Question about Zoom X5 5654 DSL Modem (DH5654)
Adsl light is flashing - no connection
Computer says "LAN is unplugged". Adjacent phone line is still working.
What happen when a adsl line work with a phone but not with a router
The phone line does two jobs. Voice phone which is what it was originally used for and ADSL modem which works at a high audio frequency.
Somewhere between the phone socket and the modem should be a filter splitter. One part goes to the phone and the other to the router. Make sure you have that.
The modem will have a power light and several additional lights. Assuming the power light is on we are interested in two of them; The ADSL light and the Internet light. When you switch the modem on you should first see the power light flash then go solid. Then the ADSL light will flash and then this should go solid. If this light does not come on then you have not plugged the phone wire in properly. If this light just keeps flashing slowly then the modem can't see an ADSL signal on the phone line. If you have a spare router you could try it and see if the ADSL light goes solid on that.
If the ADSL light is fine then the modem has locked onto the signal on the phone line, sync'ed. If not then this is the problem you must solve. Ask your ISP if service is set on your line.
The next light is the Internet light, this maybe a symbol like an i or a world. This light will begin flashing then go solid. It will flash with Internet traffic. This means you have Internet, as far as the modem is concerned. If this light does not stay on then your ADSL account name and password maybe wrong. You can correct this but that's a different question you need to ask.
Feb 18, 2015 | D-Link Dsl-2750b Adsl2 Verizon N Wireless...
Wt8951nd
Power cord
RJ-11 telephone cable coming from a splitter or the extn. line of your landline phone.
Ethernet cable coming from your Desktop/Laptop connecting RJ-45 port
Most standard ADSL modems have four/five lights in the front :
Power light to indicate electric power to the modem.
ADSL light indicates the status of ADSL sync. When the modem is synchronized with the ADSL line card at the other end of the circuit/loop, the DSL light will be steady green.
LAN light will glow steady green when the modem detects a successful link to a computer or router ethernet port.
ACT i.c. Activity light glows when the modem is sending and/or receiving data on the lan and wan. It will vary between very slow to fast flashing and steady green to indicate lan/wan traffic.
for more help visit CBR Tech Solutions
Feb 08, 2014 | Computers & Internet
Net Gear Adsl DM 602 modem ether net inter net and usb port
unplug modem for 30 seconds and re-plug if that fails do a hard reset ( button).
Sep 17, 2017 | NetGear DM602 ADSL-Modem
I have a DSL502T ADSL Router,and have bought a new emachines computer. I can not connect to the internet. The computer has a wireless connection loaded but I want to connect by dailup Please could you help...
You are a bit confused with the various components required for Internet connections.
If you have a dial-up connection with an Internet Service Provider, all you do is connect your computer's modem port to the phone line and dial the phone number of your Internet Service provider.
If you are connected to the Internet Servise Provider by ADSL and have a combined ADSL router and modem then you connect the phone line to this router/modem. If the ADSL modem is separate component then the phone line is connected to the ADSL modem and this modem is connected to the router with a LAN cable and the computer is connected to the router with another LAN cable. If the route is wireless and the computer has a wireless card then you don't need a LAN cable between the router and the computer.
If you are connected to the Internet by ADSL, to secure your Internet connection and configure your computer so it can connect to the Internet, please follow my instruction - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 17, 2009 | Computers & Internet
Wireless facility does not work LED does not illuminate. I have tried to get access to web site
The connection to your modem could be faulty.
Ring your ISP and get them to test the connection to your ADSL modem.
Also do you have ADSL line filters on all your phones?
The phone connection to the ADSL modem does NOT use a ADSL filter.
Dec 13, 2009 | Siemens SpeedStream 5260 ADSL LAN Modem...
Ethernet light flashing
Check your DSL Filters on your house phones or anything connected to the phone line EXCEPT the modem. The modem should not have a filter on it. If this doesnt help I would recommend getting your ISP out to test the line because sometimes the resisitors or hardware in the box goes bad or at the DSLAM.
Jul 20, 2009 | Efficient Networks SpeedStream 5667 Modem
How to connect the telephone lines
Please let the fax line be connected to computer itself do not remove , In the DSL line you get a splitter which the lines for phone and ADSL modem connect the splitter to DSL Line and from the Splitter you 2 o/p ports with phone marking or symbol connect the phone line to it and to line port connect the main 8957and then to ADSL line to ADSL modem from the ADSL modem connect to lan port which is behind the computer (not to dial up modem
i.e is fax line ) or the usb port in the computer ...
Good luck...
Feb 02, 2009 | RCA 25201RE1 Corded Phone
X6 won't pick up DSL
hopefully you haev installed the software first on yoy computer>
turn off the computer. connect the phone line one end to the ethernet port on your computer and the other end to one of the LAN port on the x6.
power up the (power cube shipped with the X6), the Pwr and the WLAN should come on and become steady, the LINK light should blink,
turn on you computer, connect a new phone line between ADSL port and the wall jack, the LINK light should become steady.
please rate the answer if it solved your porblem.
thank you
Sep 09, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Siemens gigaset se587 wlan dsl
HI
A flashing ADSL light on the router means its not getting constant broadband signals. Make sure it is connected to the adsl filter without any extensions and the filter should be directly connect to the main phone socket and not to an extension socket. Also check if the phone socket has 1 or more than 1 ports on it. If it has two port its most likely a SSFP socket which does not require a filter as it is inbuit.If all the connections are fine try changing da filter.
Sep 07, 2008 | Siemens (120-5830-001) Modem
ADSL light flashing!
what is used this router it is a adsl router or only router if this is only router then you have to connect your adsl modem then only its work properly .
Sep 03, 2008 | Computers & Internet
Zoom X5 5654 DSL Modem (DH5654) Logo
99 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
