Question about IBM Computers & Internet
Screen resolution Hi I have a IBM thinkpad, i cannot seem to get the screen resolution to be brighter, it's like looking at it through dark glasses. is there some special trick? please help. Laura
  • Anonymous Jan 21, 2009
    I have also the same problem, about my IBM think pad, my LAPTOP screen is seems to be in dark colour,thedisplay is not displaying
    Guru:
  • 558 Answers
Check the screen and increase the contrast ans setup some brightness accordingly there. Use the button present on the bottom of screen of Laptop to change it.
It will solve the Screen brightness problem.
 And for Screen resolution you will need to change the Display properties by Right click with mouse on Desktop, then go to DISPLAY SETTING and Select the resolution viz: 1024 X 768
or 800 X 600 or 1600 X 900 pixels.
That will give you best screen  resolution. Thanks
Scott
Posted on Nov 11, 2008
    Genius:
  • IBM Master
  • 1,250 Answers
HAVE you tried the key Fn along with the key that marked brightness sign togehter
I have an IBM ThinkPad running Windows 98 Second Edition used to program older radios so it needs the older version of Windows. The display power on showing IBM Thinkpad full size, but when windows or DOS...
I've seen this before, the main problem is that the resolution is set too low, so it only fills part of the screen.
two ways to solve it.
1. Adjust the resolution to the optimal setting so it fills the entire screen.
2. Find the Picture Scaling option and have it Scale the picture to the entire screen.
To adjust the resolution, now its been a long time since I used windows 98, but I think you got to it by going to your desktop with the background, right click anywhere on the empty space and select properties, now on the window that opens it was the last page, settings I think, you should get an representation of your screen with a resolution lever and color options, pull the resolution lever one point to the right and hit apply and ok, do this until the picture fills the entire screen.
If your laptop has internet connectivity, I could take a look at it over remote support and solve the problem for you.
Oct 23, 2011 | IBM ThinkPad 380 Z (2635HGU) PC Notebook
How do you lighten the screen on the ibm a20m laptop computer?
Hello sandee232,
The following key combinations can be used for screen brightness:
•Fn + PgUp Turn the ThinkLight on or off.
•Fn + Home The LCD becomes brighter.
•Fn + End The LCD becomes less bright.
The screen brightness information can be located inthe IBM ThinkPad A21m User guide:
http://safemanuals.com/314159.php?k=c7c8bab9c3a5ec3c048ad8dc9eb006be&ID=321133&q=IBM%20THINKPAD%20A21M
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 04, 2010 | IBM ThinkPad A21m 2628 Notebook
Where is the wireless button on t42 thinkpad
There's no hardware switch to activate and deactivate the wireless networking, but pressing Fn and F5 brings up a menu that allows you to turn Bluetooth on/off, WiFi on/off or both. It seems like IBM isn't satisfied with standard toggle buttons like other notebook manufacturers - even pressing the Fn and F7 buttons to switch between internal and external screens, brings up a menu with multiple display settings and resolutions.
Hope this helps,
David
Mar 10, 2009 | IBM ThinkPad T42 Notebook
IBM Thinkpad R31
It looks like hardware problem.
Nov 08, 2008 | IBM ThinkPad R40 2722 Notebook
Back light on ibm t21
This is an known problem I think you must replace the backlight:
look for example ebay partnr: 260327530145
only for example if this is your problem.
PRODUCTS ITEMS
LCD CCFL BACKLIGHT LAMP IBM THINKPAD T20 T21 14.1" SCREEN
LAPTOP & MONITOR LCD SCREEN PROBLEMS
SOME COMMON SYMPTOMS FOR BACKLIGHT LAMP REPLACEMENT
- Flickering, red or pinkish hue to display and even total darkness. These symptoms are a result of a failed or ageing backlight or a failed, damaged. This is caused by the defective backlight lamp and all you need to do is replace the backlight.
DESCRIPTION
Our high brightness LCD cold cathode lamp (CCFL) with long life, it is more than 50000 hours, with Japanese new cathode, phosphor, glass, and other materials, they are perfect for all LCD backlight application and other purpose, such as instrumentation, medical devices, and all type devices.
COMPATIBLE MODELS
Suit for
Any 14.1” LCD Screen (2.0mm in diameter and 290mm Length) and (2.0mm in diameter and 292mm Length)
CUSTOMER SERVICE / CONTACT US
Email: mkproco@gmail.com (12 Hours Response Time)
Oct 14, 2008 | IBM ThinkPad T21 Notebook
How to repair ibm thinkpad t23 laptop screen no light
Yes you have no backlight. The screen is all dark but in the back you can barly see it. You inverter is bad on you thinkpad. You need to replace it. I have a IBM thinkpad 600e and i got one for $9.95 so they can be cheap. They are located under the lcd. When you open it up it is there or can see that it is attached to the light dimmer swicth so you will know that is it. Thats your problem
Sep 20, 2008 | IBM ThinkPad T23 2647 Notebook
Not show display clear is very darkness
Have you increase the brightnes by Fn key and brighntess key on above of keypad please set it first fn>+brightness key
Also please check wheather the deaault settings are in agp card settings in display properties
Regards
Balisonu79
Feb 15, 2008 | Lenovo ThinkPad R51
Dark screen
Your backlight is probably burned out. It is repairable, but I recommend having a computer repair shop take care of it.
Jan 28, 2008 | IBM ThinkPad G40 Notebook
Hi my IBM 2635-6AU, ThinkPad 380ED 26356AU screen is dark and i cant see
From what you are stating it seems like your backlight in your lcd needs to be replaced. Plug an external monitor up to your laptop. Press the fn & f key (the one with the picture of a monitor in it.) Your diplay should project to the monitor. Display is ok.....replace the backlight.
Hope this helps you
Oct 26, 2007 | IBM ThinkPad 380ED
Computers & Internet Logo
159 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
