Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Ir 2200 a3 paper at the end is
I have canon ir2200 with sorter. when i copy with A3 format paper the paper at the end is undulate?????.With A4 format is ok.
  • 1,219 Answers
Try to flip the A3 paper (in your paper drower), it may be if it isnt used so often it can be moisty, so when it pass the fixing roller, he bacames undulate.
Or if A4 is ok, that means that sorter does not work OK, because the A3 is longer and it pass longer way and more rollers.
Posted on Mar 03, 2010
My canon ir 3320i copier toner is leaking from drum unit fix it
Can u plz Check Cleaning Blade and Mylar sheet for cut,
Check Charge Roller if gone bad.
if both seems to be ok, then change Drum Unit .
Aug 13, 2017 | Canon Office Equipment & Supplies
I need copy A3 with Canon iR 2016j Black and White Copier
Press aditional function, slect copy setting, then stack bypass, then select paper size A3.
Apr 04, 2013 | Canon iR 2016i Black and White Copier
I have a Panasonic Workio 1820 photocopier and I can't get it to copy A3 size documents. I have set the copy size to A3 but it will only copy and print an A4 portion of the document.
from where are u using the A3 paper . if ur using the drawer then simply select the original size and copy size as per ur requirement and first change the tray paper size to A3 in operator settings. if ur using by pass tray then be sure to pull the entire tray out as there is a sensor in the last end of the tray that senses A3 and legal paper
Aug 23, 2011 | Panasonic Office Equipment & Supplies
I need to change our Canon IR2016 from A4 to A3, Also I need to activate 1 to double sided copies. I am looking on line for the user manual for the IR2016 but can't find
ir2016 is allready A3 size copier.you can change tray setting.pull out tray from machine and then set A3 paper on it according to paper you must change blue lever position from A4 to A3.then close your tray.now you can work with A3 size paper
for double side copying you must be installed a "duplex unit" which is not come with standard machine.It is an optional unit.after that you can make double sided copying.
Jan 19, 2011 | Office Equipment & Supplies
COUNTER CHECK "CANON IMAGERUNNER 2200" BLACK AND WHITE
On the left side of the on/off switch is there a small button mark with 123 press that button and the meter reading will display.
101 TOTAL ***** -that will be the total of copies,printing,and fax receiving on A4
103 TOTAL LARGE ******-this is the total of the A3 copies,printing and fax receiving made
201 COPY(TOTAL) -this is the total A4 copies
203 COPY(TOTAL LARGE)-this is the total for A3 copies.
Apr 02, 2009 | Canon imageRUNNER 2200
I want copy from A3 (2*A4 pages) to A4 (landscape)
While coping A3 paper it result in A4 portrait not in landscape which is incomplete.How to manage it?
Feb 19, 2009 | Canon iR 2016i Black and White Copier
How do i set paper sizes on my canon ir2016i printer
Open the paper drawer
Remove the paper
There is a blue paper size plate,that keep the paper in the correct posision,Push it to the front and downwarts.The paper plate should come loose from the tray.Put it back in the openning for the A4.The openning for the A4 papersize is mark inside the paper tray.
Now set the blue papersize dail to A4 paper .
Then you are ready to copy with A4 paper.
Size reduction from A3 to A4
put the A3 original on the glass.
press reduction button.
make sure you have A4 loaded into the drawer.
select that drawer.
off you go.
Nov 19, 2008 | Canon IMAGERUNNER 6570 Copier
4 sets of copy counter numbers on canon imagerunner 2200
101:Total black copies and printed pages
103:Total A3 black copies and printed pages
201:Total A4 black copies
203:Total A3 black copies
Oct 31, 2008 | Canon imageRUNNER 2200
A3 Printing
Put A3 in the paper tray and select reduce and enlarge and set to 141% this is A4 up to A3 then press start this should help.
Thanks J
Oct 02, 2007 | Sharp AR-161 Laser Printer
Computers & Internet Logo
111 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
