Question about Craftsman 4 Cycle Blower/Vac
Engine misfires changed fuel filter
  • Hairyloon May 11, 2010
    Do you want to give us a few more clues: description of symptoms etc?
  • 211 Answers
Hi
Check the cable from coil to sparkplug to have continuity(measure apparat).Check the other wires as well.Check the ON-OFF switch.
regards savumihai71
Posted on Dec 05, 2008
I have a 2001 Pontiac Montana minivan that is misfiring stalling and cutting out. I put in fuel additive thinking it might be the injectors and premium gasoline . Could this be a bad fuel filter?
It could be a timing issue (misfire) but it absolutely could also be either air or fuel filter. If it's starving for fuel, it's the fuel filter. If it's starving for air (too rich), it would also stall out and that could be the air filter. Basically, you need 4 things to make an engine work: compression, air, fuel, and spark.
Oct 13, 2016 | 2001 Pontiac Montana
'01ElDorado... how many 02 sensors&where? I've replaced three,changed plugs, but car still misses. Error code:"random misfire". where are the fuel filters; is there one in the tank ,also. Thank you
many people mistakingly believe that misfires are the results of ignition problems only. There are several other variables that have to be considered . They are fuel pressure and injector performance. If the fuel pressure is too low then the injectors squirt instead of atomising an the resultant air/ fuel mixture will not combust properly resulting in misfiring. Plugs used in the engines manufactured in the last 12 years will generally out last the engine . Quality HT leads if separated correctly will last many years . But injectors which are subject to electronic problems and dirty fuel (gum and tars not removed by filters) will be the culprit in most engine misfires. So have a pressure test done on the fuel manifold to check the fuel pressure regulator, pump and filter. have the injectors cleaned and regularly maintained .
Dec 25, 2013 | 2001 Cadillac Eldorado
Misfiring.
need do a tune up change spark plugs and wires.clean fuel injectors and change fuel filter.if engine equiped with distributor replace distributor cap and rotor.if vechicle still misses.could have bad ignition coil or cylinders have low compression.
Jan 13, 2013 | 1994 Toyota Corolla
Engine light came on and said 8th cylinder misfire i changed spark plugs and ignition coil but still showing same problem
Could be a clogged fuel injector. Check all ignition connections to make sure they are clean and secure as well as the one for the associated fuel injector.
Jun 11, 2012 | 2003 Ford Crown Victoria
Engine stumbles, no check engine light comes on
Check engine light does not have to come on unless the misfire monitor reaches a certain count.There it will pend a misfire code,and who know what code you get may just tell you P0300 random misfire,we know its misfiring .But we got the symptoms, The 2.2 is sensitive to water in the fuel system when you change the fuel filter were you able to get a sample of at least some.Where the ignition coil sits do you hear any arc at idle(in park) that can tell you you will need sparkplug wires. you can also use a spray bottle of water and spry it on the wire.see if that exposes any arc from the sparkplug wire. The fuel pressure on the 2.2 has to be 56-62 psi.This is the necessary pressure. Also the TPS can cause you to stumble intermittently and this is a common failure on the 2.2 engines
Mar 06, 2012 | 2002 Chevrolet S-10
CODES-PO301-PO303-PO316- CHANGED PLUGS & WIRES. STILL MISS ON START UP, GOES AWAY MOST OF THE TIME ABOVE 1000 R.P.M
P0301 - Cylinder 1 Misfire Detected.
Causes:
- Improper spark plug at cylinder #1
- Insufficient compression at cylinder #1
- Incorrect fuel pressure
- The injector circuit is open or shorted at cylinder #1
- Fuel injector #1 may be faulty
- Intake air leak
Solutions:
- Perform Injector Service
- Replaced Spark Plug #1
- Replaced Injector #1
- Replaced Ignition Coil #1
P0303 - Cylinder 3 Misfire Detected.
Follow info from P0301.
P0316 - Misfire Occurred In The First 1,000 Engine Revolutions.
Causes:
- Damaged CKP sensor.
- Ignition System.
- Fuel Injectors
- Running out of fuel
- Fuel Quality
- Base engine
- Damaged Powertrain Control Module
Solutions:
Usually the P0316 is combine with a P03XX codes. The P03XX code indicates in which cylinder the misfire occurred.
Jan 17, 2011 | 2002 Mercury Sable
Diesel engine misfires
try having the overhead run on it!!
Oct 26, 2009 | 2005 Volkswagen Golf
Engine misfires badly after cruising a while at 3k revs,
Try to check the computer box and check if it is working and check the timing belt as well make sure it is properly tune up.
Jun 09, 2009 | 1998 Subaru Legacy
Craftsman 4 Cycle Blower/Vac Logo
99 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
