Question about VeriFone (M19755014US1) Magnetic Card Reader
Verifone omni 3750 ethernet problems...
When I first received the credit card terminal machine, I plugged the ethernet cable to the modem/router and then the AC cord to the outlet as instructed, since I could not get connected, I changed the IP address to the one numbered for my location, now my internet service company reassigned me another IP address but the machine remains powering on with the old IP info even if I unplugged it from everything, it does not accept the new one, how can I reset or unblock this old IP address without resetting the rest of the programmed info ? please help !!!
Chances are you would need to RAM FILES, FLASH FILES, DEFRAG FILES....this is like resetting and crashing the terminal, starting all over again.
Try this, press F2 & F4 together you should be on GO VARIABLES, enter password 1 alpha alpha 66831 use the down arrow locate RAM FILES, CLEAR ALL GROUPS, CONFIRM, FLASH FILES, CLEAR ALL GROUPS, CONFIRM, then DEFRAG, ALL GROUPS, CONFIRM
Plug in your DSL or cable line (the one you are using) locate the DOWNLOAD, do a FULL
this should pickup your new IP address and make sure you are on COMM SERVER not on DIAL
(dial is only for analog phone line)
Posted on Mar 07, 2009
Where do i look to see why machine isn't calling out to verify card
first check the phone line it self. take all phone lines out of the credit card machine, and unplug the power to machine. now take a telephone with a phone line attached and plug that into wall as if you were making a call on that phone. check for dial tone. if you have a dial tone, make a call. do you require a 8 or 9 to dial out? you terminal may not recognize that.
also if you do have dial tone do you use digital or analog phone lines? you need analog for terminals. if you have a fax line you can connect the terminal to fax via phone line. if this does not work contact phone co and ask what type of lines you have, you can also connect most terminals via Ethernet.
Jun 08, 2014 | VeriFone Omni 3730 Aka Vx510 Credit Card...
VeriFone VX510 TCP error 1009
your internet connection is not established check internet and Ethernet cables. may have to reboot your modem
Jan 27, 2014 | VeriFone Omni VX-510 Credit Card Machine...
How do i change the ink in my verifone omni 3750 credit card machine?
It does not use ink, it used a thermo printer, need th thermo paper.
Aug 23, 2010 | VeriFone Omni 3700
Slow input on Omni 3750
it needs to reprogram again.
erase all of memory and caches and re-install fresh file
most cases are fixed in that way.
Sep 18, 2009 | VeriFone (M19755014US1) Magnetic Card...
Add Credit to Gift cards with Verifone Omni 3750?
Get in touch with a gift card company or you processor (as many have programs) they will set you up with a program and cards and put the program in the machine.
Mar 10, 2009 | VeriFone Omni 3700
Our verifone omni 3750 credit card terminal started making a beeping sound and would not accept input. Sometimes you can unplug it and then it will work fine or you can press many different keys at the...
Depending on the type of business you are, the terminal can get pretty dirty on the inside and not look it on the outside. I had a florist contact me about similar issues with his terminal and after a good cleaning of the contact points under the pin pad the Omni worked fine.
Good luck
Sep 05, 2008 | VeriFone Omni 3700
Verifone omni 3750
here's some passwords you can Try: 1, 0000, 1234, 1701, 1739, 000000, 12345, 998877, 123456, 752036, 23378463, 45803155, 53664337, 1[Alpha][Alpha]66831, 6[Alpha]78727[Alpha][Alpha], Hope this help if not call us @ 775- 358-2922 : - )
Jul 09, 2008 | VeriFone Omni 3700
Verifone omni 3750
Use this Master Password from the manufacture #23378463
May 02, 2008 | VeriFone Omni 3700
VeriFone (M19755014US1) Magnetic Card Reader Logo
1,615 people viewed this question
Top VeriFone Televison & Video Experts
AliennoisE
Andrew Taylor
Andrew Taylor
Are you a VeriFone Televison and Video Expert? Answer questions, earn points and help others
