Question about Konica Minolta DiALTA Di200 Copier
Minolta dialta Di200 on screen :malfunction detected code:COO4E
I have a problem about minolta dialta Di200,the message on screen is this:a malfunction detected & provide code:COO4E.What does it mean?please help me,thanks.
  • Anonymous Mar 29, 2014
    printer
    driver download
  • 146 Answers
C004E: Power Unit Cooling Fan Motor malfunction
Check the power supply fan for proper operation.
Posted on Nov 11, 2008
Malfunction code C0040
Minolta copier show error code c0040. Please show me the picture that point of problem. The second problem. What is the way we could what kind of minolta di ...in the machine?thanks in advanced.
Apr 12, 2012 | Konica Minolta DiALTA Di200 Copier
Minolta Dialta Di200 malfunction
1-The C0500 code can be reset following the steps below: find a small
hole on the right side of the control panel. press it using a paper clip
2) When the dot appears on the LCD after reboot, press the number 3 key.
3) The mode will change to the initialization screen.
4) Choose the selection for trouble reset.
5) After reboot the code will be cleared.
good luck
Feb 10, 2010 | Konica Minolta DiALTA Di200 Copier
F-34-1 in konica 7055
This code refer to a fusing unit malfunction.High fixing temperature abnormality.The TH1(thermofuse) detects more 220 C.Possible causes the fixing heatre lamps or the thermistors defective.Verify the continuity,and verify the printer control board and the DC supply unit.Be sure to repair a defctive part before setting the 25 DIPSW 3-1 to 0.
Sep 26, 2009 | Konica Minolta DiALTA Di200 Copier
Message on screen, paper jam, then COBOF
Paper entrance switching motor M1 drive malfunction.For reset turn OFF,then ON the power switch or open and close the side cover or use trouble reset of the initial screen to reset all malfunctions.
Sep 25, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta dialta Di450 Error message C-143E
The Document Feeder has only 1 Malfunction code for any problem with it.
If opening and closing the front cover (while it is turned on) resets it and you can use the machine, dont worry about it.
The unit was prone to this false malfunction code.
If it returns very often, then get an engineer to have a look at it.
Jun 09, 2009 | Konica Minolta DiALTA Di200 Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Error c12c0 in minolta di 550
C12CX (X is any value) deals with the hard drive
1. Run “Hard Disk Format” selected in the following sequence: Tech. Rep. Mode - Function - Image Memory.
2. If the same malfunction persists, change Hard Disk Drive.
3. If the malfunction is detected a third time, change Memory Board.
To enter Tech Rep Mode:
1. Press the Utility key.
2. Touch Meter Count.
3. Press the following keys in this order: Stop - 0 - 0 - Stop - 0 - 1.
4. Select Tech. Rep. Mode.
Oct 28, 2008 | Konica Minolta DiALTA Di200 Copier
Error c12co in minolta di550
Copier not working
Is the copier a Minolta? If so what model there are different ways to rest code.
Feb 09, 2008 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di200 Copier Logo
1,015 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
