Question about Brother HL-2040 Laser Printer
Paper light keeps blinking red
There is no paper jammed in the printer, but the paper fed light keeps blinking. Any suggestions
  • A C Linux Nov 17, 2008
    I've unplugged it; tried holding down blue button while powered and when powering up; slid the corona wire cleaner several times; opened the back & front, taken the cartridge out, etc., etc.; unplugged the unit for a day, etc.,
    STILL get the Paper light blinking.
    -How do i truly -re-set- the unit?
    *problem happened after trying to print on 3x5 index cards; they jammed; (easily & entirely removed index card in one piece) but afterwards the Paper light just blinks an angry amber eye at me..no printing!! only got a couple hundred pages; otherwise I've liked this machine.
    Help?
Pull out the drum. There is a blue button on it - if you pull it out and look straight down at it, it should be on the right hand side towards the printer. Slide the blue button back and forth, left to right, 20 times or so. Make sure to position it back to the right side all the way when done and put it back in. It should fix it. It is some kind of wire that is dirty with paper dust, etc. Brother told me to do that very thing when mine was having the same problem. Now, if that doesn't work, I also use the dust remover canned air and spray inside where the drum fits.
Hope it helps.
Posted on Nov 13, 2008
In Brother's own information it states to -never- use the air-spray in their machines..that it can damage if used on the wrong spots, or can cause grit/dust to scratch parts, ie-drum, or push foreign materials into worse places.. **with caution**
Posted on Nov 17, 2008
Printer hp deskjet 840c blinking green and red light why
Depends which red blinking light. I assume the red light is the resume light. The green light is the power light. If the Power and the Resume light are blinking alternately, then you have a paper jam somewhere in the printer. remove the paper jam and you should be fine.
Mar 18, 2011 | HP DeskJet 840c InkJet Printer
Brothers HL-5370DW. Yesterday, I printed about 20 sheets with no problem. Then I set up to print more pages and the yellow paper light started blinking and the red status light came on. I checked for a...
I had the misfortune of between two sheets of paper, out of the packet, there was a piece of tape that jammed the drum.
Nothing else for it with your, take the drum and toner out and check for bits of paper.
Mar 11, 2017 | Brother HL-5370DWT Laser Printer
Ip5000 printer worked perfectly but now comes up with three orange lights stating a paper jam. There is no jam. Shop says it is a timing problem but suggested a new printer. Paper roller keeps rolling...
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Hope this will help or else you mother board has errrors.
Sep 28, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
How to stop red blinking "paper"? couldn't stop
There is probably a paper jam since you shut it off as it was printing. Turn off the printer. Remove the tray and look inside. Remove any sheets of paper you see. Open the back of the printer (the pass-thru door) and remove any paper you see. Turn on the printer. If that fails, check the blink status against the manual's troubleshooting guide to locate a different solution.
Aug 27, 2010 | Brother HL-2040 Laser Printer
Paper jam/no paper fed
make sure the photo paper is in glossy side face down,
set the paper type to photo.
If it keeps jamming it's because the paper feed is probably dirty and not taking the paper properly
Mar 24, 2010 | Brother DCP 130C All-In-One InkJet Printer
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Xante 1200, paper jam front. Red light is blinking without a paper jam.
PROBLEM: Paper Jam. XANTE 1200, Tabloid size, B&W, Printer —Red light blinking fast indicating paper jam upfront. If you checked everything, trays, ink cartridge etc., and see no paper jam anywhere, take the top cover off and look inside the (head) for the jammed paper! This printer is problem free. It has given us the best service for many years.
Michael J. Frangos, Baltimore, Md.
Feb 04, 2009 | Xante AW 1200 Laser Printer
Cannot print
If this is a 2200dtn, have you checked the duplex turn around tray under the printer? You can access this by removing tray 2, inside on the front left you should see a small green tab which will release a drop down tray. Many times a sheet or even just a piece of paper can get lodged in the sensor causing a paper jam condition.
Nov 21, 2008 | HP LaserJet 2200dtn Printer
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Brother HL-2040 Laser Printer Logo
52 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
