Examine the interface specifications for the what the HD is connected to. Most 120 MD SSD's are backwards compatible with SATA-150. Usually the specification with say SATA-II (3MB transfer speed) or SATA-III (6MB transfer speed). A SATA-III SSD will work on a SATA-II connecction.
A SATA drive cannot be set to master or slave like a PATA drive can. SATA only allows one device per port. If the problem is that you don't have any SATA ports in your computer, you can get a SATA host adapter card for your system, update your motherboard to a motherboard with SATA ports, or get a PATA hard drive.
Yes, it can be causing a problem. You have 2 hard drives that are working at 2 very different speeds. The computer is having to do a translation and adjust rates of transfer between them on top of having to do the read and writes between them. Will SATA II will be backwards compatible to SATA I it won't work the other way. If you have to keep these drives, I would make the SATA II Drive the primary and SATA I drive the secondary on a different channel if possible. The SATA II drive is teh faster drive and should be your main.
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
This is normal. SATA II drives spin much faster and run much hotter then IDE drives. You can attach a hard drive cooler to the hard drive if you wish and if there is enough room in your case.
Update: SATA II drives do have jumpers to make them backwards compatible with 1.5 Gb/s (SATA II drives are 3.0 Gb/s). So if your system is older and can only handle SATA (first Gen) then you have to add a jumper (Seagate has the jumper setting on the drive but sometimes supplies no jumper i.e. you have to have your own).
