ohm speakers like yours.
HTIB's aren't meant to mix and match with anything. Proprietary speaker connections instead of stripped bare wire are a tip-off.
If you really like the speakers you could troll the auction sites for a new central unit.
Jul 07, 2011 | Sony DAV-S300 System
I have a Sony DAV S500 AV system and with certain DVD and with the volumn just over 20 (not really that loud), the system shuts down and PROTECT shows in the message window. I read somewhere on the web...
If the subwoofer and other speakers were included with the system, THAT is what they're designed for. Mixing and matching with other products is usually discouraged if not forbidden.
http://audio.manualsonline.com/search.html?q=Sony+DAV-S500
If the problem returns with connection of the sub it may be defective or on its way out. Internal damage to the voice coil from being overdriven could have melted or worn through the insulation and it would cause intermittent undesired electrical contact or load variation under certain conditions, like high volumes.
If your speaker level settings are unusually boosted for the sub you may be overdriving it.
Feb 07, 2011 | Sony DAV-S500 System
I just installed a Denon 1610 A/V. I used my speakers from a older Sony 5.1 channel home theater system (DAV-S300). I got all the speakers to work except for the subwoffer. In order to hook-up the SW, I...
If you go to Manual setup/ select speaker setup/ select bass setting/ does it show LFE? If it does it is sending to main speakers only and you'll need to change to LFE+Main.
Oct 20, 2009 | JBL SCS135 System
DAV-DZ260 + KDL-32V4000 - no audio from TV to DAV via HDMI
Check DAV amp menu and select DTS surround or any other digital sound option.
Jun 15, 2009 | Sony Audio Players & Recorders
Sony-DG820 Subwoofer
The powered subwoofer should be connected to the black subwoofer output near the bottom of the receiver in just about the center. A subwoofer uses line level signals and has its own amplifier, Good chance that you wiped out a channel. Put the wiring back the way it was, and IF the channel was not directly connected to the speaker terminals, MAYBE, JUST MAYBE it will still work.
Chances are slim...
Apr 27, 2017 | Sony STR-DG820 Receiver
Picture distortion. Sound fine
Dont worry andysenny, Just give your dvd player for general service, these small problems will be rectified.
Feb 10, 2008 | Sony DAV-SC8 System
Problem playing CDs
did you put the firmware update, perhaps it can solve the problem
Nov 11, 2007 | Sony DAV-DZ100 System
Sony SA-W305 Subwoofer Logo
134 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
