Question about Pioneer SD-533HD5 53" Rear Projection HDTV
SD-532HD5 TV shuts off when watching
After about 30 minutes of watching tv, we hear a loud pop and the screen goes blank. The power button remains green, but we have to shut it down for about a half hour then it will turn back on. We need to do this a couple times during the day. What is going on.
  • 1 more comment
  • marco_morale Mar 02, 2009
    same problem.....
  • Anonymous Apr 11, 2009
    Pioneer SD 532HD5. Same problem. Loud pop then the screen goes blank and the dog flees for safety!
    Is this a dangerous situation?
    Can anyone be more specific as to which solder joint creates this problem? Do you need to be a technician or can anyone solder these points? Is there a U-Tube video that shows how to do?
  • xfactor7483 May 22, 2009
    Same problem, TV shuts off. I put a fan behind it to cool off the heat-sensor and this works as a temporary fix, but now it won't even turn on. Can I fix this problem by myself or is my TV done for?
Its is a cold solder joint on the board. The board is the one located at the bottom right of the tv when looking at the rear. Mine did the same thing. After refreshing mose of the large solder pints on the board, it stopped. Hope this helps!
Posted on Jan 19, 2009
    Problem Solver:
  • 13 Answers
I am not absolutely 100% sure but it does sound like possibily cold soler joints in deflection part of board
Posted on Dec 23, 2008
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Watching my LG 37LC2D and suddenly a loud 'pop' sound,screen goes purple,then blank - no picture, no sound. I turn off TV and power, wait a while, turn it back on - after a couple of minutes the picture...
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 18, 2017 | LG 37LC2D Television
My 42 inch flat screen was on and the all of sudden there was a big pop and the TV went blank. I could hear it clicking inside after this happened. Pulled the power plug to stop it. What caused the big...
It sounds like one of the Electrolytic Capacitors in the TV has gone, this can be caused by voltage fluctuations, Ambient Temperatures around the TV and sometimes they just fail for no apparent reason. If you are handy with some basic electronic tools you could open the back of the TV and you would possibly see the remains of the blown component as bits of paper like material around where a capacitor used to be.
Oct 25, 2010 | Samsung Televison & Video
The screen blanks out after approximately 20 minutes.
The power supply board is dead.Those high voltage transformers on the power supply board,one those power coil have a short in it,that why it cause this shutdown a have a loud electrical current noises.Tries websites like Shopjimmy.com.Ebay.com to buy a new refurbish power supply board for the replacement,should solved this loud electrical noises shutdown to tv.
Jul 10, 2010 | Sony BRAVIA KDL-40V3000 Television
Pioneer sd-582hd5 shuts off while watching
internal components probably need to be cleaned.... sounds like a problem with t.v. overheating
Jul 11, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Samsung plasma ppm42s3 , picture wobbling,sometimes screen goes blank
Hello arunaik_6,
This looks as if a component has become thermally sensitive. The best way to find this is to use component cooling spray. It looks as if the problem is localized to the tuner section. Take the back off of the TV and turn the TV on, wait until the problem occurs and lightly spray the tuner section with the component cooling spray watch for any reaction, then if this does not work spray the Microprocessor and the LVDS section and watch for a reaction. The set should go back to normal when it does that section is the problem, try to localize the problem to one component. Then replace that component.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 15, 2008 | Samsung PPM42S3 42 in. Plasma Television
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
322 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
