Question about VeriFone (M19755014US1) Magnetic Card Reader
Ethernet connexion IP address does not update automatically
When I first received the credit card terminal machine, I plugged the ethernet cable to the modem/router and then the AC cord to the outlet as instructed, since I could not get connected, I changed the IP address to the one numbered for my location, now my internet service company reassigned me another IP address but the machine remains powering on with the old IP info even if I unplugged it from everything, it does not accept the new one, how can I reset or unblock this old IP address without resetting the rest of the programmed info ? please help !!!
  • 74 Answers
Press the purple more key on the left of screen then scroll down to other setup then go to comm then keep pressing next untill you see ip address then press edit, put in correct ip address, press exit and ok for save changes. If password is needed try 0000 then enter or
1 alpha alpha 66831 which would be Z66831 then enter
Posted on Sep 17, 2009
Invalid ip address
im thinking your Credit processor IP settings have changed or your ternminal for some reason is not seing your processor IP settings and port. Calll your processor, and maybe you will need set the right IP address manually to your machine or they might ask you to redownload the application. Call (775) 358-2922 ask for Randy and maybe we can help you. Thanks
Jan 31, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
I have a linksys cable/dsl router with 4 port switch and also a linksys 16 port workgroup switch. I want to connect 10 computers to the internet with all automatically getting the dumby ip address. Can you...
When your 10 computers are connected to the switch, just make sure your ethernet cable is plugged into the ethernet port. The computers should then have a internet connection
Mar 03, 2018 | Linksys EtherFast 10/100 16-Port Workgroup...
How do I change the ip address of the Dell 1720 dn printer to work with my network?
Ok the following instructions will help you reset the ip address of your printer however you must use the origina driver cd to do this. Follow the instructions below if you have no print server involved with this network. If you do use a print server let me know ok?
Print and Check the Network Setup Page
  1. When the Ready/Data light is on solid, press and release Continue to print a menu settings page and a network setup page.
  2. Under the Standard Network Card heading on the network setup page, make sure Status is Connected.
If Status is Not Connected:
    • Make sure the Ethernet cable is firmly plugged into the back of the printer.
    • Plug the Ethernet cable into another wall outlet.
  1. Under the "TCP/IP" heading on the network setup page, make sure the IP address, netmask, and gateway are what you expected.
  2. Ping the printer and verify that it responds. For example, at a command prompt on a network computer, type ping followed by the new printer IP address (for example,
If the printer is active on the network, you will receive a reply.
  1. If your printer doesn't respond, or if the IP address is not what you expected:
    1. Insert the Drivers and Utilities CD into your computer.
    1. The Drivers and Utilities CD should launch the installation software automatically.
If the CD does not automatically launch, click Start® Run, type D:setup.exe (where D is the drive letter of your CD), and then click OK.
    1. When the Drivers and Utilities CD screen appears, click Set IP Address Utility.
    2. Select your printer from the "Configure Print Servers" list, and then click TCP/IP Settings.
    3. Make the necessary changes, and then click OK.
    4. Click Close.
    5. Print and check the network setup page to verify your changes.
Install Printer Drivers for All Clients
  2. The Drivers and Utilities CD should launch the installation software automatically.
If the CD does not automatically launch, click Start®Run, type D:setup.exe (where D is the drive letter of your CD), and then click OK.
  1. When the Drivers and Utilities CD screen appears, click Network Installation - Install the printer for use on a network.
  2. Select Install printer on one or more remote computers, and then click Next.
  3. Enter your Administrator user name and password, and then click Add.
  4. Select the clients or servers, and then click Next.
  5. Select the network printer you would like to install, and then click Next. If you do not see your printer listed, click Update to refresh the list or click Add Printer to add a printer to the network.
  6. Select your printer from the list. If you would like to change the printer name listed, enter a new name in the Printer Name field.
  7. If you want other users on the network to access this printer, select Share this printer with other computers, and then enter a share name that users will easily identify.
