Hi there. i am findng it difficult to remove and replace the headlight bulbs on my 2005 nissan terrano 2. does anyone know what to do and if so could you give me a step by step guide. it is a nissan terrano but the product catagory didnt list it sorry
Check out
http://www.sferamydlo.com.pl/Zbyszek/Nissan/R20/el.pdf
Bulb Replacement
The headlamp is a semi-sealed beam type which uses a replacable
halogen bulb. The bulb can be replaced from the engine compartment
side without removing the headlamp body.
I Grasp only the plastic base when handling the bulb. Never
touch the glass envelope.
1. Disconnect the battery cable.
2. Disconnect the harness connector from the back side of the
bulb.
3. Pull off the rubber cap.
4. Press end of the retaining pin together to release bulb.
5. Remove the headlamp bulb. Do not shake or rotate the bulb
when removing it.
6. Install the new bulb in reverse order of removal.
Head lights not going to high beam
removal of parklight fitting
