Question about Samsung SGH-G600 Cellular Phone
Add word in Uppercase only
When I go to the Add Word screen it only allows me to add words in Upper case only. How do I change to use mixed case?
  • karen.newnha Nov 12, 2008
    thanks - but doesnt work
Hold star button down to change from caps to small
Posted on Nov 11, 2008
I am asking or a password........pls help or get me help now
I'm a full time student and I stay up for days sometimes try a shift to Upper and Lower case look at your to row left , Lowercase 1 upper case !Exclamation, 2,uppercase @, Lower case 3 Uppercase # type lower case then upper case, hope that works
Mar 06, 2015 | AccessData Password Recovery Tool Kit (ftk...
Format changes
Not sure what application you are using but a thought would be that the style that is attached to the paragraph that you are copying the text to in the other document has upper case as a default. I have just tried this in word and it appears to affect the text that you are copying. Hope this helps.
Jan 15, 2014 | Apple MacBook Air
My key board is only doing upper key on word pleasehelp
Are you holding shift when you type?
do you have caps lock key pressed in?
Or Open Word, load your document Click Format in the main menu click change case in the sub menu Uncheck the box that says "Uppercase"
HOPE this helped please Thumbs up?
May 12, 2011 | Microsoft Windows XP Home Edition
Awesome App, BUT it won't separate my words. So if I write: This is a test, it writes thisisatest. Is this an app or user error? Help!
Check to be sure that the Recognition mode button (ie, the button that allows you to change between mixed, upper-case only, numbers only, and internet) is not on "internet". If it is on "internet", no spaces are inserted.
Mar 05, 2011 | Stan Miasnikov WritePad
Installed Belkin router sometime ago...now want to add password...how is that done..thanks
first you want to make sure you can access the routers dahboard to setup your password.the default ip address is 192.168.2.1 and username admin password admin Hi tech eh?
Once in navigate to the password option for the router and change from admin to new password.
Hint Have a password convention for yourself ie use you initials date of birth and mix the letters and numbers up also use upper and lower case. You can add your own spine to personalise it NOT GOD!
hope this helps
Sep 06, 2010 | Computers & Internet
Cannot save words in dictionary when typing messages
If u wanna add words to dictionary just press the upper arrow sign ( arrow sign is just below your typed content on the screen) and select add word..and ur prob is fixed........:)
Dec 07, 2009 | Samsung Star GT-S5233 Cell Phone
Change case for 1st letter in each new sentence line.
This is a setting you can change in the AutoCorrect options window.
Open a new document. From the Tools menu, choose AutoCorrect Options to open the AutoCorrect dialog box. Select the Auto Correct tab. In the list of options, uncheck Capitalize first letter of sentences.
Mar 05, 2009 | Microsoft Computers & Internet
Text messages type in very strangely
When ready to type the message pulse #key for 2 or 3 seconds and turn Prediction OFF and problem solved. It works for my Nokia 3555.
Dec 19, 2008 | Cell Phones
Passing PCL code from Word document
All PCL Command Sequences begin with the escape character (an ASCII control code with a hex value of 1Bh, 27 decimal) and end with the first upper case letter (or "=" note: "@" is considered an uppercase letter). In between there is either nothing (the PCL command is just the escape and a single upper case letter) or a set of one or two characters and often a numerical value. The single character commands are listed at the end of the "Decoded PCL commands" table below. The first non-uppercase character after the escape will be a symbol between "!" and "\" (most commonly one of %,&,( or *) which is called the "parameter." After the parameter there is normally a lower case letter called the "group." After this there may be a numeric value. If no value is present, the value is assumed to be zero. Finally the ending uppercase letter is called the "command." See Examples, Tutorials below for some samples of PCL commands and the Decoded commands List for detailed information. Note that these use the text "Ec" to mean the escape character. Since the escape character is not printable, it is very hard to convey in human readable text. Common abreviations are Esc, Ec, [], or <-. See the ASCII page for more information on the codes. That page also allows you to convert between hex, decimal or ASCII codes. The form below can be used to find english descriptions of PCL commands. Just paste the PCL into the box, if you use "Ec" or "esc" to mean the escape character, press the "Ec and esc
i hope this will work for you
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Feb 12, 2008 | Computers & Internet
Samsung SGH-G600 Cellular Phone Logo
46 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
