Question about Brother MFC-8460N All-In-One Printer
Brother MFC-8460n paper jam
I have a 8460n with about 17000 page count on it and when i go to print, or copy any thing i get a paper jam. its like the paper goes through the drum part way and about 2 inches of paper hangs out of the fuser when it stops and says paper jam. tried a lot of stuff to fix this but not sure how to work on this thing.
  • rmooney Jan 05, 2009
    where might the paper exit sensor be at?
    President:
  • Brother Master
  • 990 Answers
Change paper exit sensor!
Posted on Dec 13, 2008
HAVE REPLACE THE DRUM AND TONER CARTRAGE AND NOW WILL ONLY PRINT ONE COPY AND SAYS PAPER JAM. OPEN FRONT PANEL AND REMOVE DRUM AND CLOSE PANEL AND THIS ALWAYS SOLVES THE PROBLEM BUT WILL ONLY PRINT ONE...
Welcome to fixya
I have a solution for this
Content
It sounds like you need to remove the toner cartridge and check for half broken pages below the toner. Some of the parts inside will be hot to the touch so take caution when attempting to remove the pages while the system is still hot.
Your pre-solution is located above. More information is available in the comments
My name is Bruce
Jan 20, 2011 | Brother MFC-8460N All-In-One Printer
My MFC8460N Brother won't print. It makes this
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
Feb 12, 2010 | Brother MFC-8460N All-In-One Printer
Overheats when printing pictures on transfer paper and now it will not print anything.
hi
i have problem with my brother prinetr MFC-8460N
IT SHOWS DOCUMENT JAM
ALSO MESSAGE ON SCREN
CLEAR THE SCANNER JAM THEN PRESS THE STOP KEY
STATUS SHOWS RED LIGHT
WE ARE NOT USING SCANNER WE ONLY USE FAX AND COPY
RIGHT NOW BLUE LIGHT IS ON FAX AND WHEN I PRESS COPY BUTTON IS NOT ALLOWING ME
PLEASE ADVISE
Nov 10, 2009 | IBM Infoprint Color 1357 Led Printer
Hi , My 4 in one printer get message Paper jam. MFC-8460N MFC-8460N
hello! i need to know where the jam is so that i may help you. brother tech
Jan 21, 2009 | Brother MFC-8460N All-In-One Printer
Mfc 8460n paper jam
Check to see if this happens when you use the drop down manual feed tray. If your printer works fine using the manual feed tray the problem is with your paper tray. Check to make sure it is set to letter size. I've found that sometimes the 'teeth' holding the paper stop on the paper tray wear out and when the printer goes to pick up paper, it pushes the paper stop out of position causing the printer to think it's using a different, much longer size paper thus preventing it from feeding all the way through. You'll probably need a new paper tray if this is the case.
Jan 06, 2009 | Brother MFC-8460N All-In-One Printer
Printing problems
If it is approx 3-4 smudges down the page. Replace the drum cartridge.
Oct 30, 2008 | Brother MFC-8460N Laser Printer
BROTHER MFC-8460N ALL-IN-ONE
I had a similar problem, more of a snapping sound than clicking, but this is what worked for me - pull the paper tray out and "loosen" the rear paper limiter by unlocking it, move it back about 1/8-1/4" and then re-lock it
Aug 19, 2008 | Brother MFC-8860DN All-In-One Laser...
Document jam brother mfc 8460n
you cannot clear this unless there is still a presence of paper inside the machine.
or you can open and close your machine once you are cleared of any paper jammed, be sure not to leave and removed all residual paper in the paper path, the tiny sensor would recognize any sort of this and thus make your machine unoperable.
Jul 25, 2008 | Brother MFC-8460N All-In-One Printer
Brother MFC 8460N Paper Jam
paper jams alway in the same spot- just as it's about to exit the bottom tray
Feb 08, 2008 | Brother MFC-8460N All-In-One Printer
Brother MFC-8460N All-In-One Printer Logo
357 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
