Question about Video Game Consoles & Games
Nintendo DS not charging. Tried different chargers but no good
  • 36 Answers
1) If the light doesnt come on at all when you plug in the DS
there is probably an internal fuse on the DS which governs the charging of the device. You can get a kit that will charge the battery for you, usually when you buy accessory kits you get these (try argos?). I got one a couple of years ago with a battery and a dock for charging it, from argos, but I think it was discontinued.
2) if the light comes on and turns off immediately then its probably a problem with the battery. Buy a new battery, theyre quite easy to get hold of and quick to change with a screwdriver.
Posted on Nov 12, 2008
5 Suggested Answers
SOURCE: ds nintendo will not charge light flashing and think it is the connection on the ds as i have tried other chargers in it
After a bit of trial and error I found that one of two internal fuses had blown. You can bridge the fuse with a bit of solder to fix it but this means if the same thing happens again there will be no fuse to protect your DS. My own solution is to get a friend to charge my battery on their DS while I wait for a desktop battery charger to arrive from Hong Kong. I found the battery charger on ebay. I suggest you charge your battery in a friend's DS and put it back in your own to see if you DS works. If it does then you have the same problem as me.
Hope this helps.
Posted on Jan 14, 2008
Ostewart2102
  • 41 Answers
SOURCE: my ds charger plug is bent
The only concern is if the connectors inside the charging station is corrupted. The bending is simply the outer metal connection, then bending it back wouldn't cause any damage. If the problem is further inside the station, it needs to be replaced. Nintendo can replace it for you for an acceptable price.
Posted on Jan 04, 2009
msgetlost
SOURCE: ds lite charging lite comes on but when i press power button nothing happens
i left to go to the mall one day and there were a whole bunch of little kids here and i put mi ds on the back of my sofa and wen i came back my ds didnt come on so i charged it for 3 days strait and on the charge button will come on but when it does it stays on for like 2 minutes then cuts of and mii game doesnt come on and the kid didnt do anything but play with it
Posted on May 24, 2009
Rachet5396
  • 12 Answers
SOURCE: Nintendo DS Lite is not charging.
it could be. you can find replacement batteries online
Posted on Jun 21, 2010
When playing the ds it turns off randomly. i made sure that it is charged so the battery doesnt seem like the problem
there could be a problem with the charger.. Have you tried different chargers? If so.. its could be the battery
Apr 09, 2010 | Nintendo DS Console
Nintendo DS Lite - does not charge
i would suggest trying to find what the issue is, if you know anyone who has a different charger, try it on your daughter's ds. if it still doesn't work, it's a DS problem...if it's under warranty, go to whatever store you bought it at and have them fix or replace it. If you try the different charger and it DOES work, then the only problem is the charger...so then all you have to do is go buy a new charger...hope this helps.
Feb 05, 2009 | Nintendo DS Lite Console
My nintendo ds won't turn on
Depending on how long you've had the DS, it's more than likely the battery. After some wear and tear, the older model batteries will eventually stop holding a charge. It's pretty inexpensive to replace as well. Contact Nintendo and find a repair shop in your area.
Jan 03, 2009 | Nintendo DS Console
My ds charger plug is bent
Nintendo ds won't charge or power up?
check for damage to the small pins where the charger plugs into the DS, it may just not be getting a good contact. If they are ok then perhaps the charger is blown and therefore the internal battery in the DS will be dead.
Either find someone with another DS and try a different charger or try your charger on theirs to rule out if yours is broke.
Oct 26, 2008 | Computers & Internet
Nintendo DS Lite will not charge
GET A NEW CHARGER HAPPENED TO ME BEFORE my bad caps lol
Jul 18, 2008 | Nintendo DS Lite Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Nintendo ds lite will not turn on, when trying to charge the orange lite blinks once.
after researching this for a while, i heard that it is because the fuses have blown inside the ds. you can try to fix it but it is risky.
good luck!
Sep 17, 2007 | Nintendo DS Lite Console
Video Game Consoles & Games Logo
653 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
