Question about GPS
The device does not reassign new IP address via ethernet
When I first received the credit card terminal machine, I plugged the ethernet cable to the modem/router and then the AC cord to the outlet as instructed, since I could not get connected, I changed the IP address to the one numbered for my location, now my internet service company reassigned me another IP address but the machine remains powering on with the old IP info even if I unplugged it from everything, it does not accept the new one, how can I reset or unblock this old IP address without resetting the rest of the programmed info ? please help !!!
  • 18 Answers
Try leaving the Ethernet cable plugged into the machine and remove the power cord for say 10 secs. then plug it back in.
Posted on Mar 26, 2009
Where do i look to see why machine isn't calling out to verify card
first check the phone line it self. take all phone lines out of the credit card machine, and unplug the power to machine. now take a telephone with a phone line attached and plug that into wall as if you were making a call on that phone. check for dial tone. if you have a dial tone, make a call. do you require a 8 or 9 to dial out? you terminal may not recognize that.
also if you do have dial tone do you use digital or analog phone lines? you need analog for terminals. if you have a fax line you can connect the terminal to fax via phone line. if this does not work contact phone co and ask what type of lines you have, you can also connect most terminals via Ethernet.
Jun 08, 2014 | VeriFone Omni 3730 Aka Vx510 Credit Card...
Invalid ip address
im thinking your Credit processor IP settings have changed or your ternminal for some reason is not seing your processor IP settings and port. Calll your processor, and maybe you will need set the right IP address manually to your machine or they might ask you to redownload the application. Call (775) 358-2922 ask for Randy and maybe we can help you. Thanks
Jan 31, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
I've recently picked up a rio2e/tango2e card maker. I need to get a fixed IP address for the machine and will need to find the MAC address. I've been unsuccessful in finding the mac address (or static ip...
By default, the printers are set to take an assigned IP address from your DHCP server (or router) on your network. Connect it via the Ethernet port, then access the GUI for your server (or router) and check your connected devices - the MAC address for the Magicard printer will be presented there, along with the IP address that was assigned by the server (router).
Once you have the MAC address, you can then use "address reservation" features to ensure that a specific IP address is assigned to that device each time it is connected.
Aug 16, 2017 | Magicard Rio 2e - Ethernet - Single-Side...
Got a hub genius GH4080SE and trying to connect computers, pls advise what is the steps?
Hardware Setup
1 Find the WAN or uplink port of the Ethernet hub. Typically, it is located on the rear of the unit, and it is often separate from the LAN ports.
2 Connect an Ethernet cable from the WAN port of the hub to either the Ethernet port of the internet modem or, if expanding a network, to an empty LAN port on the existing network’s router, switch or hub.
3 Plug an Ethernet cable into one of the LAN ports on the Ethernet hub and connect the other end of cable to the computer or device that will be added to the network. Repeat for any other devices that will need to be on the network.
4 Power up the Ethernet hub and the computers or other devices attached to it. On the front of the hub will be a series of LEDs that correspond to each LAN and WAN port on the hub. Every port that has a cable plugged into it should have one or more of the LEDs lit that represent that port. If not, check the connections and swap out the Ethernet cable if necessary.
Software Setup
1 Configure the network settings on each connected computer. If you are expanding a network and the network uses DCHP, or dynamic IP addressing, no configuration will be necessary. On networks using static IP addressing or on a new network setup using the Ethernet hub, each computer or device must be assigned a unique IP address. Local IP addresses must use the allowed “private” address pools that will not interfere with internet addresses. Acceptable addresses include 192.168.x.x, 172.16.x.x to 172.31.x.x, or 10.x.x.x. The “x” represents a number that is chosen by the user, from 0 to 254. All computers on the network should share the first three numbers in the address, with the final number representing the individual computer. In a network with three computers, for example, the first could be 192.168.1.1, the second could be 192.168.1.2 and the third could be 192.168.1.3, though the final number does not need to be sequential.
2 Click the “Start” button in Windows, select “Control Panel" and double-click the icon labeled “Network Connections.”
3 Right-click the icon for the Ethernet adapter and select “Properties.” Click on the check box marked “Internet Protocol (TCP/IP)” and press the “Properties” button.
