Rank: Guide
Rating: 86%, 245 votes
Before any proposal can you do following:
Golden rule: first use eyes and ears
- unplug your washer, and open it; try to detect any water leak trace ; start at water supply, verify also the dispenser, centre of the drum and rubber tube between pump and drum
Any cause of water leak must be avoided.If you see the problem in this stage, repair what is wrong and leave the washer some time to dry up. Try again.If you can't see anything particular do following:
- switch to spin cycle; switch on current and listen - do you hear the pump ?
- sequentially, the drum motor should turn on and start spinning, if this sound normal the tacho is most probably is OK
- simultaneaously, try to detect water leaks.
Let us know what you heard and/or saw, so we can get closer to the point.- after ending the spin cycle, unplug your washer, and open it; try to detect any water leak trace ; start at water supply, verify also the dispenser, centre of the centrum and rubber tube between
pump and drum
Comments:
Nov 12, 2006
- I twice sent a comment with a photo, apparently the post didn't go out. I'll try again on Monday Nov 13th.
