Question about Technics SL-1210 Turntable
Both working one day and then wont the next??
I literaly had a mix one night and then went to switch both my decks on the next morning and they are dead??? I have checked both of the fuses inside both decks but they are fine, i have changed the fuse in the plugs but no joy??? im getting really confused could it be the power supply??? If it is how do i check where do i get the parts and how much is it gonna cost? I just find it really wierd i could understand one but both is just plain odd?
  • 4 more comments
  • dj_dubbzie Nov 11, 2008
    no ive had it in different rooms defo not the power outlet! its just really strange! i've never known anyone else thats has had this problem
    can you explain how i would test if it was eithet one of those componants?
    nope defo something inside of the deck preventing them from working
    right, is this a common problem that people have?
    yeah there was a power cut so its looking more like its the transformer! is there any other likely things it could be before i pay £35 easch for 2 new transformers???
    Genius:
  • 2,035 Answers
You can try to replace the power circuit board on the unit :if you want the part you use this link to get part number for the unit ,,Please click here and enter the model no and you will get the parts list ...
Good luck...
Posted on Nov 11, 2008
    Genius:
  • 1,550 Answers
Its enough to change transformer.
But did you check for any faulty capacitor on power board ?
If you have not checked have a check over it .
    President:
  • 624 Answers
If you remove the bottom, you can find the fuse. It is a glass fuse on a small board. Just follow the A/C cord into the unit and it will be on the same board that the A/C is soldered into. That would be the first thing to check after you make sure that the unit is properly set for your A/C outlet. This unit has a switch on it for 50 or 60 hz, depending on what country you live in. U.S. is 60 hz.
The bottom has a lot of screws to take out, but it is not difficult to do, just time consuming. If you need a manual, I can email it to you.
Dave
    Brigadier General:
  • 6,966 Answers
Initially, was there anything out of the ordinary after you used the units? Say a power outage/interruption, thunderstorm or near lightning strike?
As you implied, both to go dead simultaneously is odd. It has to be an external factor. In any case, pls start diagnosis on the transformer/power supply. You would need a continuity tester (DVM or VOM). Additionally, if your version uses an external power supply, you may want to start checking if it has an output (34V DC) or the built-in regulator (21VDC). The illustrations on this page may be of additional insights as well as some of the discussion here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 11, 2008
    Hi again,
    The transformers could be easily checked with the use of a continuity
    tester (VOM/DVM). Priority concern would be the primary side. Using the
    multitester/continuity tester, there should be a reading and not "none"
    no deflection/display. When you connect the two (2) testprods (red
    & black) to the two wires/terminals of the primary side of the
    transformer, the meter/display should show a resistance.
    Alternately,
    you could disconnect the transformer (just make notes how it is
    placed/connected) and ask any electronics technician/store/shop to
    check the continuity for you.
    Again, an open primary would
    require replacement. On the other hand if the transformer checks out,
    then it would be any of the components of the power supply.
  • Louie  Role
    Louie Role Nov 15, 2008
    Hi again,
    Any development(s) so far?
    Master:
    Sergeant:
  • 449 Answers
Hi!!
try to check the power
use a tester on it
  • 728 Answers
Try it in a different power socket and see if that makes any difference. Then check to make sure a short did not occur while you had the mix by moving the cord around at the back of the turntable and see if anything happens power wise.
    Genius:
  • 1,250 Answers
If you are not sound in technical knowledge its better take your device to the technical person, the fault is in the power supply , some times its not necessary to replace the whole supply a minor resistance or capacitor change will be ok
    President:
  • 1,952 Answers
Voltage may not enter into it...check the internal parts
  • Technics Master
  • 19,396 Answers
CHECK THE POWER OUTLET FIRST.
The power supply is rather unlikely, unless the two tuurntables share the same power supply.
  • Ginko
    Ginko Nov 11, 2008
    Start concentrating on a single turntable first.
    Try first a different power outlet, do not use extensions or adapters.
    Double check the fuse in the power plug, replacing it again.
    The only possibility that both turntables had gone at the same time is if there had been a power surge or a major problem with the AC power, such as a short.
    Even in that case it is quite weird that both units had gone at the same time.
    Get a multimeter and start testing the power cord. Check for continuity, if it has infinite impedance, then replace the cables.
    If cables are ok, then units must be taken apart and component inside checked, a component that blows quite often are the capacitor on the power board area of the circuits.
    I still think it is probably the power outlet, or a faulty extension.
CAR WONT START
CKP sensor or cam sensor. one goes bad and causes other to go bad. easy fix and not too expensive.
Mar 13, 2014 | 1999 BMW 318 ti
No display after installing Biostar motherboard
THE DRIVERS MAYBE ? .
THE MONITOR ? .
YOU HAVE TO EXCLUDE ONE THING AFTER ONE OTHER.
Jun 13, 2013 | Biostar Computers & Internet
Toshiba REGZA 40E200U 40 LCD TV wont turn on after it was working fine the night before.
Your TV needs servicing, Most likely you have a power supply related issue. Do you have any experience with electronics repair?
Sep 01, 2012 | Toshiba REGZA 40E200U 40" LCD TV
My van has an old security system it dosnt work since tow three years.Now a days my vehicle starts it remain one or two days works whenever I start but some time it didnt start. I left for whole night...
I agree with the mechanic..
I would have someone remove the security system all together from the van...
You dont mention what model van ... or year... so it's hard to discern what to do from this point.
Oct 06, 2010 | Vehicle Parts & Accessories
Push button to start and does not start
Your problem could be with the "push to start" switch or "door" switch.
Apr 14, 2010 | Roper RES7648E Dryer
Dead TV Panasonic CT 36HL42CF
have a visitation and bury the next day.
Jul 14, 2009 | Panasonic CT-36HL43 36" TV
Engine won't crank
i have the same problem my avalanche wont crank, and the fuel gage dont go up, when the fuel gage works the truck starts but its been two days and it wont crank plz help...
Jun 27, 2009 | 2002 Chevrolet Avalanche
Car wont start in the morning
a toggle switch will work as long as you put the right fuse in it..Good Luck
Mar 23, 2009 | 1987 Chevrolet S-10 Pickup
2001 chevy s10 wont start
no it comes on when you turn the ignition.
Nov 11, 2008 | 2001 Chevrolet S-10
1210 mk5g pitch adjustor
switch off for a will and see.
if still bad. check the circuit board under.
with old electronic devices, capacitors are commly the ones that may go wrong/dry. which would cause oscillatory circuit to generate wrong signals or strobe or feebacks. if you know how to take out the circuit board, check it starting from capacitors.
Jan 22, 2008 | Technics SL-1210M5G Turntable
Technics SL-1210 Turntable Logo
26 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
