Question about Mitsubishi VS-45609 TV
Problem with picture - "double exposure"
My Mitsubishi big screen looks like it has a double exposure. Sort of like the red, blue and yellow are not lined up right. I have tried the contrast, tint, brightness, etc. Even tried disconnecting the cable and reconnecting. Any ideas?
    Sergeant:
  • 337 Answers
Your set has what is know as convergence problem and is a popular problem in the rear projection sets,the only way to correct the problem is by replacing the amplifiers in charge of aligning all 3 colors,your set might only use two amps for all 3 colors,The IC's(amps) are both the same number and they are mounted in heatsinks because they get hot,they have a number in the front that looks like this STK--- ---,they run about 25.00 each and replacing them can be difficult because they need to be unsoldered and removed without damage to the main circuit board ,then the new ones need to be soldered in,sometimes the new ones need to be aligned from the service menu so all three colors line up.If you are familiar with tv service you have now a place to direct your attention but if you are not too familiar be safe and call for assistance from a servicer.Let us know if you need more information.
Posted on Nov 07, 2006
  • Omar Urrutia
    Omar Urrutia Nov 07, 2006
    Your rating response is also important.
Have a Sanyo big screen tv but need need to adjust the color, to yellow!
Need to know if older set with picture tubes---turn color off--if yellow screen you have a loss of blue of some sort--red and green will give you a yellow screen. If set has the 3 picture tubes look inside in the lens to see if all 3 have a image---little or no blue means a problem there.
Oct 15, 2012 | Sanyo Televison & Video
Mitsubishi ws-48311 blue and yellow shadows
I would suggest you go into the menu and select convergence and then advanced convergence (set will display on screen instructions) and call up the grid of lines by doing that---the grid of lines you see should all be yellow---if you see red or blue lines out of position try with the Mitsubishi remote to adjust them.
If they will not adjust the set needs the convergence circuit repaired.
For many if this is the issue it can be a do it yourself repair--I have complete instructions for this repair in this set---start to finish.
Look first to see if this is your problem.
SD TECH
Apr 22, 2012 | Mitsubishi WT-42311 42" Rear Projection...
I am trying to install a Panasonic stereo to a mitsubishi mirage 1996, trying to find wire diagram for vehicle, the one I found on net was completely different from wiring colours in vehicle.
Constant 12V+ Red/Black Switched 12V+ Blue Ground Chassis Illumination Green/White Dimmer Black/Yellow Antenna Driver's Pillar Front Speakers 4" Dash Left Front (+) White/Blue Left Front (-) Black/Blue Right Front (+) White/Red Right Front (-) Black/Red Rear Speakers 6" x 9" Rear Deck Left Rear (+) Yellow/Blue Left Rear (-) Gray/Blue Right Rear (+) Yellow/Red Right Rear (-) Gray/Red
May 14, 2011 | Mitsubishi Mirage Cars & Trucks
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
Apr 14, 2009 | Mitsubishi WT-42413 42" Rear Projection...
Color is mostly yellow and blue with double images
you have lost the convergence IC`s in your set, this really isn`t a diy repair unless you are very proficient in un-soldering and re-soldering components, once replaced there will be an alignment procedure as well that will require the service manual also, if you have more questions feel free to ask away, video-tek
Feb 04, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Mitsubishi convergence Problem
You only have 3 colors Red, Blue, and Green. No black or yellow. I would say look for self test diagnosic on here or other sites.
Jan 13, 2008 | Mitsubishi VS-60607 TV
Convergence Problem?
Convergence problems are what you have possibly a pincushion error. Either way if you have to have a repair shop do the repair, you should look at replacing the old TV.
Jan 26, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-45609 TV Logo
104 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
