Question about Summitsoft Militarism for Windows
Compatibility Is this Summitsoft's game Militarism compatible with Windows vista?
  • 83 Answers
It should work in vista but if might not as well. What you can do is right click on the icon and choose run as administrator if it does not work the first time you try it. With vista, make sure you download Service Pack 1 through windows update for incrased compatability with programs.
Hope this helps, I could not find the Operating system requirements for the game so it probably does work with vista.
Posted on Nov 11, 2008
Dark Messiash disk for -window xp- igot window vista 32bit
try to run the disk on compatibility mode. right click the application file, usually the file with the .exe extension then choose to run in compatibility mode running windows vista. if this doesn't solve then time to change to disk for windows vista version
Apr 06, 2012 | Video Game Consoles & Games
How can I load the 32 bit program on a 64 bit machine?
I will assume you are using Windows Vista or Windows 7, which is a newer operating system then what the game was intended for. Microsoft Windows has a Compatibility feature you can use to run games in Compatibility mode. Once you install the game, you can right click on the game Icon(should be on your desktop) then choose properties. In the properties go to the Compatibility Tab and click Run program in Compatibility Mode and in the drop down box try selecting Windows Xp(any service pack). Also check the Run Program As Administrator. In some cases you can get the older games to run.
Sep 28, 2011 | Groove Games Marine Heavy Gunner for...
Will this software work on Windows 7?
According to their website it will in fact work with Windows 7. Cheers!
Feb 28, 2011 | Logo Summitsoft Logo Design Shop - Jewel...
This is a game created for Windows 95/98. How do I run it in Windows Vista?
By default it should work, but some games would need you to change its compatibility. After you install it, right click the shortcut on the desktop and go to properties. After that click the compatibility tab, then check the box for 'Run this program in compatibility mode for:" And pick WIndows 95 or 98.
Feb 25, 2011 | Knowledge Adventure JumpStart 2nd Grade...
Problem running Civilization IV with Windows Vista
Okay, i play Civ IV on my system and i run Vista as well. Your best bet is the tweak with the compatibility. Find the install folder and look for the .exe that launches the game (civ.exe i think, don't hold me to that though). Right click on it and click on properties, then the compatibility tab. Try dropping the compatibility to win xp and see if that helps. If it doesn't, post your system specs and we'll work from there
Jul 25, 2010 | Take 2 Interactive Sid Meier's...
I had my comp. fixed and they put windows vista home premium on here and i can't play my old games that need xp what can i do
You can do 2 things:
1 - try to run them in XP mode  - right click on its icon, then Properties, then Compatibility, check 'Run this program in compatibility mode for' and select Windows XP in the drop down menu and finally at the bottom of the compatibility tab, check 'Run this program as administrator'.
2 - install , configure it and in it install XP and all the soft with problems, starting with the games.
Mar 07, 2010 | Microsoft Windows Vista Home Premium...
CivilizationII test of time
If it doesn't work the regular way, try installing and playing in compatibility mode. To install in compatibility mode right click on setup -> properties -> compatibility tab -> check: run this program in compatibility mode; to play the game in compatibility mode do the exect same thing ond the game executable file
Mar 17, 2009 | MicroProse Civilization 2: Test of Time...
My game is loaded but when i click on the icon. it will not play?
Ok, from what I read on Microsoft, this software is NOT compatible with Windows Vista 32-bit or 64-bit. That was found directly from:
However, checking the company's website, it mentions that some games that normally won't run in Windows Vista, can be ran in a "compatibility mode" which mimics Windows XP. Follow these steps and see if this corrects the problem:
  1. Right-click the shortcut for the game.
  2. Click the compatibility tab.
  3. Check the box for "Run this program in compatibility mode".
  4. Select Windows XP SP2 (or Windows 98 if XP does not work) from the drop down menu.
  5. Click Apply
  6. Click OK
  7. Start the game
It should run in Windows XP SP2. If it doesn't you can try Windows 98 to be sure. If neither of these work, unfortunately, you may be unable to play this game.
Mar 04, 2009 | Video Game Consoles & Games
You're probably not going to find one. Vista lets you run old programs in 'compatibility mode' - actually, so does Windows XP. TSometimes it works, some times not but it's worth a try.
To use, you have to...
  1. right-click on the games' shortcut (either located on your desktop as an icon, or in Start -> All Programs).
  2. Once you right-click on the shortcut, click 'Properties'
  3. click on the 'Compatibility' tab at the top
  4. under the 'Compatibility mode' section, check the box that says 'Run this program in the compatibility mode for:'
  5. then choose 'windows 98' from the dropdown menu
  6. click ok when done
Good luck and I hope this helps! : )
Jun 24, 2008 | Microsoft Windows Vista Ultimate Edition
Summitsoft Militarism for Windows Logo
98 people viewed this question
Top Summitsoft Video Game Consoles & Games Experts
James Wishart
Are you a Summitsoft Video Game Console and Game Expert? Answer questions, earn points and help others
