Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Does not print clearly, dotted lined through letters, print light
This is Kodak 5300. Also need to know how to clean printhead
Installed new printhead provided by kodak free of charge
Posted on Nov 14, 2008
Everything i print has lines in it and the color is horrible..I put new cartridges in and aligned,calibraited it.still having same problems. it is a 5300 kodak all in one..
With the Kodak 5300 the print heads are separate from the ink tanks and when you have printing issues where you have lines or the quality is poor you need to clean the print heads or in worse case scenario you would have to replace the heads.
Here are the steps to clean the heads:
To clean the Printhead from the control panel on the printer:
  1. Press the Menu button to display the Main Menu.
  2. Press the down arrow until Clean Printhead is displayed, then press OK.
    • For a basic clean, make sure Basic Clean is selected, then press OK.
    • For a deep clean, press the down arrow until Deep Clean is selected, then press OK.
To clean the Printhead from the KODAK All-in-One Home Center Software on your computer:
  1. Start the home center software.
  2. If the Help toolbar is not open, click the Help (?) icon in the upper-right corner of the window.
  3. From the Help toolbar, select Maintenance.
  4. Click Printhead Cleaning, and wait for the printer to complete the cleaning.
Apr 14, 2010 | Kodak 5300 All-in-One InkJet Printer
My kodak easyshare 5300 prints lightly every 3 - 4 lines. New print cartiges do not help.
Have you tired to clean the printhead (deep clean) and also calibrating it? If yes it means the printhead that you are using is damaged, You may call kodak to have a printhead replacement toll free 1 800 421 6699 ext 02. I think their printhead is free of charge.
By the way you may also try to download the latest firmware of your printer at kodak.com/go/downloads
Nov 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My KodakEasy Share 5300 will not print in black.
92b8b47.jpgThe Kodak AiO printers 5000 series and ESP series PRINTHEADs has orange protective cap that need to be remove to fit on the printer carriage. For the ink cartridges 7b91cbc.jpgthere is also a orange protective cap.
Issue that its not printing black and deep clean and removing the printhead and reinstalling the printhead (reseating printhead) is already done and still no black when printing. The printhead should be replace. For futher assistance call 1 800 421 6699 Kodak AiO printer support line
Nov 16, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak Easyshare 5300 printer will not print black
Print a self test diagnostic page to check the status of the black ink and print heads.
To print the self-test diagnostic page
Control panel: Press (Configuration Page button), or press and hold the (Cancel button) for 3 seconds.
For models that support networks: Press (Configuration Page button).
If these are all showing OK then clean the printheads
To clean the printheads
If printed characters are incomplete, or dots or lines are missing from printouts, ink nozzles might be clogged and you might need to clean the printheads.
NOTE: Cleaning uses ink, so clean the printheads only when necessary.
The cleaning process takes up to 3.5 minutes. Some noise might be generated in the process.
Control panel: Press and hold (Power button), press (Cancel button) two times, press (Resume button) one time, and release (Power button).
If this fails then replace the black cartridge and run a clean cycle again and then a self test diagnostic then try printing again.
Sep 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Will not print and cannot install.
to solve the problem call 1 800 421 6699 for kodak support
DO THIS:
PRESS MENU>CLEAN PRINTHEAD>DEEP CLEAN (to solve the problem in light blue prints
Then print a demo sheet try to look at the colors if it is correct
SOFTWARE PROBLEMS:
delete kodak in the add/remove > uninstall microsoft.NET framework 2.0
WARNING! (unplug the usb cord at the printer before downloading the clear utility)
download the clear utility at www.kodak.com/go/clear > run it
then download the software
download the www.kodak.com/go/downloads for the software
Feb 01, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
KODAK EASYSHARE 5300 BLACK VERTICAL LINE ON ALL MY PRINTS Greetings. My name is Stephen and only recently, has my printer been acting up. I have had my share of troubles with it over the last year, but...
Check the paper path. It sounds like you might have a piece of debris laying down a line of ink when the paper goes past it. If that doesn't fix it, you might need another printhead. Kodak replaced mine without any problems.
Jan 30, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5300 printer
Hello donnam69,
You need to clean the printhead of the printer to solve that issue. Because everytime you print, excessive inks are going to the printhead that's the reason why it's clogging the system up. That's because Kodak printers is using "pigments" as inks that's why Kodak printers are producing high quality prints unlike other printers - a photo printed from kodak could actually last for about 100 years. Now back to your issue, you need to clean the printhead from the printer but not manually. You could clean it by going to the software of the printer namely the KODAK HOME CENTER SOFTWARE. You need to click the "?" mark icon on the upper right corner of the software window then under the General Links select Maintenance then choose Clean Printhead. Do it at least twice and then try making prints. If that still doesn't work try calling Kodak Technical Support Representative: 1-800-421-6699
I hope I have been some of help.
Nov 05, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Will not print red and prints with lines 5300 kodak
You will either need to replace a cartrige, or replace the printhead. To get a new printhead, cal 1.800.421.6699. Also try printing a cleaning printhead page.
Nov 03, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Lodak Easyshare 5500
More than likely doris you have an issue with the black text not printing. Press copy and photo at the same time. Look at the eyes of the kids in the picture. They're probably all white. Clean the printhead from the main menu. A deep clean. Print another demo. If it comes out the same, you need a new printhead. Call Kodak.
Sep 28, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
96 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
