Question about NetGear WGR614/WG511 (wgr614nawg511nakit) Wireless
Static IP How do I make the router not detect a static IP address?
    President:
  • 2,961 Answers
Normally a router will assign an ip address in relation to it's own address and not a static address, eg if router address is 192.168.2.1 it will assign your pc as 192.168.2.2. So if you mean you want to change the router to your pc's addresses that you have set yourself, you need to manually alter the routers ip address and dns address to the same as ypur pc's eg if yours are 10.0.0.1 then the router can be 10.0.0.2 or anything as long as first 3 digits are same. If it's not answered then apologies as it's unusual to detect static addresses, normally they are unable and can't see your pc'c.
Posted on Nov 07, 2006
192.168.0.13
77.248.24.119 is the dns from the internet service provider
192.168.0.13 is the router address
Jul 07, 2015 | Computers & Internet
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
What is the ip address
IP address
noun Computers. a code that identifies a computer network or a particular computer or other device on a network, consisting of four numbers separated by periods. See also IP.
http://dictionary.reference.com/browse/IP+address
PS. Free points for newcomers or are you to lazy to google it?
Aug 23, 2013 | Comtrend CT-520 Router
What is ip address
Internet Protocol is also known as Ip address.Every users on internet have their own ip address.Users on internet identify by their ip address.Ip address provided by the internet service provider.There are two types of ip address static,dynamic ip address...
Static Ip address will not change forever ..Even if you reset the modem the static ip address won't change.Static Ip address also known as dedicated ip address..You can use for website..This ip is dedicated for your website only..
Dynamic Ip address :
Dynamic ip address will change whenever you reset the modem.A new ip address will assigned for your connection...You can use dynamic ip address for browsing and normal internet usage....you can use the site Ip-details.com check the ip address whether it is static or dynamic ip address
Jul 24, 2013 | Computers & Internet
I need a static ip address how do i get one
Static IP address should come from them, some of our service providers give paid static P addresses to customer, you can check it from them for they are the one who have control providing ip address either static or dynamic.
Dec 26, 2011 | Cisco Linksys E1000 WirelessN Broadband...
During set up router is asking for static IP address. Why is this question asked?
It should ask you to enter at least one Static IP address. You have to enter the IP address given by your ISP. Without IP address, you'll not be able set up the router. You can assign the DHCP later for the machines which will be connected with the router..
Hope this helps.
Good luck.
Thanks for using FixYa.
Aug 25, 2010 | NetGear N150 / RANGEMAX 150 Router
I can't install a Netgear wgr614vp router - stops in the middle and says, "we have detected a static IP address" - won't let me go any farther
The fact remains, unless Comcast (your ISP) has given you a "static" IP odds are that your IP is in fact NOT static, but dynamic (where your ISP can change your IP at the drop of a hat. I am wondering what the router is detecting to tell it that your IP is in fact static? Comcast OUGHT TO be able to tell you, without getting one of "their" routers, if your IP is static or dynamic. Comcast has this answer, and no onev else, so keep after them.
At any rate, you ought to be able to get to your router control by pointing your browser at http://192.168.1.1 and log in with the following:
User Name: admin
Password: {leave this blank}
Once you've logged in let me know and we'll take small steps to get you online, OK?
Jan 17, 2010 | NetGear WGR614 Wireless Router
I am trying to install the WRT160 N router, but can't install it due to having a Static IP. What should I do? The set up CD is giving the message that the the ethernet cord isn't plugged in. All I am doing...
Do not run the set up disc do it manually.
.You said that you have a static IP.
Is the static IP for the internet service provider or it is on the computer.
If you have set up the static IP on the computer then you will need to remove the static IP address from the computer and set it to obtain IP automatically.
If you have a static IP given by the ISP then you can use it to set up on the router.
Check the Ip address of the computer when connected to the router.
I believe the default gateway will be 192.168.1.1.
open the set up page of the router. default password of the router will be admin. Once you open the set up page of the rotuer, you will find the option Internet connection type. set it to STATIC IP address.
then you will get the option to enter the static IP address given by ISP.
Enter the information and Click save settings at the bottom and you will
be able to go online.
Click Here for More Info
Oct 06, 2009 | Linksys WRT160N Wireless Router
RCA Modem DCM315R
Just a bit of explanation. E0 interface is for inside network (LAN interface). E1 is for outside (ISP or WAN physical interface). Dialer1 is for PPPoE (the "actual"/logical WAN interface). The 1.0.0.13 is ISP provided static IP address for the use of the server. This configuration example is for running FTP server, which uses the standard TCP port 20 and 21.
The LAN uses 10.10.10.0 network with 255.255.255.0 subnet for both servers and workstations. All servers within the LAN use static IP address. The router is configured as DHCP server to give out IP info (IP addresses, subnet mask, DNS) to workstations that are configured as DHCP client.
Basically I suggest that you deploy NAT (Network Address Translation) and PAT (Port Address Translation) to setup your own servers behind Cisco router. The NAT is used to translate the ISP's given static IP address to your local IP address. The PAT is used to translate TCP ports (the port 20 and 21) between the two IP addresses.
When using NAT/PAT, keep in mind that the Internet-accessible servers are seen from the Internet as their NAT/PAT-ed IP address (the Public IP address) and not the local IP address (not the Private IP address). This understanding is very important when you or someone need to test connectivity to the server and/or when you need to create filter (access list or ACL for short) to allow only certain incoming traffic from the Internet and block others.
Side Note:
For more info on NAT/PAT concept, check out the following FAQ
»Cisco Forum FAQ »NAT and PAT; Introduction and Implementations
Instruments used in this illustration are pretty much standard for running your own servers. Please note that IP addresses, username, and password are changed. However, you could always modify the configuration to suit your situation.
This sample configuration assumes that you have a block of IP from ISP. There is a dedicated Public IP address for the router WAN interface (the Dialer1 interface) and another dedicated Public IP address for the server PAT IP address. If you only have a single Public IP address for both router WAN interface and server PAT IP address, there are several ways to configure the router.
One way is to use the same command as shown in sample configuration.
view plaincopy to clipboardprint?
  1. ip nat source static tcp 10.10.10.2 21 1.1.1.14 21 extendable
This one configuration way is suitable when you have static IP address from your ISP and you know exactly what the IP address is. In this case you have the 1.1.1.14 single static IP address for both the WAN interface and Public server IP address.
When you are unsure which IP address you receive from the ISP, or when your Public IP address keep changing; then another way to configure the static PAT is following
  1. ip nat source static tcp 10.10.10.2 21 interface Dialer1 21 extendable
With situation of dynamic IP address, at some point you still need to know the exact Public IP address you receive from your ISP for server connection testing and production time. To find out, you can issue show ip interface brief command on the router. You will then see the associated WAN interface Public IP address.
Feb 25, 2008 | RCA Cable Modem DCM315R (11603540)
Static IP on machine, now can't access web sites
Please see the related article on assigning a static IP address behind the router. If you still can not access websites, please try changing the static IP address you're using. For example if you're using the address 192.168.1.2, try 192.168.1.200. If that does not work please try the same static IP address on a different computer to see if it can use the information. If it can please try reinstalling your network card. If that doesn't work please contact Linksys Technical Support.
Feb 16, 2006 | Linksys WRT51AB Wireless Router
NetGear WGR614/WG511 (wgr614nawg511nakit) Wireless Logo
219 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