4 Select the radio button labeled “Use the following IP address.” Enter a unique IP address for the computer and the applicable subnet mask. If a router is used on the network, enter the router’s IP address as the default gateway. Press the “OK” button and reboot if necessary.
5 Enable file and printer sharing from the “Properties” dialog for the Ethernet card if files will be transferred between the networked computers.
6 Click the “Start” button, select “Control Panel” and double-click on the “System” icon. Select the “Computer Name” tab and click on the button labeled “Change” to set the computer’s network name. In the “Computer Name” box, enter a unique name for the computer. In the “Member of” section, choose the radio button marked “Workgroup” and enter the workgroup of the network. If setting up a new network, this name can be change but all computers on the network must share the same workgroup name.
7 Verify that all computers can access the network and the Internet if connected.
Read more: How to Set up an Ethernet Hub | eHow.com http://www.ehow.com/how_4530475_set-up-ethernet-hub.html#ixzz0xnIzsGqa
see also Networking Diagram
Aug 27, 2010 | Genius GH 4080 SE 8-Port Ethernet Hub...
Cant connect to xbox live need an ip address how do i get one
When the SurfBoard modem is powered up and connects to the internet on the WAN interface, it automatically gets an IP address from your ISP. When another machine is powered up and is connected to the modem via a USB cable, it is automatically using the WAN IP address to communicate with the world. If it is connected via the Ethernet connection, the modem automatically issues it its own IP address for use on the internal network via DHCP. The modem's internal Ethernet connection is 192.168.0.1. The next machine powered on will normally get an IP address of 192.168.0.2.
May 30, 2009 | Arris SURFboard® SB5101 Cable Modem
Can't connect to phone
I bought SNOM 300 and i was unable to connect the router in first go. it was keep saying Send DHCP reqt but nothing was happening. i tried even connecting SNOM 300 dirctly to my laptop but in vain. in last i started receiving message Ethernet cable unplugged.
I reset the SNOM 300 to the factory defaults which solved the problem immediately.
Get to the phone menu "configuration-Reset" and select this option. it will ask for the admin password which is 0000. This will fix the issue. try it.
Jan 23, 2009 | Snom 300 IP Phone
CAN'T CONNECT TO ISP USING ETHERNET NETWORK PORT DIMENSION 4700
make sure the cable is in the correct place. (8 ping plug-little bigger that the phone plug.)
1). start>>control panel>>system>device manager.
make sure there is not "red X" or yellow!" ont he network card.
if that is OK. right click on "my network place" on the desktop>>local area connection>> right click on properties again.
you will see the network card name, and select TCP/IP under the " This connection use the following item" box. Click on properties.
make sure the " Obtain the IP address automatically and the "Obtain DNS address automatically" are check.
shunt down the computer
wait 2 minutes, restart the machine.
open the Internet Browser after the machine finished loading.
Dec 16, 2008 | Dell Dimension 4700 PC Desktop
Verifone omni 3750 ethernet problems...
chances are you would need to RAM FILES, FLASH FILES, DEFRAG FILES....this is like resetting and crashing the terminal, starting all over again.
Try this, press F2 & F4 together you should be on GO VARIABLES, enter password 1 alpha alpha 66831 use the down arrow locate RAM FILES, CLEAR ALL GROUPS, CONFIRM, FLASH FILES, CLEAR ALL GROUPS, CONFIRM, then DEFRAG, ALL GROUPS, CONFIRM
Plug in your DSL or cable line (the one you are using) locate the DOWNLOAD, do a FULL
this should pickup your new IP address and make sure you are on COMM SERVER not on DIAL
(dial is only for analog phone line)
Nov 11, 2008 | VeriFone (M19755014US1) Magnetic Card...
Ethernet connexion IP address does not update automatically
press the purple more key on the left of screen then scroll down to other setup then go to comm then keep pressing next untill you see ip address then press edit, put in correct ip address, press exit and ok for save changes. If password is needed try 0000 then enter or
1 alpha alpha 66831 which would be Z66831 then enter
GPS Logo
111 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
