Question about Uniden Cordless Phone
Noise before dial tone
My Uniden phone, base and cordless units, makes a duh, duh, duh, duh, duh noise before I get a dial tone. Is there anyway to get rid of that noise?
  • Anonymous Mar 24, 2014
    Tell me how to get rid of strange dial tone
That usually means you have messages waiting. clear your messages and that should stop.
Posted on Nov 13, 2008
I not have manual for Uniden dect 6 cordless phone on my phone I can't get any dial tone,I think I pressed a button on the phone either mute, intercom or redial, how to reset phone
If you have no dial tone the problem is most likely the base station has failed, nothing you can do will kill the dial tone (no button you pushed etc.) except a failed base station.
Dec 19, 2016 | Uniden DECT 6.0 Cordless Phone
GE 900 Mgz cordless phone, model 26936GE2-C
How many handsets do you have on this system? Just the one for the base unit?
May 21, 2008 | Uniden Cordless Phone
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
No connectivity cordless phone
Sorry you are having trouble.
Try this: Remove batteries from phones and re-insert.
Unplug base unit
Leave unplugged for about one minute.
Plug in base unit
Check for dial tone
If this does not work then get a non wireless phone and verify that you have a dial tone.
Apr 04, 2010 | Uniden Cordless Phone
My Uniden wireless phone doesn't have a dial tone,
I would be willing to bet that it's the line cord that is plugged into your phone's base unit. Try a different cord, and/or try it on a different jack.
If it's neither of these, see if any phone you have gets dialtone. If no phone gets DT, contact your service provider. If other phones work, and the new cord didn't fix your Uniden, then chances are that the jack has been ripped from the circuitry. If that's the case,
contact us at IdacomUSA and we'll be glad to set you up properly.
Jun 17, 2009 | Uniden EXS9950 900MHz Cordless Phone
No dial tone, just buzzing noise - should be 2 line phone, 1 jack
What you need is a dsl filter since you are working off a splitter. You can usually get these for free from your phone company.
Mar 20, 2009 | Uniden TRU9466 Cordless Phone
No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Sep 25, 2008 | Uniden 2.4 GHz Cordless Phone System
No dial tone
my base unit did the same.... power from the wall was out ... check GFI switch.
Sep 15, 2008 | Uniden Cordless Phone
Dial Tone but won't call out.
I just had the same problem. Try unplugging the plug from the electrical outlet for the home(base) unit and plugging back in. Fixed my problem right away.
Jul 26, 2008 | Uniden Cordless Phone
Uniden cordless phone
Hello, While I cannot locate that model in any Uniden database (you might want to find the literature), It sounds as if the handset may be communicating with its base, but you have lost the dial tone. Did any storms pass through recently? Here is what you do. Go to your base and push the locator button on your base station to call the handset via the page/locator function. If it rings the handset and you can answer it okay then you know your handset is working well and communicating with your base (the radio portion is working correctly). If it does not ring your handset then your Uniden is definately bad (radio wise). But, I am going to guess that it is okay but you still cannot communicate with the outside world and dial out to get dial tone or get an incoming call. Okay, so we have a dial tone problem. The next step is to see if dial tone is getting to your base. So you will need to take another good telephone, preferably a handy "line powered" telephone (no batteries or ac adapter needed) you can use in a power failure emergency. Take that good phone and plug it into the phone cord you unplug from your Uniden base. If you get dial tone, then your uniden does need repair. If it does not get dial tone, then you have a bad cord, jack or something in your phone wiring. If thats the case, change cords, look for corrosion, dirt or bent pins in the jack on the wall. My guess is that your Uniden has gone bad, likely from a slight surge on the phone line. If you do need your Uniden repaired you can contact Uniden they are at http://www.uniden.com/repair/service.cfm , however I don't believe they offer repair, but offer to sell you a replacement. Or you can go to www.cordlessrepair.com where you can get your Uniden Cordless unit repaired, not exchanged. Good Luck, CG
Feb 18, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
222 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
