Question about LG LRMM1430 Microwave Oven
Microwave works with door open
I have a GE microwave. When I partially open the door (not fully open, just a crack at the top), the microwave will start buzzing. The buzzing stops if I close the door or open it completely. I did not open the door while the microwave is running. Does partially opening the door cause the magnetron to turn on and leak microwaves? (P.S. I think I only disengaged the top switch on the door when I opened up a crack.)
  • 5 more comments
  • Anonymous Apr 28, 2008
    We have a Whirlpool Gold micro/oven combo. We can open the door to the micro and the micro continues to run. We had someone out to look at it and they said it was just the fan. We were ok with that, but realized that we can open and shut the door and it never turns off and continues to cook. So, if it is just the fan on the initial opening of the door, can the actual cooking be turned back on when you shut the door? Because that is what is happening.
  • Anonymous Mar 15, 2014
    GE microwave plugged in first time it was running. Only way it stops is to open the door. Pressing cancel has no affect and will not accept new selection. It's like a previous selection has stuck and will not dislodge
  • Anonymous Mar 21, 2014
    the buzzing sound is on the right side of the microwave
  • Anonymous Mar 22, 2014
    Turns on when door is opened
  • Anonymous Mar 23, 2014
    is there anything i can check
  • Anonymous Mar 26, 2014
    Microwave hums when not running with door closed
  • Anonymous Mar 29, 2014
    I have a less than 3 year old over the range Samsung microwave and after using it today I shut the door and it made a buzzing sound while it was off. After opening the door it stopped. I closed the door again and it buzzed more. When I opened the door the glass turn plate was warm. Called a repair person but it stopped buzzing and while he was there it worked fine. Trying to figure out what it was? It could have been buzzing from the right upper side but not sure.
  • LG Master
  • 9,150 Answers
If the top is open, the upper door switch should be open and the high voltage section should not be energized. That's the way it's *supposed* to work. But that buzzing is worrysome! Does the turntable turn during this condition? Does the inside light come on? How about the fan? If not, then I would doubt that it's cooking. If so, some models will do this. It's not uncommon to notice that the fan and light will try to come on for a split second when you shut the door. This would not indicate a problem. It has to do with the timing of the door switches and a replay on the board. If it's still under full warranty, it wouldn't hurt to call a GE-authorized servicer.
Posted on Nov 07, 2006
  • William Miller
    William Miller Nov 07, 2006
    I guess I should really clarify my response...
    If that buzz sounds like the magnetron, that's a problem.
    If it's the turntable or fan motor, it's okay.
    During normal cooking, you hear the magnetron's distinctive buzzing pretty clearly for the first second or so after hitting the START pad. After that, the cooling fan has gotten to full speed and it drowns out a lot of the mag's sound.
    Run the oven a few times so you can get an "ear" for the magnetron buzz. Then try your door trick to see if the buzz seems to be the same. If so, then you may be cooking while the door's "cracked".
H5460NO/01 door lock is not working
test this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Oct 27, 2013 | Microwave Ovens
I ordered and received a replacement door for my 2002 spacemaker ge microwave. The lady I spoke with said I would be able to install it myself. I figured there would be directions in the box explaining...
HELLO.
Below is the solution to replace your microwave door.
Unplug the oven from the outlet and/or shut off the gas valve. Open the old door completely and unlock the hinges by pushing the hinge out toward you and down toward the door. Slightly close the door and lift the door up and toward you.
Install the new door. Make sure the wall oven door hinges are aligned to go into the rectangular wall oven slots. Place the hinges into the slots. The hinges should "catch" on the slots comfortably.
Ensure the door is fully opened and push the hinge locks into an upright position. The two hinge locks should rest on top of the two hinges that are inserted in the wall oven slots.
Close the door and open it several times to make sure the door is properly opening and closing. Replug the oven back into the outlet and/or turn the gas valve back on.
Thanks.
