Question about Samsung RS2630SH Side by Side Refrigerator
Water coming out extremely slow Please help
Hello. I just installed a new water filter. Samsung brand for this refrig. Since installing, and I did install it properly, the water takes about 60 - 70 seconds to fill a glass up. Can anyone help with this problem? Thank you!!!
3 Suggested Answers
  • 111 Answers
SOURCE: Water Filter light still red after new filter installed
You have to reset the light by pressing and holding the touch pad for 3-5 seconds. It doesn't reset on its own when you replace the filter
Posted on Dec 19, 2008
  • 6784 Answers
SOURCE: pure water dispensor leaks around the edge.
hi, this is a seal leak. its located behind the water release point. it could also be cracked, the assembly that is, but im sure its just a seal issue.
Posted on Feb 12, 2009
  • 65 Answers
SOURCE: My new (2 months) Samsung refrigerator barely
The only thing between the inlet line and the spout?
Water Inlet solenoid, a valve that lets water in. Follow the inlet line to the back of frige. Unplug and turn off water before service. repace valve. EZ FIX...
Posted on Mar 29, 2010
0 characters
1 Points
Slow water flow
I would try the backwash as you suggest. Also, I had to run a few gallons of water through a new filter, for it to work properly..
Hope it helps.... good luck!
Jan 12, 2014 | Frigidaire Refrigerators
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Water flow is extremely slow after filter change.
Those filters are for refrigerators that have heavily treated water in the household. You could have a filter that filters your water supply and not use the filter inside the frig. Why use both? Now, if your home is not filtered, you may need it. Check to see if the water supply line is crimped somewhere or frozen when it gets inside the frig.
Jul 15, 2010 | GE Refrigerators
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
The water dispenser is not working properly. There is water coming out, but at a reduced amount than before. The filter is new so it is not that. What could be the reason?
Put your old filter back on or the filter bypass piece that came with refrig .I have found several new filters which lowered the water output when installed . I would not replace the filter when the little lite says to . Only when the water flow rate decreases .
Jul 28, 2009 | GE Refrigerators
With the refrig , you should have gotten a small bypass piece which fits in place of the inside filter . Install this to see if the filter is good or not . Water faster , replace filter , still slow , possible water valve problem . Also use a connector usually a 1/4 x 1/4 compression fitting , to bypass the outside filter for test purposes only .
Jul 19, 2009 | GE Refrigerators
Installing the water filter to my refrigator
Rotate the cartridge hand hold to a vertical position and PULL.
You may need to get pliers to grab with.
Jan 21, 2009 | Kenmore 53642 / 53644 Side by Side...
disconect water line and make sure you have water pressure.
Mar 30, 2008 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Kenmore Refrig with Filters water and ice dispenser- water is dripping when not in use, no flow when activated
valve needs to be replaced. it is located in the back, just follow the water line to it. to shut off water there is eaither a shutt off behind ref or in the basement. again try to fallow the water line
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Samsung RS2630SH Side by Side Refrigerator Logo
729 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
