Question about Panasonic CT-25G6 25" TV
The sound suddenly dropped down to hardly nothing and will not come back to normal.
    Sergeant:
  • 337 Answers
Try tapping the side of the set to see if it reacts,Audio output Ic's develop loose conections and hopely this is one of those situations and all it needs is resoldering,if you remove the back cover follow the speaker wires and they should take you close to were the output IC is,it is mounted on a heatsink,if the set is not stereo it could be a bad speaker.The loose conections or the speaker are two possibilities you can probably take care of but if you are not too familiar with tv service be safe and call for assistance from a servicer.Let Us know how it goes or if you need more information.
Posted on Nov 06, 2006
  • Omar Urrutia
    Omar Urrutia Nov 06, 2006
    Your rating response is also important.
My panasonic tau ct-34wx52 tv shut off by itself, now only clicks
Its power supply regulator section circuits need to to be troubleshooted.
Apr 26, 2012 | Televison & Video
Panasonic CT-27G14A
Have you tryed both the front and the back inputs?
May 17, 2008 | Panasonic CT-27SL15 27" TV
I have a Panasonic 32" tube television that is only 6 years old (Model CT-32D31) that we bought from Sears. We suddenly have nothing but a horizontal white line across the screen, which "grows" into a...
Sounds like 'bad' or 'dry' capacitors in the vertical deflection circuit. Please note that leaving the white line on the screen too long can burn in the screen, which is permanent damage.
Jan 31, 2018 | Panasonic CT-32D31 32" TV
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
2004 ford f350diesle hard starting depress throtle nothing there
Dear dsmalley427,
I think it sounds like a fuel injection problem. You get fuel for a while until the injector backs up and then all of a sudden NO FUEL. The engine quits and the pressure drops and flow returns enough for you to restart. If I were you I would get to a good mechanic and check the fuel injectors.
OR--try adding a fuel additive that would clean the injectors.--Signed jwr
May 10, 2009 | 2004 Ford F350
PANASONIC CT-27D30B
Maybe the vertical IC output are damaged you need to replace him
Sep 19, 2008 | Panasonic CT-27G14 27" TV
Won't turn on
Once you take the back off there is a glass gma fuse withing a few inches of where the power cord plugs into the board at. This should be a 6.3 or 6.5 gma fuse. Very common to blow in your model because the degausing coil is a little to big for it. There are other reasons for it to blow but 99% of the time you change change it and the set will work again. Let me know if you need more help or info!
Tim Nolan
Sep 11, 2008 | Panasonic CT-32HX41 32" TV
High pich whine from CT-36D32 36" TV
jdosk-the high pitch noise you hear is generally from the horizontal output being shorted,the horizontal output is usually near the flyback transformer,get a digital multimeter to checkthis part.Let me know I'll try to help. cooltek Feb.16/08
Feb 05, 2008 | Panasonic CT-36D32 36" TV
No picture no sound nothing
We had a TV repairman look at our 3 year old (Oct 2004) Panasonic CT-32HXC14J FLAT SCREEN TV. It suddenly stopped working and appeared to have no power getting to it. It was a high voltage supply or transformer that was bad and has to be replaced - estimated cost is around $400. In a year we will also need to spend around $125 for a digital converter box. We went for the repair since that is still cheaper than a $1,000 plus equivalent size LCD or plasma.
Our old tube tv was still working after 15+ years. They aren't making them like they used to. Way to go Panasonic.
Nov 09, 2007 | Panasonic CT-32HXC14 32" TV
Buzzing sound, no picture on my Panasonic TV
You might have a short causing the set not to start. Probably in the horizontal/high voltage circuit. The buzzing sound that you're hearing is the power supply overloaded. Stargazer
Apr 22, 2007 | Panasonic CT-27G23 27" TV
Panasonic CT-25G6 25" TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