Sep 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
When the microvave in plugged into outlet it makes a buzzing sound but works ok. When the door in opened the noise stops but starts back up when door is closed.
I just had the same problem with my ge spacemaker microwave model number JVM1490bd. I removed the grill on the top of the microwave with two screws on top. There is one screw that holds the front touch pad on, remove the screw and lift up to remove. The damper assembly is on the upper left, my door was sticking and didn't make the limit switch. I moved the door back and forth making the switch a couple times and that solved the problem.
Jul 16, 2011 | GE JVM1490 Convection/Microwave Oven
GE Microwave Spacemaker2. The toouch screen does not respond
could use a little more detail.
when u have no display screen the solutions are. possible causes * A fuse in your home may be blown or the circuit breaker tripped. A. Replace fuse or reset circuit breaker
* Power surge. A. Unplug the microwave oven, then plug it back in.
* Plug not fully inserted into wall outlet A. Make sure the 3-prong plug on the oven is fully inserted into wall outlet.
* Door not securely closed. A. Open the door and close securely.
Jan 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Venting of microwave - house stinks of bacon
Interesting post, because I have the same problem! I have spent the better part of today researching and taking our microwave apart (partially) to inspect the top portion re: outside vent. Everytime the microwave is on, the "active vent door" (manufacturer's term, not mine!) opens. Apparently this is normal. But it also opens when you turn on the vent fan, when cooking on the stovetop. I don't like this feature, because I think it 'overrides' the outside venting system. I double checked our outside vent to ensure that when this oven was installed, the person did in fact allow the flap to be open when the fan is on (he did). So I think what 'our' problem is, is that the microwave active vent sort of interferes with the outside vent, thus more of the cooking smell being blown into the house instead of the outdoors. I was thinking of simply disconnecting the gizmo that make the active vent door open each time you use the oven and/or vent fan option however I don't think that's a good idea as apparently the main purpose of the active vent door is to keep the electronics of the microwave oven from overheating. The more I read about this version of microwave, the less impressed I am with it. Lots of electronic issues with it. I am not fussy either with having the microwave over the cooktop. Sorry I don't have a solution for your problem but I do feel your pain!!!
Mar 21, 2010 | GE Microwave Ovens
Interior light always on Ge advantium 120
I bet by now your microwave is no longer working....did the bottom or top "hook" finally break off? I found that mine had cracked and started coming loose and so when it closed it was no placing enough pressure on the internal safety switch that tells the oven the door is shut. I was able to use a sturdy plastic glue to solve the problem but finally after about 2 years of fixing it I can no longer get it to bond. Now, I'm looking for a new part. Who makes a product this expensive with plastic parts!!?!??!?!? So frustrating.
Apr 13, 2009 | GE Advantium 120 Convection/Microwave Oven
No display, open the door lights on
Chances are that's a bad connection on the control board, which we repair nationwide by mail for $39.95 postpaid in most cases in about a week or so.
But for a common counter top microwave such as this, if it's out of warranty, it would probably be more economical to replace it.
If it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
GE Customer Service is here.
Mar 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile microwave remove top grill
1. Unplug power.
2. Remove two screws holding grille, either on top of the front edge of the outer case or in the grille itself.
3. The grille should lift right out. In not, you may need to pull it to the left about 1/4".
You can download GE owner's manuals and installation instructions here.
Some models have them on top.
Feb 04, 2009 | GE JVM1750SMSS Microwave Oven
Microwave stopped working
There is a internal locking mechanisim that has 2 or more switches that is usually attached with two or more screws next to the door latch side. Crack open the micro and adjust this by shutting the door then pushing this assy toward the latches untill all the switches look like they are being pushed in fully. If this doesn't solve the problem one of the switches or possibly more are defective. Call a local appliance repair center and get a switch there called micro switches.
Sep 14, 2007 | GE JE1540 Microwave Oven
LG LRMM1430 Microwave Oven Logo
2,098 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
