Question about Gateway 505GR PC Desktop
Flashing Green Light next to voltage switch
Hey Kids! I guess I've got 2 problems 1: My system stops booting at the "Gateway" splash screen and the hard drive light stays solid orange. I have to keep shutting it off and back on, then after doing this 4 or 5 times the system makes it past the "Gateway" splash screen and I'm up. Problem #2: Now the green light next to the voltage swith is "flashing" and the power on switch does not respond? Anyone?
    President:
  • 2,961 Answers
For problem #1 there is a MBR (Master Boot Record) problem, meaning that Windows is unable to find Windows. This can either be a software problem or a hard disk failure. If you have your Windows XP disc boot up with it in your cd drive and when it starts press 'R' for repair as this wil repair system files and you will not lose any settings or doc's. When you are running go to your hard disk drive manufacturer and run a diagnosis and repair if neccassary. Problem #2 should sort itself out if left unplugged from the mains supply and the power supply unit for 15 mins or so. If not there is a power supply that needs replacing.
Posted on Nov 07, 2006
Mitsubishi WD 62725 - Message indicating impending lamp failure, followed by lamp failure. Replaced lamp and noticed a flashing green light. Pressed reset button and also disconnected for 12 hours. Upon...
Hi James,
First of all thank you for posting your question here at Fixya.
Flashing of the LED light green has two error code.
1. Lamp Fan failure - if the lamp LED at the front panel blinks green, this is an indication that there's a malfunction on the lamp fan. You've mentioned that you've replaced the lamp, please make sure that the connector of the fan and other connectors are securely connected. Double check it.
2. DM boot failure - If the Timer/Power at the front panel blinks green for more than 1 minute, this is an indication that the DM failed to booted up. I have a link where you can buy DM repair kit, click it HERE, it includes parts that are know to be faulty, illustrated instruction that will guide you in the whole process of repair. Your unit is a V26 chassis, when you are on the link, you can see two version of the DM repair kit for V26 chassis, one is the same working voltage of the capacitors and the other one is the upgraded version. It's up to you if you are going for upgrade or not.
Please let me know if you need further assistance.
Have a great holiday!
Kind Regards,
Mjsazon
Dec 23, 2011 | Televison & Video
I have a Liftmaster 2000sdr 1/2 hp garage door opener. It stopped halfway through the cycle and is giving a 5-light error code (RPM sensor or motor overheat). When I try to run the system all I get is 4...
SORRY TO SAY IT SOUNDS LIKE A FRIED CIRCUIT BOARD. LEAVE THE UNIT UNPLUGED FOR AT LEAST 30 MIN. & TRY AGAIN, IF SAME RESULTS I WOULD REPLACE THE BOARD.
HOPE THIS HELPS
Oct 17, 2010 | liftmaster Chamberlain Garage Door Opener...
My keyboard on my other computer is not working - I can't type my password in so I can start my computer -- the computer seems to be working ok! Its a gateway computer
Two things are a possiblity
1. Your keyboard has a short, and you have to get a new keyboard.
Or
2. The cable is unplugged (I'm sure you've checked) but hey it's a possiblity
May 13, 2010 | Gateway GT5220 PC Desktop
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
Fry's wireless g router
I found this on this site:
2Wire 2700HG-B Setup
1. Connection of phone line, ethernet and power adapter
2. Indicator light: POWER: green; Ethernet: blink; DSL: green; Internet: blink or red
3. Open IE beoswer.
4. address: 192.168.1.254
5. Click "Run System Setup Wizard"
6. Login with preset password: admin. Or change password: click "I forgot the password." Under question "Here’s a hint for the password wedding date", click "I still can’t remember the password.". Then Reset System Password by enter System Key which locate on back of the Router (like: [1234567890]), and your new password, then click "Submit"
7."Set Up Your 2700HG-B Gateway" screen. Keep default "Key Code". Click "Next"
8. "Time Zone". Select your time zone,then click "NEXT"
9. "Set Up Connection Info". Enter "PPP Authentication" information provided by internet service provider. "Username", "Password", and "Confirm Password", then click "NEXT"
10. Screen "Connecting" running...
11. Auto turn to screen "2700HG-B Gateway Setup Complete", click "FINISH", or "EXIT" to complete setup or "Register" to register with 2WIRE on line.
Jan 28, 2010 | 2wire 2700HG-B Router (2700HGB)
Flashing green light
i loose vga video controller
Nov 16, 2008 | Dell OptiPlex GX260 PC Desktop
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
DELL GX260 bootup problem
To start with I would run FDSIK from a DOS boot disk and delete the partitions on the hard drive. Then reload the operating system. There is no telling what has been loaded on the system. After the reload the DELL should boot normally.
BPCS
Nov 15, 2007 | Dell OptiPlex GX260 PC Desktop
Gateway 505GR PC Desktop Logo
299 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
