Sony KV-32S42 32" TV
Problem for Sony KV-32S42 32" TV
My sony Trinitron KV-32S42 keeps blinking on and off
By tma615 on Nov 11, 2008
I have a sony Trinitron 32 inch that started recently with the screen blinking on and off. The image itself is fine its just that it keeps cutting on and of every couple of seconds or so
Comments:
Nov 11, 2008
- the model number is KV-32S42
serial number is 8108573
Same Problem
Mar 18, 2009
-   Every few seconds my TV will go to black screen then back to the picture, over and over.-   Guest
Nov 13, 2008
-   I have the same problem with tv blinking on and off it also started in November-time for a new tv or can it be fixed? -   chuyck
Solution #1
posted on Nov 11, 2008
Somewhat Helpful)
Abrsvcs
Rank: Guru  Sony Televisions & Videos  Expert
Rating: 88%, 1821 votes
This can be a symptom of the picture tube starting to fail or a power supply problem. Can you please verify the model number and I'll then be able to give you a few options.
Thanks,
Dan
Comments:
Nov 11, 2008
- Thanks for verifying the model. If you are confortable with this, try the folowing:
Remove the back and locate the flyback transformer (part with large red wire coming out the top).
There should be 2 controls on this part. One will be labeled Focus and the other Screen. You need to rotate the screen control slightly clockwise. If that resolves the problem, the picture tube is starting to fail and you should take your time to locate a new set. Turning up the screen will only "fix" the problem for a short time (anywhere from a week to a month or more). If you turn it up too high, you will see the retrace lines in the background of the picture.
Keep us posted.
Dan
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sony KV-32S42 32" TV
Questions and Unsolved Problems for Sony KV-32S42 32" TV
Do you recommend Sony KV-32S42 32" TV?
Answer
Answer
i have a sony tv it was working fine till last night when turned on the tv picture started to skew... (More)
Answer
Sony Trinitron Model #KV-32S45 Ser#8066618
Answer
I have just moved my satellite receiver and DVD recorder to a new cabinet and upon reconnecting... (More)
Answer
Is this a Digital ready tv? How do i change from cable to antenna/
Answer
recently purchased a kv-32s42 32" at an auction. Tv was working but when we got it home will... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony KV-32S42 32" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 769
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
