Question about Air Tools & Compressors
Cant set my compressor to automatic start/stop mode
I have a Ingersoll-Rand SSR-EP100 compressor. I need to set it as a back up. My manual does not give me a step by step way of doing it.
  • ian stalker May 11, 2010
    does your machine have a digital controller
    Scholar:
  • 89 Answers
U NEED TO ADJUST THE PRESSURE SWITCH ON THE BACKUP TO A LOWER PSI. TO COME ON AFTER THE PRIMARY. EXAMPLE: PRESSURE SWITCH ON PRIMARY COMP. SET AT 140-175 PSI AND BACKUP SET AT 135-170 PSI. U CAN USUALLY TURN ONE CENTER SCREW IN THE PRESSURE SWITCH COUNTERCLOCKWISE TO LOWER THE PSI.
Posted on Dec 27, 2008
It depends if it is the old electro Pneumatic control or the more Current Intellisys control. The other recomendation pressure setting is incorrect! EP 100 is a 125 psi rated compressor. DO NOT EXCEED THIS PRESSURE!
IF you want a lead compressor setting Ideal would be cut in 110 psi and cut out would be 125. The "Lag" setting should be 100 psi and the cut out 120 psi. If it is the old Allen Bradley swith on the older style, the top screw is the high or cut out, the bottom is the differential or Cut in. If the compressor has an Intellisys controller, the go into Operator Set Points and set the desired pressure that way
Posted on Feb 13, 2010
I have Ingersoll rand ssr Hp40 SE compressor.. I can't set pressure above 95 psi if it have discharge pressure 143psi..what should I do for set this? If pressure touches 95 psi automatically vavle...
The tank, compressor head, and components need be rated at what you want set the compressor unit pressure to, the safety valve will keep from exceeding the lowest of those limits. If you suspect the safety relief valve needs replacing because it has weakened, then replace the safety valve with one OEM pressure values
Aug 09, 2017 | Ingersoll Rand Air Tools & Compressors
How to change from BAR to PSI on INGERSOLL RAND INTELLISYS CONTROL for INGERSOLL RAND SSR-6-20-125 AIR COMPRESSOR
Ingersolll Rand website support section should be able to provide a manual.
Failing that contact customer services.
Aug 03, 2016 | Ingersoll Rand Air Tools & Compressors
Have a SSR-EP100 air compressor that shows
Try to reset the main motor and fan motor over loads by pushing the reset on the overload it self, Then reset the controller. If the error resets, before starting. put a clamp on amp meter on to L1 or L3 motor lead which is located in the compressor electrical box . Then start and observe amps when unit is making air fully loaded. Once you know how many amps at full load the unit is pulling ,look at the overload setting on main motor overload and see if it is approxmately 10 amps above the max amps being pulled.If not set it about 10 amps above your max load amps.
Nov 26, 2011 | Ingersoll Rand Air Tools & Compressors
Ingersoll Rand SSR EP60 60hp Compressor w/ Intellisys 39817655 controller. Need to reset target pressure. What is the secret button sequence to access programming mode on this controller? I am aware of...
OK, Compressor should be shut down and showing (ready to start) in display. Press load/unload button once then press hidden right button within 3 seconds. This will let you access the set point program. It will include language, temperature and pressure, rated pressure,etc. Make sure you look at the data tag affixed to the unit and see what the rated pressure is for your unit. You can endanger yourself and equipment by over pressurizing the components of the compressor.
May 19, 2011 | Ingersoll Rand Stationary Air Cooled...
Sorry, what do you mean it 'blows off',, the relief valve is letting off pressure ? Sounds like you need to replace it with the proper psi Relief valve or just a new one. Then you say it restarts but in your question you say 'Cant set my compressor to automatic start/stop mode' If it is restarting that means it is automatically 'stopping' then automatically 'starting' Please clarify your question.
Nov 12, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
782 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
