Question about JVC MX-J30 CD Shelf System
Unable to read any CD on JVC MX-J30 CD Hi-Fi
I put a CD in any of the 3 CD shelves but when the system checks for it's presence it says there is nothing there (consequently not being able to play any CD). This used to happen now and then but a simple re-insertion of the CD normally solved it but now it seems to be permanent.
As this occurs on all shelves and any CD we can rule out them two things. I would therefore assume it is a dusty lense or a mechanism is not working inside.
If it is just the lense, I assume opening and giving a quick clean will solve the problem? If it is a mechanism however, how can I check and solve this?
P.S. I am competent enough to open the box and have a look around and replace parts if necessary but don't know what to look for or where to get replacement parts if required.
Many thanks for any help.
  • Anonymous Jan 04, 2009
    I have exactly the same problem. None of the cd drives are functioning. The message in the display showes 'no disc'. Using a cleaning cd is not possible. what is the problem?
    Kind regards.
  • Lickzee Feb 14, 2009
    i have the same problem as well, but i did open it and check inside.. when the cd have been inserted it would not spin and the laser will not active...it seem to not be able to sense the cd in the drive..seem to be a mother bord problem.. the whole drive seem to be the problem. it is held together by 4 screws 2 on the back and 2 inside and a ribbon strip.. if anyone can find the complete drive i would like to know...thanks...
  • 67 Answers
Failure of this laser is quite common giving a no disc message in the HiFi's display. A defective laser can also be responsible for an intermittent no disc message and general playability problems with CD discs. Part number Optima 7 / 7B Laser Assembly
Posted on Feb 14, 2009
  • Lickzee Feb 15, 2009
    for the advance fixers i have another solution.. The unit that i have, i took it apart, the laser is isn't very hard to remove, the tray the laser is sitting on does not have any screws and can be easily remove, but be careful removing the ribbon connector, Now this is what i did, now the unit i have i found in the garbage someone dump it because cd don't play, so i had nothing to loose.. I took the laser out and wash it under warm water carefully washing the lens with soap (palmolive dish liquid to be exact) rinse and compress air blow it dry.. when i replace it, it work amazing, I now have a perfect working unit for free... remember this work for me, i dont know if it will work for you but i had the same problem when i first start the unit as you did...
Where can I purchase an fm aerial for this jvc
Just about any electronics or big box store (Walmart, Target, etc.) will have an FM antenna. They will be in the electronics section.
Mar 18, 2015 | JVC MX-J30 CD Shelf System
What is bluetooth passkey for samsung hi fi 2560w
Most factory standard passkeys for bluetooth are 0000 or something similar. I'd try 0000
Sep 18, 2013 | Samsung Premium MX-FS9000 Mini Hi-Fi...
No power not even light but power is going to transformer also touch the metal cover with a phase tester and it lights up (only just though)..jvc mx-j30
hello you may have ac power but no dc power take the cover off and have a look for any swollen capacitors or components that might be burn't
regards
shaun
Feb 10, 2010 | JVC MX-J30 CD Shelf System
No power, sometimes working
please check the input voltage and adjust it
Feb 08, 2010 | JVC MX-J30 CD Shelf System
How do i connect my mp3 player to my jvc stereo
If it has a aux input at the back you can get a dock and that will let you plug it into your system.
Jan 23, 2010 | JVC MX-J30 CD Shelf System
Disk pops-up and blocks halfway when booting
Probably a poor suggestion, but you may want to look for a reset button on the back or the front. It is usually recessed and about the diameter of a paperclip. The electronics may be "confused".
Jan 16, 2010 | JVC MX-J30 CD Shelf System
The Volume knob malfunctions
Hi there. Sorry I haven't got a solution. Just want to know if you found one, as I got the very same prob with the volume knob of my JVC hi fi. Thanks for your time.
Oct 05, 2009 | JVC MX-J30 CD Shelf System
How can I modify my audio system as a Mp3 player
Hi sorry cant be modified to do but what you could do is use an external player and plug it into the AUX input on the back
Hope that helps
Jul 21, 2009 | JVC MX-J30 CD Shelf System
JVC MXJ30 Compact Hi-Fi
Spares from JVC? Where's the cheapest remote? Where's the cheapest Service manual?
Mar 09, 2009 | JVC MX-J30 CD Shelf System
JVC MX-C33 Tape Drive Problem
there are small rubber belts that drive the tape spindle that makes the tape play! Over time these stretch and become loose and make the tapes play slowly and even shut down (replace belts and it should be fine) these belts are located in back of tape spindel and are about two inches long!
Please rate my answer and keep this site FREE!
Dec 31, 2008 | JVC MX-J30 CD Shelf System
JVC MX-J30 CD Shelf System Logo
355 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
