Question about Polaroid Polaview 211E Multimedia Projector
Vertical control of viewing frame needs adjustment.
Our LCD projector projects an image of the desktop with the top half of the screen at the bottom and the bottom half on the top. I have tried the menu adjustments...but nothing is correcting the problem. I am using the LCD projector with an Apple G4 laptop with correct connections. It has worked in the past...but just started messing up recently. How can I correct this adjustment?
Did you try going into MENU --> PICTURE --> SIGNAL MODE, and then pressing > to go through all the signal modes? On mine, most of the signal modes split the screen weirdly as you described, but one of them (in my case XGA3, but I'm not using a Mac) looks right.
Posted on Mar 09, 2007
Can't get my Viewsonic projector to project an image AND show image on my laptop screen
Hold the FN+CRT/LCD or (it could be an icon/image of a screen) simultanesouly and then keep press the CRT/LCD key it should eventually get around to displaying an image on just the projector or projector and laptop screen
Jun 08, 2010 | ViewSonic PJ500 Multimedia Projector
The image from my cp x251 is uneven the top and right side are angled but the bottom and left side are straight and perfect on the screen.
this is a common problem with projection systems this is the reason that most screens are lined with black felt its non-reflective and works great to hide uneven edges also try balancing out the difference with the keystone adjustment
HitachiTech
Feb 08, 2010 | Hitachi CP-X251 LCD Projector
Image on top half of screen is gone. It seems to
The LCD inside the projection unit is broken - nothing you can do about it - it needs replacing.
They are built in two halves to give you higher resolution and quick image response. One is working, the other is broken. You will need to get it serviced.
Aug 20, 2009 | Televison & Video
Is it my lcd screen or my video card
Please try to connect the laptop to a different monitor or display output like LCD or a projector, in case u find the clear images then the issue is with your LCD otherwise the issue is with your video card. The replacement of the LCD depends on the type of warranty you have.
Jun 20, 2009 | Acer Aspire 5004WLMi Notebook
Images has a blue color across the center
Wow, 3 in a row. As described on 2 other projector issues this is very similar to those others. I'll repeat the info here.
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the blue color has gone out. The image is made up of red, green and blue images layered upon the screen. If the blue panel has gone out then there is nothing filtering out the red light in the image.
It looks like yours has just a secone of the panel dying or comming loose from it's connector.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Mar 14, 2009 | Epson PowerLite® S4 LCD Projector
Image has bend at top of screen
first reset the setting to factory default. if it persists on a regular image too, either the lens, the tunnel or something else in the optical engine is damaged (from a fall?).
Jul 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Sanyo Multimedia Projector PLC-XT25L
Click here to download the user's manual. Go to page # 50 if you are seeing the image on the right side of the screen.
Jul 18, 2008 | Sanyo PLC-XT25L LCD Projector
Toshiba TL-S30 projector, project one half of screen colored blue, one half clear
Is it a problem...or a setting in the projector asking u to check the color settings?
Try the manual fully... Also try the monitor with some analog input (other than PC)
Try to tell me.... whether my suggestion was useful???
Bye
Have a nice day.
Jan 07, 2008 | Sanyo PLV-WF10 Multimedia Projector
The image projected from my CTX EzPro 680 Projector flickers on screen
From my experiences working with projectors, more than likely you will need to replace the lamp
Oct 04, 2007 | CTX Optoma EzPro 680 Multimedia Projector
Polaroid Polaview 211E Multimedia Projector Logo
140 people viewed this question
Top Polaroid Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Andrew Taylor
Andrew Taylor
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
