Question about HP LaserJet 1010 Printer
Hp LaserJet 1000 series printer error message on front door cover and toner cartridge missing
With an error message on front door cover and toner cartridge missing my dependable printer of 6 years is not working. I have tried reinstalling, using a new cartridge, etc. without luck. I have a 1000 series not 1010
  • 7 more comments
  • dineshkumarg Dec 13, 2008
    The HP LThe HP LaserJet 1000 has the front cover door open or the cartridge is missing. But there is cartage and as well as front door is close. althaugh this message is printing and i am unable to print any thing.
  • franklinstah Jan 02, 2009
    Yes, I have used genuine HP cartridges. This same cartridge had been working. I also used it in another printer and it worked. I borrowed a cartridge from another printer and this printer did not work.
  • Anonymous Jan 02, 2009
    I have tried to reinstall the drivers from the CD many times.
    I tried to uninstall and reinstall about 4 times without any luck. Sorry, didn't you read my first description.
  • surya069 Jan 16, 2009
    hp 1000 laserjet printer front cover doesn't open.
  • style_126 Jan 30, 2009
    this problem is really annoying,
    and unfortunately I am facing the same problem as franklinstah....
    does anyone know how to fix it?
  • Anonymous Mar 01, 2009
    Folks....I have given one has a solution...I have trashed it. Too bad for HP on this one. It was a workhorse.
    Good luck to anyone else.
  • Anonymous Apr 20, 2009
    ur manual feed tray is working???
    ive got the same porb rite now
    and i was searching for solutions
    my manual feed tray is working... but the regular tray is not...
    must be some sensor prob in there.....
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    Are you using GENUINE HP cartridges?
    Problem Solver:
  • 6 Answers
ijust solved this issue
WHOA ...
my printer is HP 1020,, and i was printing a huge number of sheets, which USED TO GET STUCK IN AGAGIN AN AGIAN... coz, i was using a low quality damned paper..
now,, it began to gave error ,tht either the front cover door not closed , or its toner cartridge missing.
Well,, simple solution for me was (which is basic i think)
>> Remove the metallic plate on the back of the printer
>>there you 'll find , on the right side, near the socket for poer cable, a "lever" like thing, thats the lever for the "barrier" between the SENSOR... move it and u'll get an idea..
>> if its jammed ,, then free it..
(mine was stuck into dont know wht, and i freed it, and all is fine)
>> if spring adjusment is wrong, correst it(you may get idea by moving it again n again, whether it comes bbacl to its orgignal position or not...
> remore the tonor cartidge and insert it back while looking on the lever movements.... and you ll get whats the matter with it..
PLEASE note it,,, that i think,, the sensors are NEVER damaged !!! mind knowlegde says , sensors are hardly damaged ..
-----Adios.... Tauseem Omer...Ravian Kemcolian.
Posted on Sep 12, 2009
    New Friend:
I followed tauseefomer's advice and opened the back metalic panel; I found a small piece of paper jammed in the bottom black rollers which, once removed, cleared the error message on front door cover/ cartridge. It is now printing normally!
    New Friend:
Thx. tauseefomer 's information was useful to me.
Posted on Jan 27, 2013
Replace - under $100. Basically the price of a cartridge
Posted on Feb 28, 2009
How can fix this error. i seen this "the hp laser jet 1018 has the front cover door open or the toner cartridge is missing"
Hello !!
For tha particular error you are facing, here is the reason. These printers have a switch that triggers an interrupt when the toner door is closed. Usually there is an arm on the door that pushes the switch. It is quite sensitive and delicate. Then sometimes there is a tab on the printer's toner and if that breaks off then that error will be generated.
But in your case as you have not removed or inserted the toner, I think option 1 is applicable to you.
Now, if this printer is in warranty you should send it to HP for Free repair/replacement.
and chek BLOW links too for paper jam and cleaning
Paper jam Message Displays for HP LaserJet 1018 1018s 1020 and 1020 Plus... Cleaning the Printer
Dec 23, 2014 | HP LaserJet 1018 Laser Printer -...
HP LaserJet 1020 won't print. Error: HP LaserJet 1020 has the front cover door open or the toner cartridge is missing. The door is closed and the toner crtridge is installed properly. I tried to upgrade...
Did this just suddenly happen or was it after you replaced the toner cartridge or opened the door?
I have found that if the toner cartridge is not completly positioned into the printer, it can give this error.
Feb 23, 2011 | HP LaserJet 1020 Printer
The hp laserjet 1020 the front cover door open or the toner cartridge is missing
Open The printer Side Cover. Then Remove Back Plate Of Printer There is Senser On Back Side Check They Are moving or not there is spring in senser
Feb 07, 2011 | HP LaserJet 1020 Printer
The HP Laserjet 1018 has the front cover door open or the toner is missing
You need to perform following steps:-
Open the door of toner and close it properly
take out the toner cartridge and insert as directed in manual
clean the electric contacts of cartridge and printer
otherwise you need technical assistance for repair
Good Luck
Jan 31, 2011 | HP LaserJet 1018 Printer
Hp laser jet 1018 giving error that front door is open or toner cartridge is missing
If you are using a non genuine HP cartridge, it is very likely it is defective and can not read the chip on the cartridge. Replace the toner with a Genuine HP cartridge.
Jan 12, 2011 | HP LaserJet 1020 Printer
Front cover dore open or cartridge missing
Try reseating the ink cartridge and see if the cover door is firmly closed.
Mar 27, 2009 | HP LaserJet 1020 Printer
Printer suddenly stopped printing
verify if you are printing with the correct paper size..... long is 8.5 by 13 and not 8.5 by 14.....
1. delete the installed driver
2. turn off the printer and let your computer detect the printer.... let it finish
3. restart your computer
Nov 09, 2008 | HP LaserJet 1020 Printer
HP Laserjet 1000 series problem
First close the front door then try printing.
if problem persists contact to fixya again
Aug 19, 2008 | HP LaserJet 1000 Printer
HP LaserJet 1010 Printer Logo
1,773 people viewed this question
Ben Johnson
