Question about Toshiba Satellite A100-S8111TD Notebook
Clock system getting to late
Does Toshiba laptops have a battery to keep running the clock?
My computer shows a very late hour
  • Toshiba Master
  • 32,281 Answers
Yes, this battery maintains the laptop BIOS information including the date and time. If the time slows down it indicates the battery is nearly flat and needs replacing.
Posted on Nov 12, 2008
Rtc battery is low or cmos checksum is inconsistent
The RTC battery is a rechargeable Li-ion "clock" battery that's buried underneath the keyboard - it keeps date and time going when your computer is turned off. If you're getting this message, you should go follow the screen prompt, hit F1 to enter Setup, and set the date and time, leave the computer on for several hours to charge it (the clock battery recharges only with the computer turned on) and it should go away.
In the rare event that your RTC battery is bad, it's really up to you as to getting it replaced or not - it's a lotta work, and not all the battery vendors out there is competent enough to sell you the right kind of battery (installing a non-rechargeable Lithium battery will kill the thing outright, and there are actually people selling these....). Not having a working RTC battery doesn't really interfere with the workings of the computer - you'll just have to set date and time every time you start it, and you can do so manually or by downloading some freeware such as Atomic Clock Sync to automatically do it for you.
Sep 19, 2011 | Toshiba Satellite A45-S151 Notebook
My Toshiba Satellite M105-S3004 PC Notebook screen is not showing??? it shows up when I flip open the screen and goes off???? how do i fix this
We ran a typical Toshiba PA3465U-1BRS battery of tests, including games, applications, and a couple other areas. Time constraints limited the amount of testing we could get done before the NDA lift (and it's already a few hours late), but we will be providing a follow-up article with further testing and information. That said, if there are any specific areas that you'd like to see tested, feel free to e-mail me or leave a comment.
Aug 17, 2010 | Toshiba Satellite M105-S3004 Notebook
The clock on my laptop keeps setting to zero when I shut down. It seem to happen after a windows update. I'm running vista. Can anyone give me a solution. I have to keep putting the computer to sleep...
It sounds like your CMOS battery is dead. The CMOS battery keeps the date and time current as well as your BIOS settings when power has been turned off to the system. Check your system for the current type of battery your Toshiba uses. It either uses a disc type of battery that sits in a socket, or it has a disc type that is in a covering and attaches to the motherboard via a small cable.
Jul 12, 2010 | Toshiba Computers & Internet
Clock Issue
I would recommend getting your laptop professional cleaned first before trying to replace your battery.
Replacing your battery on laptops is not always an easy task and can require several hours of labor.
Please visit the following link for access to a replacement battery
http://www.google.com/search?num=100&hl=en&safe=off&client=firefox-a&hs=CpO&rls=org.mozilla%3Aen-US%3Aofficial&q=Toshiba+Satellite+M35-S359+cmos+battery&aq=f&aqi=&aql=&oq=&gs_rfai=
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
May 23, 2010 | Toshiba Satellite M35-S359 Notebook
The Toshiba Tecra A8 S8413 laptop cmos battery (or capacitor?) does not seem to be working. Symptoms: I set the date and time. As long as the laptop does not sleep or go into power save mode the clock...
The RTC (Real Time Clock) battery charges when the computer in on (operating). You can plug the electrical cord in and let the computer run for 24 hours by temporarily suspending any sleep mode or automatic power saving features. This should sufficiently charge the RTC battery.
Nov 30, 2009 | Toshiba Tecra A8-S8513 Notebook
My laptop freezes often and clock stops running
i would recommend a fresh install of windows and if that doesn't solve your problem then check that your processor isn't loose and while you check inside the laptop give it a good hoovering to get rid of any dust. i think maybe it freezes because it gets too hot so i would recommend hoovering inside and buying a laptop cooling platform off ebay (fans that the laptop sits on.
Apr 04, 2009 | Toshiba Satellite A135-S2276 Notebook
Laptop Asks for Password Right Away?
can you get on in safe mode
if so then click control panel users accounts
i believe you would click administartor then accounts you can remove windows passwords in there.
hope this helps
safe mode can be accessed by repeatedly hitting f8 as you restart your pc
Jan 15, 2009 | Toshiba Satellite A105 Notebook
I have a e system desktop the clock keeps running late
Computers have an internal battery on the motherboard that helpd the board retain certain data when the computer is off. If the battery is low or dead it will cause this problem. The easiest way to replace the battery is to open the side of the computer when it is off and remove the battery from the battery holder on the motherboard. The battery looks just like a watch battery. Replace it with the same kind of battery (available at most drug stores) once you have replaced it turn on your computer and reset your clock.
Dec 29, 2008 | E-Machines eMachines Desktop PC
Can't switch on a laptop
this may be too late for you, but I had the same problem with my old toshiba laptop. The support person I talked to had me take out the battery, leave the computer plugged in and push and hold the on button for 10 - or 15 seconds. She said it discharges something or other and to periodically run the computer without the battery. Sometimes my screen just goes blank on my new computer and this always fixes the problem.
Good luck.
Sherrie
Nov 11, 2008 | Toshiba Satellite 1905-S301 Notebook
Toshiba A100 Power problems
here are few laptop troubleshooting guide to troubeshoot ur laptop. it has one post about power problem of laptop.
I hope this laptop troubleshooting help to solve ur problem. or chekc ur laptop with another working battry or try to start laptop to without battery. and chekc ur power cable for charging is working or not
May 05, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
127 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
