Question about Moen 3867 Four Function Hand Shower With Slide Bar
Shower faucet, similar to Moen 3867 the slider broke and Moen send me a new one, but I don't know how to install it. They never left any paperwork, ie instructions when I had it installed. How do I get the new slider on the bar?
    Problem Solver:
  • 19 Answers
You need to remove the bar from the wall than the slider goes on the bar and than you reinstall the bar again
Posted on Feb 03, 2009
We had both the shower and the Bath tub remodeld and installed new Moen faucets with a single knob that turns right to left to open. All was fine for a couple of days but all of the sudden they startd...
You need to install a new moen cartridge its a single handle posi-temp cartridge you should be able to get 1 for free if you are the original owner by calling 1-800-buy-moen more than likely when soldering in the new valve a little bit of solder broke free into the cartridge or hard water. When the water gets turned off and then turned back on it can break free alot of particles that can get jammed up in these cartridges or any fixture for that matter you will need a cartridge puller to perform this job with ease.
Aug 27, 2011 | Moen & One Handle Tub & Shower Faucet
On new Moen shower faucet, when I turn on faucet, water drips from shower also.
The faucet was installed upside down.
The shower riser pipe in the wall is to short( the distance between the faucet and shower head).
One of the biggest problems is if your shower faucet was installed with Pex pipe to the tub spout. Pex pipe will restrict the flow and force the water back up and out of the shower head.
The tub spout must be piped with at least 1/2 brass pipe nipples and fittings, or 5/8 OD. copper pipe and fittings.
Hope this helps, if you further questions please let us know.
Sep 08, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Knob on tub spicket to release or stop shower came off
I could not find an exploded parts diagram for the Benton suite from Moen. I did find the bayhill which is very similar. Please see link below of exploded view. That should help you piece it back together.
Jul 31, 2010 | Moen & Benton& Tub & Shower Faucet
Just installed a Moen 3867 hand held shower. There is no water coming out of the head. Water flows just fine from the hose without the head attached. Is there a restrictor plate or something I can...
Usually whenever you do any repairs on plumbing, you dislodge calcium from the inner surfaces of teh plumbing. Check to see if ther is a mesh filter in the inlet side of the head. and remove and clean it. otherwise you could remove it and use a vacuum yo try and remove any deposit that may be in it. If that is unsuccessful,
you can always return it, but always remember to open the fawcett and run it before installing the head.
This is an essential part of any plumbing job. Good luck
. If your local store refuse to replace it Moen will gladly do so with no problem.
They are good like that.
Mar 04, 2010 | Moen 3867 Four Function Hand Shower With...
Moen faucet in bathtub that whistles and a very high pitch whine when shower is engaged recently purchased house and don't know model # how can I locate a relacement part
your cartridge's rubber's may be fluttering in water stream. causing the noise. had similar problem,and a new cart' solved problem.either #1222 or 1225 is possible # for new cart,' remove and take with you to hard ware store, or the home depot/lowe's
Jan 13, 2010 | Moen & One Handle Tub & Shower Faucet
Shower water temperature regulation
The temperature is adjustable. The valve has a disc you pull off the front of valve and then rotate the seat I believe counter-clockwise. If you get the paperwork for this valve from moen it is very explanatory. I can help further if needed, Let me know!
Nov 10, 2009 | Moen & One Handle Tub & Shower Faucet
Just installed a Moen shower fixture, & the knob for the shower head doesn't send water to the shower head-- I don't get it!
I just installed one this weekend. Make sure that the cartridge has the embossed "HC" at the top (for Hot on left, Cold on right) when you slide it back in. Also, before putting the handle on turn the cartridge shaft so that the completely flat part is toward the top and the side with the small notch at the end is toward the bottom.
Jul 26, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen shower handle keeps turning it wont come to a stop
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
Thanks and Please Rate jj505
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Mar 29, 2009 | Moen 2919 Chateau Two Handle Tub and...
Moen 3867 Four Function Hand Shower With Slide Bar  Logo
290 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
