I need to factory reset my laptop to its out of box state. I have tried doing the "Press zero till it beeps" I have tried "hold zero on boot up" it took me to a screen that just checked all my stuff then sent me to login. I tried F12 and F8 and neither of those would work unless I did something wrong. On the menu where i can change bios and whatnot i loaded system defaults then saved and still nothing. Please help I really wanna reset it then rebuild up to my liking. I don't have any kind of recovery disk and nothing on this laptop is that personal to me.
The recovery partition is basically the same as the Toshiba restore CD if your model has one. The restore partition is located on a separate partition on the hard disk (if it has one).
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state.6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Restore Toshiba to Out of the Box Condition If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition. 1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook. 2. When the machine Starts beeping; release the 0 key. 3. When prompted by the warning screen; select Yes to continue with the system recovery. 4. Select Recovery of Factory Default Software; click Next. 5. Select Recover to out-of-box state. 6. Click Next again. 7. Click Next to Start recovery. 8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition. 1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on your notebook. 2. When the machine Starts beeping; release the 0 key. 3. When prompted by the warning screen; select Yes to continue with the systemrecovery. 4. Select Recovery of Factory Default Software; click Next. 5. Select Recover to out-of-box state. 6. Click Next again. 7. Click Next to Start recovery. 8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
The recovery partition is basically the same as the Toshiba restore CD if your model has one. The restore partition is located on a separate partition on the hard disk (if it has one). If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition. 1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on your notebook. 2. When the machine Starts beeping; release the 0 key. 3. When prompted by the warning screen; select Yes to continue with the systemrecovery. 4. Select Recovery of Factory Default Software; click Next. 5. Select Recover to out-of-box state.6. Click Next again. 7. Click Next to Start recovery. 8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
try pressing the f12 or whichever key it states on boot to get into the bios setting and check that it is set to boot from the hard drive and not a network
On some models of TOSHIBA laptops you can access the system restore partition by tapping on the 'zero' (0) during boot.
This will erase EVERYTHING on your drive and reset it to a "out of the box" state. So be sure to back up anything you want to keep before doing a system restore.
