Question about MTX Thunder 1501D Car Audio Amplifier
Makeing poping noise
I got an 1501d when i hooked it up it made some funny noise in the subs when i turned the gain up somthing like poping can some one help me with that
  • mannslick Nov 12, 2008
    so do i need to buy a new cd player cause the one i got is a pioneer deh-3900 that i got from a friend and he said that when he was hooking it up he let the speaker wires touch and he didint get no more sound so i took it and ran both of my amps off the rca's preouts and i always had a little wineing noise when i press the gas so what should i do.
  • 631 Answers
Although open shields on the head unit generally cause MTX amps to squeal, it can sometimes cause the symptoms you described. To check the shields, you will need a multimeter. The procedure is on the following page:
Testing for Open Shields on RCA Signal Cables
If the shileds are OK, we will have to check a few other things.
Posted on Nov 12, 2008
No sound
ok if u have a radio with sub controll make sure its on an make sure that you have the gain bassboost turned up an if it has a crossover switch make that its on
Jul 24, 2010 | Jl Audio 1000/1 Car Audio Amplifier
I have a few problems. i have 2 amps and 4 subs. first problem is when i connect one amp to my speakers it just hisses and crackles. this never happened before. when i turn up the gain to try and get...
The first amp, sounds like there is straight power going through the gain instead of it being limited. The second amp...hook the other subs up to it and see if it sounds ok. If so, then the subs are messed up. If it sounds the same, make sure the subs are connected correctly.
Oct 21, 2009 | Car Audio & Video
My subs make a loud humm when I turn my gain up.
your ground has to be no longer then 2 feet if ot it picks up noise from rca
Mar 13, 2009 | MTX Thunder 1501D Car Audio Amplifier
Mtx thunder 1501d
yes you can not run amps with your speakers being grounded un ground and then try
Nov 26, 2008 | MTX Thunder 1501D Car Audio Amplifier
My mtx thunder 1501d car amp making noise in the subwoofers
This is common with pioneer head units, the rca jacks are not properly grounded and this lets engine noise come through the rcs cables. This thread explains a fix
Nov 13, 2008 | MTX Thunder 1501D Car Audio Amplifier
Does the woofer move in and out in relation to the movement of the gain control?
May 09, 2008 | MTX Thunder 1501D Car Audio Amplifier
The 1501 is very similar to the 81000 but there are important differences. The 1501 is a better amp.
If you turn the gain up and down, does the woofer move in and out in direct relation to the rotation of the gain?
What do you mean by "you only feel current going through subs"?
Sealed subwoofer box with two 10" jl audio subs hooked up to jl audio 250/1
you mite have the gain to high turn it down a bit just because there's a max gain doesn't mean you need to use it . you mite have to turn the bass boost up. you should get a bit better sound out of it
Dec 12, 2007 | Jl Audio 250/1 Car Audio Amplifier
Amp turns on then starts making subs go erratic with almost sounds like line nosie
hi i had the same problem people suggest checking ground thats where you start at then if it aint ground for sure, the make sure you have good rca cables. If there good this is what happen to me i had a cheap ole pioneer 70 doller cd player the actual rc jacks from that cd player was making and horrible sound travel through my speakers im talking humming whinning everything im positive that this will solve your problem email me at and let me no something if i helped or if ya need more help
Apr 04, 2007 | Kenwood KAC-9152D Car Audio Amplifier
MTX Thunder 1501D Car Audio Amplifier Logo
144 people viewed this question
Top MTX Car Audio & Video Experts
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
