Question about Balboa Instruments Garden
Need a users manual
Jacuzzi 8 person hot tub
Model # WH-R576-DCAH
H25000
R576000
These are the numbers on the hot tub, I bought it used and need a users manual. Please help me with this. Thanks Kathy Dummer
Kathy,
I think what you're looking at are the part numbers for the heater and control systems used in some Jacuzzi hot tubs rather than the Jacuzzi model number. I ran into the same issue and discovered through some cross-referencing on the web (jacuzzi parts suppliers) that this is the part number control unit made by Balboa. Odds are they were used in multiple Jacuzzi models.
My suggestion: Look here http://clearcreekspas.com/model_id.html to identify the control panel for your Jacuzzi and then follow the link to the correct manual. Some cover multiple models so you will need to know the electrical requirements of yours (120 V or 240 V?) and then check the layout of each tub shell to determine which model is yours.
I figured out mine is a Jacuzzi Essence Model 350 this way.
Posted on Dec 07, 2008
I just got an outdoor Jacuzzi, it's all there. I just need to know what more do I need to hook it up to have it working
Didn't it come with installation instructions?
There are a number of very important things.
A flat level pad for it to sit on.
Correct voltage and RCB to prevent electrocution. The installation must be to building code.
A hose to fill it.
Chemicals to kill bacteria pathogens, and used in the right amounts and tested each time you use it.
Have a look at some of these videos.. You can also Google
make model installation instructions.
http://www.bing.com/videos/search?q=jacuzzi+installation&FORM=HDRSC3
Strictly speaking, you probably have a Hot Tub rather than a Jacuzzi which is the trade name of a bathroom bath that has water jets.
http://www.bing.com/videos/search?q=hot%20tub%20installation&qs=n&form=QBVR&pq=hot%20tub%20installation&sc=8-20&sp=-1&sk=
jacuzzi installation Bing video
Jun 20, 2016 | Home
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
Jacuzzi hot tub, Water is too hot. Heats until it trips the system. I have replaced the analog temperature control,
1) Safety question first
Why hasn't the GFCI tripped.
If your spa is not protected by ground fault., then you are at serious personal risk.
http://waterheatertimer.org/How-to-wire-GFCI.html#arc-fault
2) Replace the element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
3) If element is cracked, it can continue heating to ground wire, causing runaway heating.
This applies to spas, and water heaters of all type.
Dec 08, 2012 | Jacuzzi Pool & Spa
Jacuzzi hot tub , trips the circuit breaker, inspection found a burn't part Z-1 in on wiring digram. Can some one help with what a z-1 is Capacator?
If you have something burnt on your circuit board you will need a new circuit board.
begin with finding the chip number on the circuit board. this chip is usually located close to the transformer on the circuit board.
Rod
US Parts Center
888-521-6183
Jun 24, 2012 | Jacuzzi Pool & Spa
I have a Balboa WH-R576-DCAH. All controls seem to operate ok but no heat. Both motors seem ok, pulling about 5amps each. Not an expert but was able to manualy close the relay and cause the heater to...
If the pressure switch is jumped properly and you still are not getting a call for heat, then you are having a problem with the circuit board and it most likely is going to need to be replaced.
If the heat light is coming on but no voltage is going to the heater, this would also indicate a bad board.
You can find the 52213 circuit board online at: http://balboadirect.com/52213.aspx.
Hope that helps.
Aug 02, 2011 | Jacuzzi Balboa R574 System for 1 2 Speed...
Hot tub not heating need owners manual to reset
You need to provide the exact make and model of your spa
Dec 12, 2009 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
Need User Manual
Go to Jacuzzi.com and plug in model and serial no. you should be able to find an operation manual there.
Jun 09, 2009 | Whirlpool Caresse 2 Person Bathtub Seats...
Open Questions:
Master spa legacy hot tub pumps stopped working after refilling it? my legacy inspire hot tub was fine before i drained it, then after refilling it pump 1 sounded like it was trying to work and never turned on, pump 2 was working, so i reset the power and let it go through prime mode and still pump 1 was still not working but make the same noise and pump 2 still worked, i then left it on overnight and in the morning pump 1 and 2 stopped working completely, made no moter noise at all, so i reset the power and still nothing, the balboa vs series controller box makes a click sound but wont let pumps work at all, now i get 5 different codes dr, sns, hfl, dry and ice, so we bleed all the unions to remove any airlock, then reset power and still the same click sound, then we emty the tub and started over again and refilled it with hot water and cracked all the unions and its still the same click, so we found an article about reseting the memory on the balboa controller and turned off power used the j46 jumper turned power on then off again then took off jumper then powered on again the the lcd panel said a bunch of reset numbers and worked but still the pumps dont work? i think the balboa controller is not letting the pumps to even try priming or to even try to work it just clicks in the balboa? is there a reset for the sensors memory?? ive replaced the heater and sensors last year so its not broken i just dont understand pump 2 was working then stopped and both completly stopped working overnight?? can someone help!!!!!
Dec 10, 2012 | Balboa Instruments Duplex Digital Panel 2...
Garden Logo
2,168 people viewed this question
Top Balboa Instruments Garden Experts
Ian Kime
Ian Kime
Craig Butler
Craig Butler
Delage guy
Delage guy
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