  8. Click Next.
  9. Select the software and documentation you want to install, and then click Install.
  10. When the Congratulations! screen appears, print a test page to verify the software is installed correctly.
  11. Click Finish to exit.
Aug 09, 2010 | Dell 1720dn Laser Printer
My laptop is wont connect to the internet?
check your cable if it is connect to a modem or DSL/ADSL router then it must be straight cable;for more information regarding the cabling go to;usually ip address and DNS address is assigned automatically by the modem or DSL set your network connection to obtained ip address and DNS address automatically untill and an unless you are given the ip address and DNS address to be configured manually. check your ethernet card is working by pinging to;hope it sloves your problem
Nov 17, 2009 | Computers & Internet
I have a D-Link DES-1108 Ethernet switch. I have my switch plugged into my router and i know the cable has connection but it still won't issue me an IP. Auto-negotiation is enabled on my router but it...
To determine if the router or the Ethernet switch is faulty.
Disconnect the Ether switch and connect the computer to the router and see if it connects to the Internet.
Next if you have a couple of computers, connect them to the Ether switch and see if the computers can communicate with each other. You may need to configure the LAN cards with a fix IP address (say 192.168.0.XX each computer must have a different XX number). Remember to change the TCP/IP configuration back to Obtain an IP address automatically and Obtain DNS server address automatically.
If these test are OK then the problem is the connection or route configuration. You do not need a crossover cable between the router and switch.
Get back to me with the results of the tests then I can advise you what to do next.
Nov 10, 2009 | D-Link DES-1108 8-Port Ethernet Switch...
Cant connect to xbox live need an ip address how do i get one
When the SurfBoard modem is powered up and connects to the internet on the WAN interface, it automatically gets an IP address from your ISP. When another machine is powered up and is connected to the modem via a USB cable, it is automatically using the WAN IP address to communicate with the world. If it is connected via the Ethernet connection, the modem automatically issues it its own IP address for use on the internal network via DHCP. The modem's internal Ethernet connection is The next machine powered on will normally get an IP address of
May 30, 2009 | Arris SURFboard® SB5101 Cable Modem
make sure the cable is in the correct place. (8 ping plug-little bigger that the phone plug.)
1). start>>control panel>>system>device manager.
make sure there is not "red X" or yellow!" ont he network card.
if that is OK. right click on "my network place" on the desktop>>local area connection>> right click on properties again.
you will see the network card name, and select TCP/IP under the " This connection use the following item" box. Click on properties.
make sure the " Obtain the IP address automatically and the "Obtain DNS address automatically" are check.
shunt down the computer
wait 2 minutes, restart the machine.
open the Internet Browser after the machine finished loading.
Dec 16, 2008 | Dell Dimension 4700 PC Desktop
Verifone omni 3750 ethernet problems...
chances are you would need to RAM FILES, FLASH FILES, DEFRAG FILES....this is like resetting and crashing the terminal, starting all over again.
Try this, press F2 & F4 together you should be on GO VARIABLES, enter password 1 alpha alpha 66831 use the down arrow locate RAM FILES, CLEAR ALL GROUPS, CONFIRM, FLASH FILES, CLEAR ALL GROUPS, CONFIRM, then DEFRAG, ALL GROUPS, CONFIRM
Plug in your DSL or cable line (the one you are using) locate the DOWNLOAD, do a FULL
this should pickup your new IP address and make sure you are on COMM SERVER not on DIAL
(dial is only for analog phone line)
Nov 11, 2008 | VeriFone (M19755014US1) Magnetic Card...
The device does not reassign new IP address via ethernet
Try leaving the Ethernet cable plugged into the machine and remove the power cord for say 10 secs. then plug it back in.
Nov 11, 2008 | GPS
D-link dss-5 setup (please help!)
you need to make sure that DHCP is enabled in the router settings and that your network cards TCP/IP is set to obtain an ip address automatically.
Also check that your computers workgroup is the same as your friends eg, Home or Workgroup.
Nov 03, 2007 | D-Link Express EtherNetwork DSS-5+...
VeriFone (M19755014US1) Magnetic Card Reader Logo
506 people viewed this question
Top VeriFone Televison & Video Experts
Andrew Taylor
Andrew Taylor
Are you a VeriFone Televison and Video Expert? Answer questions, earn points and help others
