Question about Samsung SF-755P Laser Fax
SF-755P LASER FAX
When recieving faxes. The image is distorted (words stretched). It does not happen all the time. I've tried a new drum unit & a new cooling fan, thinking that might be over heating. Any ideals will be appreciated. Thank You
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 171 Answers
IF WORDS GET STRETCHED ONLY ON RECEIVING AND NOT ON PRINTING OR COPYING FRONM THE MACHINE, THE PROBLEM LIES WITH THE TELEPHONE LINE DISTURBANCE YOU MAY TRY GETTING THE PHONE LINE CHECKED /CHANGING THE CABLE LENGTH SETTING OR ATTENUATION LEVEL IN THE TECHNICAL MODE.. HAPPY FAXING OMNIPRESENT.
Posted on Sep 23, 2007
Sf5100 says recieve error
take the power out and hold the red button in. put the power back
Jul 21, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Hi we have a fax samsung sf-560r and recieveing fax and just going to memory and not printing..
press menu
#1943
menu again
look for new cartridge
it will print.
you can maby shack the cartrige befor you do this.
so that your prints can be better
May 18, 2011 | Samsung SF-560 Plain Paper Laser Fax
What does the fax drum do?
The Fax Drum Is The Heart Of The Machine.When you scan a page to send a fax or copy the Image of that is processed through laser unit & printed on the drum & after that the drum rolls on & prints the image on the paper & then the paper passes through the Heat Roller & the image is pressed on it & the copy or fax comes out.
Please rate me if it was helpfull..
Aug 04, 2010 | Brother IntelliFax-2820 Laser Fax
I have a samsuns SF515 fax machine after changing the toner cartridge the message still appears "toner Empty" I have tried several new cartridges with the same issue.
if you have changed the drum/toner unit then the machine should have a fuse on top of the drum unit.I have come across some cartridges that don't have them on the unit.The fuse resets the fax so that it knows there is a new unit installed.If that does work then clear the machines memory using the control panel
Jun 14, 2010 | Samsung SF-515 Plain Paper Laser Fax
What does it mean when there is a big smug down the middle of the received fax? Does it mean there is something wrong with the printing belt? Or that it needs a new ink cartridge?
does this happen with every recieved fax from every number... ? if so then the either the drum or fuser is bad... open unit and take a soft cloth and clean drum... look at the fuser see if you can match smudge to fuser or drum...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 09, 2009 | Panasonic Panafax UF-560 Plain Paper Laser...
Unable to send/recieve with my Samsung SF 565P fax
Plug a phone in to fax port, Is there a dial tone there also? can you dial a number and make a call from the fax port? You should be able to with a regular phone. If you can't, try plugging in the fax machine to the other port where your phone is plugged in. try sending a fax.If it works there, then the Vonage device or your service itself is the problem.
Apr 22, 2009 | Samsung SF-565P All-In-One Laser Printer
RECIEVED FAXES ARE TO LIGHT TO READ
take drum unit out, and locate blue tab on bottom of drum unit. take the tab and slide back and forth several times, making sure you return tab to the same side it was on. then, locate the small **** glass that covers your laser, which is located on the bottom of the machine right under where your drum would be, and clean that with a cloth and alcohol or windex. if that doesn't help, your drum may be worn out.
hth,
razors
Apr 02, 2009 | Brother IntelliFAX 2800 Laser Fax
Black vertical lines issues on Samsung multifunction fax SF
Black lines are usually a sign that you have toner on the laser slip glass which is usually situated above the drum unit, its just a little bit of glass if u give this a wipe and get toner on ur finger or rag then thats probably what wrong. If you don't I would look at your drum unit as it might not be cleaning correctly, which would mean getting a new one.
Hope you find this info helpful. Cheers
Dec 13, 2008 | Samsung SF-830 Plain Paper Laser Fax
Not recieving faxes ,can send not recieve
when you using fax you better shut off answering machine
Dec 09, 2008 | Samsung SF-531P All-In-One Laser Printer
NOT RECIEVING FAXES
You need to use the [MENU], [< >] and [ENTER] keys to browse through the unit's menu. Find and enter the "System Setup" menu and then search for the "Ignore Toner" option. Press [ENTER] and change the setting to "ON". Press [ENTER to confirm, the, [STOP/CLEAR] to get out of the menu system. The unit should start printing all faxes in memory.
Be blessed.
Nov 05, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF-755P Laser Fax Logo
114 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
