Question about Intel Motherboard
Hp1007 not connecting with my pc
Thiis is pankaj i have a network & share printer but i am unable to connect them from my pc. when i search a network printer then network shows network pc but not share printer
    President:
  • 2,692 Answers
Not enough infor. Type?   HP (model name) (letters?)1007
The solution will be to download the software and updated driver from the HP support website and install the same.
http://welcome.hp.com/country/us/en/support.html
Posted on Jan 18, 2009
Hi i have 2 pc that were connected each other by addhook connection i add one printer to one of them and share printer the other pc can not see that printer
first thing to try is to restart both machines, have a look in network places for the printer, when you click print, click the find printer option and navigate to the network places folder to see if the printer is there. Make sure both machines are on the same workgroup.
May 03, 2011 | Computers & Internet
Unable to find printer sharing for mfc6890 over window xp
To set up printer sharing in your home network, you need to configure printer options in the control panel of Windows XP Operating System. You could get a menu while right clicking the printer icon in the Control Panel. From this, you need to select the sharing option. You also need to make sure that you have enabled printer sharing option in the network card properties. To connect a printer in the network you need to set an IP address for your printer. If you have any troubles with printing with your printer in the network it might due to the errors in the network. So, you need to make sure the network connection.
Apr 06, 2011 | Brother MFC-6890CDW Printer
How to conect a printer
Install a printer on a home network
There are two basic ways to make a printer available to the PCs on your home network:
  • Attach it directly to one computer and share it with all the others on a network.
  • Connect the printer as a stand-alone device on the network itself.
This article explains how to do both in Windows. However, you should always first consult the information that came with your model for specific installation and setup instructions.
Setting up a shared printer
Traditionally, the most common way to make a printer available to a home network has been to connect it to one of the PCs and then tell Windows to share it. This is called a shared printer.
The advantage of sharing a printer is that it works with any USB printer. The downside? The host PC always has to be powered up, otherwise the rest of the network won't be able to access the shared printer.
In previous versions of Windows, setting up a shared printer could sometimes be tricky. But a new home networking feature in Windows 7 called HomeGroup has greatly simplified the process.
When a network is set up as a homegroup, printers and certain files are automatically shared. (To learn more about what homegroups do and how to use them, go to the Windows website and search for "HomeGroup: Recommended links.")
If you've already set up a homegroup and want to access a shared printer from another homegroup PC, just follow these steps:
To manually connect to a homegroup printer
  1. On the computer the printer is physically connected to, click the Start button ?id=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33, click Control Panel, type homegroup in the search box, and then click HomeGroup.
  2. Make sure the Printers check box is selected. (If not, select it, and then click Save changes.)
  3. Go to the computer you want to print from.
  4. Click to open HomeGroup.
  5. Click Install printer.
  6. If you don't already have a driver installed for the printer, click Install driver in the dialog box that appears.
    Note
    • After the printer is installed, you can access it through the Print dialog box in any program, just like a printer that's directly connected to your computer. The computer that the printer is connected to must be turned on to use the printer.
Setting up a network printer
Network printers-devices designed to connect directly to a computer network as a stand-alone device-were once found mostly in large offices. No more.
Printer makers are increasingly offering inexpensive inkjet and laser printers that are designed to serve as network printers on home networks. Network printers have one big advantage over shared printers: they're always available.
There are two common types of network printers: wired and wireless.
  • Wired printers have an Ethernet port, which you connect to your router or hub via an Ethernet cable.
  • Wireless printers typically connect to your home network using Wi-Fi or Bluetooth technology.
Some printers offer both options. The instructions that came with your model should tell you exactly how to install it.
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Devices and Printers.
  2. Click Add a printer.
  3. In the Add Printer wizard, click Add a network, wireless or Bluetooth printer.
  4. In the list of available printers, select the one you want to use, and then click Next.
  5. If prompted, install the printer driver on your computer by clicking Install driver. ?id=18abb370-ac1e-4b6b-b663-e028a75bf05b If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  6. Complete the additional steps in the wizard, and then click Finish.
    Tips
    • Make sure that you have permission to use these printers before adding them to the computer.
    • You can confirm the printer is working by printing a test page. For details, see Print a test page
Feb 14, 2011 | Acer Aspire One PC Notebook
How czn i install my printer so that can network
You first need to check if the printer is compatible with Vista. Then, if it is,Install the printer on one of the machines. Once it has installed, go into printers and right click on the printer itself, then select Sharing or Sharing and Security and allow the printer to be shared. You may have to switch on file and printer sharing before you can share the printer. Then, go onto the other machine and go to install printer. In the dialog window that opens, choose network printer and then search. When the printer appears in the search area, select it and choose install. The system will then download the appropriate drivers from one machine onto the other through the network and install the printer. This assumes that you have both machines connected to your home network and file and printer sharing is turned on, on both machines. To use the printer over the network, the machine the printer is connected too MUST be turned on.
Dec 12, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
I AM UNABLE TO ACCESS INTERNET THRU MY HYBRID APPLE MAC DESK TOP-
Go into network set up a shared Internet connection using ICS (Internet Connection Sharing) You can use Internet Connection Sharing (ICS) to share an Internet connection among two or more computers on a network. First, you need one computer, called the host computer, that is connected to the Internet and that has a separate connection to the other computers on your network. You enable ICS on the Internet connection. The other computers on your network then connect to the host computer, and from there to the Internet through the host computer's shared Internet connection.
If your computer is connected to a network, network policy settings might prevent you from completing these steps.
On the host computer (the computer whose Internet connection you plan to share):
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Network Connections.
  2. Right-click the connection that you want to share, and then click Properties.getcontent.aspx?assetid=18abb370-ac1e-4b6b-b663-e028a75bf05b&documentset=en-us&renderkey=signed1 If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Sharing tab, and then select the Allow other network users to connect through this computer’s Internet connection check box.
Jul 22, 2009 | Computers & Internet
Printer installation
On the computer that the printer is connected to, go into the Printers and Faxes window, RIGHT click on the printer you want to share and select "Sharing...". After you finish going through the printer sharing wizard, go to a different PC and try to add a printer, select network printer. Make sure that the computer that is sharing the printer is on during this process, it sounds strange to have to mention this I know but you would be surprised. I'll check back later to see how things worked out.
Feb 21, 2009 | HP Office Equipment & Supplies
Hp printer 1007
your driver selection is wrong, i guess, select correct driver from list
Oct 20, 2008 | Intel Motherboard
My HP Officejet 6310 All-In-One InkJet Printer is unable to complete the network installation
Are you connecting via usb or ethernet cable?
Through usb you need to install the driver on the pc it is connected to. Then share it.
Through ethernet make sure your CAT5/Ethernet cable is connected from your printer to your router/switch. Through the menu on the printer Print the network setup.
Then from your web browser type
http://ip address of printer from the network setup page
If you can then you need to add the printer driver on your pc and use a tcp/ip port to print to it through the network.
Sep 04, 2008 | HP Computers & Internet
Unable to share printer
you will need two computer connected through rj-45 (internet cable) so its network up, then you will just have to share the printer on that main pc and then the other pc will be able to print to the printer as long as the main printer is turnt on.
Hope this make sense
Jun 04, 2008 | Canon PIXMA Pro9000 InkJet Photo Printer
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
