Question about Hitachi 53UWX10B 53" Rear Projection Television
Have an hitachi 53uwx10ba red light on front is on but no tv
Ok my red light is on not blinking and all the leds inside are on except dp 23 checkd pf 05 06 they are good where do i check next isnt the red light supposed to be off when tv shuts off ?
  • 3 more comments
  • bumos28 Nov 11, 2008
    ok i tried that didnt work all the leds still on except dp23
    is the lights on the board supposed to go out when tv off if so wonder if a relay is bad
    ok i found out why it was stuck pulled board off the case the holds power switch now it turns on and off but dp 23 still isnt comming on no pic or sound im gettin closer need to know what to look at next like i said fp05 tested good
    lights not flashing
    the power light is on when tv powers up no blinking only ld not lit is 23 which monitores voltage so its looing power before there i can hear amp kick in audio but no sound yet
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
On some TVs, the lights do not turn off so that is not that big of a deal.  If you want to make sure, unplug the TV and then push and hold the power button for about 30 sec.  Then plug the TV back in and that should fix the light if it is stuck. (Pushing the power button wile unplugged will reset the system default!)
Posted on Nov 11, 2008
  • JT Features
    JT Features Nov 11, 2008
    it could be that but just to be sure you should contact the company or go to there site. Try http://av.hitachi.com/tv/ and go to the product and try looking for the comments and stuff.
  • JT Features
    OH!  So it's not even working?  WOW ok well...  A flashing light when nothing works means that something inside the TV is broken, something BIG!  CALL THE COMPANY!!!
When I turn the tv on the red lights are flashing then it becomes fixed on the lamp sign keeping its red light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jan 31, 2015 | Hitachi 50V720 Television
Hitachi 53UWX10BA HDTV adjusting color
Hi, Your tv model has a small light blue color button inside for manual adjustmnet mode. You will have to remove the front covering below the screen. its just attached with velcrow. Then there will be a centre wooden pannel with the the switching box screwed to tv front with around six screws.Open this panel and look to the left corner of the chasis boards in front of a small metallic box. Thats the switch you have to press to get into manual adjustment mode. use remote to adjust the colors. once done press it again to exist. Visit www.fixurtvs.com to find out more about tv FAQs. Thanks if you found it helpful.
Apr 29, 2009 | Televison & Video
Hitachi 53uwx10ba turns on & off when off red flashing light/clic
Same problem. Replaced both convergence ICs about 5 months ago. Worked fince since then and just recently no sound, no video, blinking red on front panel and clicking sound. I suspect that the ICs went bad again and blew a resistor or two. I used cheap Chinese ICs instead of the Sanyo ones and thing this is why. I'll be looking at it again and post solution.
Jan 21, 2009 | Hitachi 50SBX78B 50" Rear Projection...
RED BLINKING LIGHT ON HITACHI TV CANNOT TURN ON
Check the resisters, that could be the burnt small, also you may need to replace the ICs
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
My 53WUX10BA Red Power light will not go out
will not power up it worked fine then last week it stoped turning on it just turns off as soon as i turn it on
Oct 29, 2008 | Hitachi 53UWX10B 53" Rear Projection...
DP23 LED not lit on deflection board no picture on tv
Good Day, Gil;
Your problem is in deflection circuit (115+v) check these: FP05, DP15, Q777, QH01, TH01, T701, etc. BUT suspect C707 1k pfd, 2kv, and check all the pico fuses (brown) 2" to the right of cap. Good Luck, big IRISH.
Jul 19, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hello
the clicking is the relay. I would suggest checking the voltage regulators and horizontal output transistors
May 11, 2008 | Hitachi 53UDX10B 53" Rear Projection...
TV popped and now only red light on front blinks.
yes you most likely hurt the audio processor. tv is now going into protect because of the shorted audio driver.
Feb 12, 2008 | Hitachi 53SDX01B 53" Rear Projection...
Help I have no picture, no sound. red light on front, 3 out of 4 green leds inside.
i would first replace the convergance ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Oct 22, 2006 | Hitachi 57SWX20B 57" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
213 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
