Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Filter Release Catch removal
Thanks for your help with this problem. I understand what you mean, but the part that forms the bend in the bottom of the pipe is in the way. As I said, I have removed what looks like the retaining screw on the bottom but although this loosens it, it will not come free far enough to bet to the back of the green retaining catch to be able to tap it out. I don't want to force it as you say it is very brittle. Do I need to take another part off first?
  • 43 Answers
Yes sorry i know what mean you need to remove the motor casing to reduce the risk of breaking any parts. Lay dyson on the front and remove the bottom plate and roller bar. Now you need to remove the belt from the motor pin lay on left side look t the round clip located next to the wheel which is holding the whole floor atachment to the chasse. Remove the clip with a flat ended screwdriver then flip to opposite side and repeat the same. The floor atachment should be moved to the down position as far as possible. now you can remove the the bottom attechment starting from the opposite side to the belt now undo the four screws on the bottom of the chassis and remove the screws under the other filter on top of the moter now remove the top cover now the piece in the way should move out.
Posted on Nov 11, 2008
The dust collecter is stuck and won't release from the vaccum. how do i release it to empty.
Make sure you switch off the vacuum cleaner.
Here is the instruction to remove the bin
Press the cyclone release catch with your thumb to remove the
clear binTM assembly from the machine.
• When removing bin, do not pull up on carry handle while pressing cyclone release catch
• When replacing the bin, ensure it clicks back into place.
Dec 31, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Diagram to take filter apart
Hi Teresa, it's Jack at Dyson.
If you've lost the spring from the cyclone release catch we should be able to order a replacement for you. Just get in touch with our experts directly - you can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jan 17, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a DC07 which is not picking up very well. I've cleaned the pre motor filter, was not aware of the post motor and will check. However, do the Dyson brush rollers wear to the point of not picking up...
Hi The filter is only part of the cleaning process with a Dyson.
I would suggest you get a 2 p peice and unscrew the plastic screws on the base. You will likely find that this area has clogged up. Clean this area out and put soleplate back on.
Also check your u bend and at the side of the Dyson there is a a piece called the valve carriage which also comes off.
You can put your filters, u bend and valve carriage release in the washing machine.
Feb 23, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
There is no suction to our Dyson animal (purple-approx 8 yrs old)
Hello bnsbryan :
1: Check that the Dyson's brushbar knob is turned to the "Carpets" setting for vacuuming non-delicate and raised pile carpet. Vacuuming carpet on the "Bare floor" setting usually leaves a telltale single wheel mark on the pile, and pickup is severely limited.
2:Locate the removable filter on the side of the vacuum. It will be marked with a raised circular representation.
3:Press down on the release button with your thumb as you lift filter housing up and out
4:Examine the filter for debris. Wash the blue foam and yellow framed filter in cold water. (See Tips section.) Let dry for 12 hours. Do not wash the outer filter housing that snaps into the vacuum; simply wipe clean with a dry or slightly damp cloth. Replace the filter when completely dry.
5:Locate the airway inspection valve on the opposite side of the vacuum. Press the release button as you lift the valve up and away from the machine.
6:Remove any debris or clogs you find inside.
7:Use a soft cloth to clean up lighter debris and completely clear the airway valve.
8:Tip the Dyson vacuum over to find the U-bend at the back of the unit. Press the release button as you pull the U-bend down and away from the machine.
9:Inspect the U-bend and remove debris. Be sure to line up the release button as you snap the U-bend back into place.
10:Check all removable pieces to be sure they are attached properly and snapped correctly into place. The soleplate should be flush with the cleanerhead.
What you need for this :
  • Large slotted screwdriver
  • Scissors
  • Washcloth
  • Soft cleaning cloths
  • Household surface cleaner, safe for plastics
  • Crochet hook or similar long-handled tool
Warning :
Unplug the vacuum before doing any troubleshooting. Follow all manufacturer's instructions and warnings. The yellow encased filter and blue foam filter pad can be submerged and rinsed in cold water only. Do not use detergent. Do not wash or dry in dish or laundry machines. Do not dry in the oven or microwave.
Apr 22, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hi its Darran at Dyson.
You would need to release the wand/hose assembly from the machine then slide the hose right to the bottom of the wand and press the release catch to disconnect from the wand. Then at the base of the hose you shoudl be able to un-clip the hose to remove it completely from the machine.
Full details on how to check your amchine for blockages, can be found in the Support section on our website at
Kind regards
Dyson Customer Service
Jan 13, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do you remove the HEPA filter on Dyson DC07
I use a screw driver to pry them up.
Nov 07, 2009 | Dyson Vacuums
My dyson dc07 seems to take awhile to build proper suction... is this normal?
no it should pick up as soon as you turn it on, make sure the brush is turning if it is then turn the unit off, make sure the the washable filter is clean and the the bin filter is also clean, if this does not work then there one more thing if you can try, remove the bin from the unit release the bin flap and with a torch look down the end of the cyclone you might find a large blockage this vry common in the dc07 hope this helps
Oct 20, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
if its the part im thinking of its a small spade like catch thats glued into a hole in the chassis normally id lay the machine on its front and gently tap the old catch out with a flat end screwdriver and a small hammer be carefull its very brittle
Nov 11, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson animal
Is the noise a loud screaming or a grinding/vibration? The screaming is an air flow problem and you'll want to check your hoses are clear and all the seals are tight. The grinding is an issue with the roller/belt/clutch/motor/housing. From what I'm reading, both problems are common on the Dyson animal.
Sep 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07
turn your dyson over so you can get to the bottom undo the screw and then you can see the bottom of the clip a gentle tap with with a screw driver blade will knock it out and the other one slips in
Jun 19, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
313 people viewed this question
Top Dyson Vacuums Experts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
