Question about TallyGenicom 6312 Matrix Printer
Error message come up on printer
C H K SUM FAUL B 8
    Novelist:
  • 169 Answers
Normaly a Check Sum fault will be displayed if the printer firmware has become corrupt or the flash memory may be damaged.
The first thing to try would be to reload the firmware into the pritner, if the firmware is corrupt this will rectify the problem.
If it is not possable to reload the firmware the main board may need to be repalced.
Posted on Nov 13, 2008
We have a CTM HS-2800 power wheelchair that has 2 red, 2 green & 2 yellow lights that come on flash 8 times and then go off. What might be the problem when this happens?
You have a module problem:
Evaluate your batteries. 12v Single or 24 together.
Flash codes:
1. Stall Timeout, Joystic out of neutral
2. Battery Voltage too over 32VDC hi or too low under 17VDC
3. Left motor Fault
4. Right Motor Fault
5. Left Brake Motor fault
6. Right Brak Motor fault
7. Shark Control Module Faul
8. Power Module Faul
9.Shark Module Faul
Nov 24, 2010 | Ctm HS-2800 Power Wheelchair
Ctm hs 2800 turn on key light come on and blink 7 time then go out push joystick foward motors kicks in and out and lights blink 7 times and then frist red light keeps flashing
3. Left motor Fault
7. Shark Control Module Faul****this will be your problem***
9.Shark Module Faul
Contact me Direct 909-590-1388 x115 CTM HOMECARE OFFICE
Oct 31, 2010 | Ctm HS-2800 Power Wheelchair
U2-40 error on sharp AR-M207 displayed on the digital display... what do i do
U2 04 EEPROM serial communication error
11 Counter check sum error
12 Adjustment value check sum error (EEPROM)
40 CRUM communication error
this the U2 Code Error
Jun 09, 2010 | Sharp AR-M207 All-In-One Laser Printer
I bought a 1 TB external just a month ago and my saved music folder on there gives me the message "cyclin redundancy check" error..what is the best way for me to recover these files?
When your computer writes a block of data to a disk-drive, it calculates a "check-sum" value, and writes that value, along with the data. When your computer reads that same block, it also reads the check-sum value, and it recalculates the check-sum, using the same "Cyclic Redundancy Check" algorithm.
If the "new" check-sum matches the "old" check-sum, then it is declared that the data was correctly written & then read. Any "mismatch" indicates an "I/O-error", i.e., at least part of your disk-drive is dying, even though it's only a month old.
Maybe, it's only one file in one folder that has become "unreadable", but it could be much more.
Copy all the files that you can, and exercise the warranty on the disk-drive to get it replaced.
Apr 07, 2010 | Office Equipment & Supplies
Error code u-2 solution
U2 00 EPROM error 11 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication error
U2 04 EPROM error 11 Main counter error 12 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication errorYou need the service help. It is no a distans work Good luck)
Mar 14, 2010 | Sharp AR-5320 Black and White Copier
I have a ctm scooter the battries are charged fully when i switch on the scooter will not work switch off and on again it then will travel a few feet before stopping
The joystick will display a sequence of flash codes. Count them and find the count here: This could be several issues, But the flash code will tell you for sure.
3. Left motor Fault
9.Shark Module Faul
Mar 07, 2010 | Ctm HS-2800 Power Wheelchair
Hello have a HS2800 the two yellow lights are flashing....and I found a wire with a fuse in it and can't find where it plugs into...can anyone help
the wire with the fuse belongs to external light fetures (unit does not have. It was intended for future use for external ligts)
the two yellow lights endicate problme with batteries( too low) or the module controller.
3. Left motor Fault
9.Shark Module Faul
****two yellow lights*** Module problem
Sep 17, 2009 | Ctm HS-2800 Power Wheelchair
Error message-"printer had any motor mis-step error"
After 8 yrs..........Get a life and new printer! Inkypete
Apr 21, 2009 | Alps MD 5000 Thermal Printer
TallyGenicom 6312 Matrix Printer Logo
157 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
