Question about Frigidaire GLTF2940ES Front Load Washer
Washer wont final spin
Had an appliance service here replaced computer board, it worked for a few loads. Again back to same problem. Ant suggestions?
  • Anonymous Nov 18, 2008
    wont spin in final spin has error code of E02
    Scholar:
  • 131 Answers
Hope this was a reputable company,if so they should come out & make the problem right.if what i'm reading is right,it could be anything from a bad connecter to a bad power supply to the board(too much voltage)anyway there are alot of what i like to call parts changers out there if you get my drift(i am in no way saying this is your case)but always check refferances & check with the B.B.B.before allowing someone to perform repairs for you.keep me posted.hope this helps,thanx for using fix-ya,please rate all replys
Posted on Nov 16, 2008
Model gltf2940fs clothes still wet only after the perma press cycle
Good Afternoon Friend,
I understand that your clothes are still wet in your Frigidaire washer, model# GLTF2940FS, but only after the perma press cycle. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and try the perma press cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire GLTF2940ES Front Load Washer
Wont spin
Good Morning Anthony,
I see that you are having trouble with your Frigidaire washer, model# FWFB9100ES0 not spinning. There are a couple things I would do. First check the dispenser drawer and make sure it is closed. This can hinder the appliance from spinning the clothes out. Another thing to check would be that the load isn't too small. If it's a small load it can become unbalanced. Add 1 or 2 similar items to help balance the load. If these suggestions do not work, you can always try resetting the washer by either unplugging it or cutting the power at the circuit breaker for at least 2-3 minutes. When you restore power try the cycle again. If you are still having trouble, I suggest contacting either the manufacturer or your local authorized technician. I hope this has helped.
-Best Regards-
WP
Mar 25, 2014 | Frigidaire Washing Machines
Washer will not spin dry
Hay david , if your washer wont agitate or spin then you got to replace the motor coupler , if its not giving you the final spin its the clutch .good luck APPLIANCES R EN
Mar 01, 2013 | Frigidaire GLTF2940ES Front Load Washer
Wont go into final spin
The final spin on this model requires an additional lock from the computer to the door. Remove upper rear panel and look at board. Find the tiny resistor that says R-11. If it's burnt looking the board and the wax motor (at the lock) need replaced
Mar 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH20PD washer does not do the High Spin Cycle
with what you have described the problem should be in the door lock unit. there is a check switch that gets pressed down and sends a signal to the computer board telling it that it is locked. if the switch isn't working then that signal will not be sent and the washer will just turn and never enter spin. replace the switch and this will clear up the problem
Jan 03, 2009 | Maytag MAH20PD Front Load Washer
GE Washer stuck on final spin cycle
when i start my washer it stays on the spin cycle
any tips on what might be the problem
Apr 06, 2008 | GE WBSE3120B Top Load Washer
Kenmore front loading washer/NOT SPINNING in cyle
replace your door lock switch it will run fine till you git to final spin then stops if i not missing the point the model no. will start with a 417 even door locks the switch is bad
Feb 24, 2008 | Washing Machines
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
