Yellow spot on the screen
I have a sony KDSR50XBR1 projector tv and I have a yellow spot on the screen the size of a basketball on the right side if your looking at the tv.Is that a lamp problem?
  • 320 Answers
You have a bad optical block. Sony has extended the warranty on your TV so the block will be replaced for free. Go here for more information:
http://ciscdb.sel.sony.com/perl/news-item.pl?news_id=185&mdl=KDSR50XBR1
Be sure to rate this solution! Thanks!
Posted on Nov 11, 2008
  • Any Guy
    Any Guy Nov 11, 2008
    May I ask why you rated this as helpful? I thought I had answered your question completely
Better call a repairman. Ours did that (and so did my sister's) and it turned out it was the optical block which SONY warranted. They must have had trouble with it because they kept extending the warranty on that particular part. Might want to check to see if they still honor it.
Posted on Jun 30, 2009
Green spot and message replace the lamp. New lamp gives same message
Have you gone through the menu, should be on the system tab, and reset the bulb reminder?
Jan 28, 2008 | Sony VPL-CX6 Multimedia Projector
Yellow spot on VPl x1000 Sony projector screen
one of the three polarizers is burned up It can be repaired
Dec 27, 2012 | Office Equipment & Supplies
A yellow line going down the left side of the television
you likely have the "screen size" option set to allow the TV determine the best size (3:4 , 16:9, ...). Set it manually to 16:9 for HD channels or 3:4 for low-def channels.
The line should go away. This is a common problem on Samsung, Sony (Green line right side) and Phillips (yellow line left side).
May 05, 2011 | Philips 50PF7321D 50 in. Plasma HDTV
My TV picture has a yellow color all the time. Even in Black & White. It is Black & Yellow.
sounds like a bad optical block this affected a lot of sony tvs and is a expensive repair try contacting sony they might help.
Feb 03, 2010 | Sony KDSR50XBR1 50" Projection HDTV
Sharp notevision xgnv6xu oval yellow spot
I have a similar issue with yellow pattern on the left and top right of my screen. Took it apart and found the blue lcd had damage that matched the yellow area that was projected. I thought it was the lens but it was the blue lcd .It has gone bad and no replacement. Are you interested in selling the bulb or the whole projector? I have since purchased another projector and am keeping the bad one for spare parts. Hope this helps..Ben
bgrenco@aol.com..
Jan 18, 2009 | Sharp Notevision XG-NV6XU Multimedia...
Hitachi projector model CP X260 projects yellow spot on screen
This is probably the polarizing filter. It will need to be replaced. It should not cost very much to fix.
Jan 07, 2009 | Office Equipment & Supplies
KDS-R50XBR1 has a yellow hue in the lower right hand corner of the screem
Hi JimmyDeps
If there is a yellow hue I would guess that this a LCD TV right ?
Which means that the blue LCD has gone and will have to be replaced.
May 13, 2008 | Sony BRAVIA SXRD HD Home Theater Projector
YELLOW SPOT ON SCREEN
There may be a dust fleck on one of the LCD screens inside your projector. I had a similar problem and managed to clean it. But it requires you to dissassemble the entire projector !!!. If you are not technical, don't do this yourself. !!!
Feb 16, 2008 | Sony VPL CS5 Multimedia Projector
Yellow spots
I have no suggestions but I am having the exact problem, yellow haze in the top right corner of the screen with a yellow line running down to the bottom of the screen. I guess we need to call tech support.
Dec 09, 2006 | Sony KDS-R50XBR1 50" HDTV
Televison & Video Logo
505 people viewed this question
Top Televison & Video Experts
Electro Med Services...
